Old 09-01-2011, 10:21 AM   #15
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by Bk Yd Safari View Post
at 34 degrees are you concerned with holding tanks and water lines freezing? what precautions should be taken?
If you think it may freeze:
Use the furnace for heat. It will provide warm air to the fresh water and holding tanks.
If you are hooked up to water, turn off the water at the spigot, unhook and drain the hose.
That simple.
One time when in -10F. we had to use a hair dryer to blow hot hair up the tank dump pipe, because ice had formed against the inside of the valve, freezing it shut. It took about 5 mins.
Ken
Airstream sightings pinkflamingoes Our Community 7044 Today 10:46 AM
Yellowstone campgound needs, 1970 29' Ambassador tkauranen On The Road... 10 08-01-2011 05:29 PM
Ohio to Yellowstone 062011 Viper On The Road... 0 07-03-2011 09:40 PM
'59 Yellowstone eye candy Jammer Vintage Kin 3 06-09-2011 07:05 AM
Yellowstone! LFM On The Road... 8 05-08-2011 08:15 AM
