Old 02-15-2017, 08:29 AM   #43
1972 23' Safari
Sierra Vista , Arizona
pulled it out of the shop today...time to swap axles, and finish up the belly pan.
jforb is offline   Reply With Quote
Old 02-17-2017, 03:07 PM   #44
1972 23' Safari
New axles, tires, brakes, etc. Belly pan is about done. Still so much to do...and we are planning on a little trip with the trailer on the 28th, if it's ready to go. Won't be finished, but it would have enough to camp in.
Old 02-17-2017, 04:30 PM   #45
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Sweet rig jforb!
SteveSueMac is online now   Reply With Quote
Old 02-19-2017, 07:01 PM   #46
1972 23' Safari
Thanks!
I did a little work today, got the propane plumbing finished, and tried it out. Had to redo one flare (the first one I made, of course), then it didn't leak. Stove works. Furnace works. Water heater works, although I didn't run it more than a few seconds, since it has no water in it. I still need to do all the fresh water plumbing.
I think I'll camp out tonight, and see how it works.
(I'm posting this from inside the Airstream, on my laptop, using the house wifi...fun!)
Old 02-20-2017, 09:38 AM   #47
nickclifford's Avatar
1972 31' Sovereign
felton , California
Originally Posted by jforb View Post
Thanks!
LOVE the black wheels ... did you buy new or have the originals sand blasted ? My '72 wheels are thrashed...not sure if cheaper to buy a sand blaster myself and refurbish or buy a new set .. ?
nickclifford is offline   Reply With Quote
Old 02-20-2017, 02:30 PM   #48
1972 23' Safari
Thanks! the wheels were supposed to be black, but they are dark walnut brown (it's hard for my old eyes to read paint cans like I used to). They original wheels were black, and the two replacement wheels (later factory type) were gray, and the two new wheels I bought were also gray. I sandblasted the used ones, and just spray can painted all 4. I still have the two original wheels, but they are pretty rusty on the back side. The originals have clips for the early style hubcaps, the wheels I used all have lugs for newer style caps. But I need to buy some of the deep ones, the 1970's truck hubcaps I have won't fit.
The furnace worked all night. I did some plumbing today, and just tried it out...no leaks on the pressure side (amazing, as I see it). But the sink trap is dripping. I guess I need to replace that. I left the old plumbing for the galley sink drain and vents, I guess it was a mistake. Oh well. It looks like it's just leaking at the screw together joint that I disassembled when I removed the sink. Maybe the angle is wrong, or something.
Also got the two new 30lb propane tanks purged and filled. Only $35 for the pair, which I guess is not too bad.
Old 02-21-2017, 10:07 PM   #49
1972 31' Sovereign
felton , California
found a metal worker where I live but he said would be way cheaper for me to buy my own sand blaster and do myslef ..
Old 02-22-2017, 12:30 AM   #50
1972 23' Safari
See what powder coating places can do. They sandblast as the first step in the process....
Old 02-22-2017, 07:32 AM   #51
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
VERY COOL! allot of great looking progress in a real short amount of time. Love the Lincoln!
Don't forget about Smoke Alarm & Carbon Monoxide Detectors...I hid mine in the closet just across from the bed (CO Detector at about the same height of our heads when sleeping. And I installed the LPG Detector just under the mattress.
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 02-22-2017, 07:33 AM   #52
1972 23' Safari
Thanks for the tip on the detectors, I hadn't thought of them...
Old 02-24-2017, 06:06 PM   #53
1972 23' Safari
I've been working on the bathroom, made the shower wall, and a couple other cabinet/wall things. And got the plumbing all done. Had only one leak, there was a nick on the end of the threaded neck on the shower valve, so the fitting wouldn't seal on it...did a little redneck machining with my lathe, all better.
Also got the solar panels and charge controller in the mail, so I installed them. We have sun charging now.
I don't know what's up with the pictures, they appear sidways or right side up depending on what I use to view them. Sorry about that.
Old 02-24-2017, 09:48 PM   #54
1972 23' Safari
Pictures...
ID:	280400   Click image for larger version
Old 02-25-2017, 10:51 AM   #55
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Jforb that looks very nice. Clean lines. Did you opt to not place a sink in bathroom and use the kitchen instead or is it just not visible.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-25-2017, 11:18 AM   #56
1972 23' Safari
That's right, we decided to forgo the lavatory, and use the kitchen sink. The vent for it was a problem...since I remove the closet, where it used to be.
I stayed up till midnight working on the shower curtain, and got that done. It works, I stayed in the Airstream last night, in the yard, and took a shower there this morning. It was a bit chilly, 27 degrees in the morning, so the furnace was running about half the time. So far, so good.
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
22 safari sport vs. 20 safari jeffrho Member Introductions 10 01-04-2008 07:52 PM
Safari 19' vs Safari 22' michael165 2006 Safari 15 06-04-2007 06:02 AM
On a safari for our Safari 3DogNight 2007 Safari SE 10 12-21-2006 12:54 AM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
