Old 01-18-2013, 02:43 PM   #1
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Your Inner MacGyver?
Three days from home the Up/Down switch on our power jack went to smoke. And, it also burnt out the 30A inline fuse. Well, that's a fine fix! First, I thought I'd tackle finding the fuse, so I could bypass the switch. Nope. Went to RadioShack, car parts etc. No 30A Type 3AG fuses. "Honey, cut me a piece of tin foil, please - 2" square."
Wrapped the blown fuse in tin foil and that seemed to work. Then I had to take the cover off the jack control, remove the switch, get two screwdrivers and hold one each across the DOWN contacts. Voila. That worked. The UP contacts were still ok.
I don't carry tons of tools, but I focus on MacGyver'ish things like "vice grips" and tape, and knives and glue, and well, you get the idea.
It's funny, but you get a good feeling when you can rig something up and make it work to get home on.
mstephens is offline   Reply With Quote
Old 01-18-2013, 02:54 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Seems overly complicated to me. If you carry a circuit tester, you can use the tester to bypass the fuse temporarily, without having to make anything.
But, having said that, it's hard to argue with success. Go, you!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-18-2013, 03:45 PM   #3
Lily&Me's Avatar
Normal , Illinois
We once retrieved a contact lens that had fallen to the floor behind one of the benches----with a spatula with chewed gum on the end.
Don't laugh, it worked.
Maggie
Old 01-18-2013, 04:04 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
What kind of jack do you have? Earlier Barkers had 2 plug in cheap internal relay switches that acted similar to your description. The Barker also had a hand crank in the event of an electrical jack failure.
Lumatic is online now   Reply With Quote
Old 01-18-2013, 04:45 PM   #5
mstephens's Avatar
It's not a Barker, it's an ACME. Bought it last year when we got the trailer. They call it a "Heavy Duty" jack and I paid a heavy duty price. I was a bit ticked off that the SW burned out in 12 months.
Ok, yes there is a hand crank. However, to use this crank efficiently, I would have to remove the propane cover and the tanks in order to swing the crank through 360 degrees. That would be fine if I had to do it once. But not so fine to do 6 times - 3 landings and 3 takeoffs. It was fairly easy to jimmy the switch with two screwdrivers.
Old 01-19-2013, 01:22 AM   #6
2005 19' Safari
GLENDALE , AZ
The manual crank handle mounts on the front of Atwood jacks, where there are no obstructions. Also, we have had no problems with ours since purchasing it about 5 years ago. However, we keep it covered with an old boat fender (bumper) to protect it from the sun, weather, dirt and road hazards.
Old 01-19-2013, 04:08 AM   #7
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Maggie
I remember getting coins through the porch planks that way. But not lately. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
