Old 12-12-2009, 10:02 PM   #1
i have moved north to VIRGINIA CITY , Nevada
wireless broadband internet ....
I have verizon wireless broadband internet and i was wondering if anyone else has it.
if so....how does it do in the AS ?
i dont know anything about what affects cell signals but i was wondering if the aluminum airstream made the signal harder to get..... since the broadband works off of cell towers like a phone.
thanks.
AnnieD is offline   Reply With Quote
Old 12-12-2009, 10:08 PM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Your Airstream's construction does not effect your BBI... If your cell phone works your BBI works!
Todd
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 12-12-2009, 10:49 PM   #3
San Diego , California
This link will give you more info on that.
This was covered last summer. Here is the thread. http://www.airforums.com/forums/f42/...oad-54021.html
Randy Bowman
OB Bambi is offline   Reply With Quote
Old 12-12-2009, 10:53 PM   #4
THANKS! thats what i wanted to know !
you guys are ALL GREAT!
LOVE these forums !
Old 12-12-2009, 11:55 PM   #5
vinstream's Avatar
FYI... I would look at a wireless card that works on both 3G and WIFI... More and more areas have WIFI and the card that I uses tells me if WIFI is available and the connection is way faster! I also think that my Mac works way faster than my IBM for mobile data gathering!
Todd
www.VINSTREAM.com
WBCCI # 1962
Old 12-13-2009, 06:06 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
FWIW the Airstream can cause signals to be weaker because of the metal. One thing I do to help is use an extender cable to put the USB aircard in a window to improve the signal strength. Some aircards will take an external antenna too.
Aaron
WBCCI #XXXX AIR #2495
Old 12-13-2009, 06:16 AM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I use a Verizon air card which is PCMCIA when on the road. I place the laptop next to a window for the best results. The signal can vary by several bars depending on my location inside the trailer. The best results are always outside.
Richard
Old 12-13-2009, 07:53 AM   #8
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I have Verizon wireless broadband. It works very well, and the coverage areas seem to be continuously expanding. A few years back, I used an external antenna connected to a signal amplifier to enhance the signal strength. Then, over time, the amp became less necessary, so I just used the external antenna, which also works on my cell phone. Now I use the Verizon USB720 air card, and with the included USB extension cable, all I usually have to do now is place the air card in the window for an acceptable signal. Can't speak for others, but in my own experience, being inside the Airstream (or any metal trailer, or vehicle) does affect the signal strength. But, in my case, it is easily resolved by getting the air card near a window, or with an external antenna.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 12-13-2009, 08:48 AM   #9
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
thanks.
When I travel, I connect to the Internet by tethering my Verizon Cell phone to my computer and using it as a modem. I use an USB cable, but a blue tooth connection will also work. The plus side to this is that you only need to activate the Mobile Band Broad feature; you do not need another plan. This means you can turn it on and off as often as you wish. The $49.95 charge is prorated for the time you have the feature activated. If you have a smart phone, the pricing is a little more complicated. In short, the total for Mobile Band Broad and whatever data feature is on your smart phone will be $59.95.
This group on yahoo is the place to go for info on this.
http://tech.groups.yahoo.com/group/InternetByCellPhone/
The aluminum skin on the airstream will definitely affect cell phone reception, as it will any radio reception. So if you use the USB cable method, be sure to have a cable long enough to allow placing the phone near a window. Which window you choose can also make a difference.
Regards,
Ken
Old 12-13-2009, 08:55 AM   #10
CanoeStream's Avatar
St. Cloud , Minnesota
My Dell was built with an internal verizon board. I don't know if it is grounding or what, but there is some antenna effect that makes my reception very good. With one bar (or less) signal strength on phones I've had -- I can hardly have a conversation. The verizon card has worked when I've had no bars on the cell. And one exceptional example when I know the direction to the cell tower was through the side of the trailer.
I don't necessarily seek a window position but then our dinette has about 180 degrees of windows around it ... though reception from cell towers is line of sight. So your results may vary until you find the right spot particular to your campsite.
5 meter Langford Nahanni
Old 12-13-2009, 09:00 AM   #11
Thanks everyone..... i will check into an antenna.
i would always be near a window when i am working online anyway.
thanks for your help.
Old 12-13-2009, 09:29 AM   #12
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Rouge Waves
This must be why I sleep better in the Airstream without all the negative waves from wifi/wireless/broadband/cell.
As soon as the honeybees discover this...we're in trouble.
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 12-13-2009, 10:15 AM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
IIRC voice requires a better signal strength than data, at least that has been my experience.
FWIW I have used both Sprint and Verizion with similar results where I had coverage. Currently the vendor is Verizon and I am satisfied with the results. I use one of 3 devices: PCMIA card, USB or a Blackberry either tethered or on blue tooth depending on the the laptop and who is paying for it.
Aaron
Old 12-13-2009, 10:18 AM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
We had a wireless data card for our computer, and found it worked best when tucked up under the streetside awning, with an extension cord attached. Otherwise, the connection would fizzle out at the most inopportune times.
Wireless Internet Cards Blevi On The Road... 39 06-29-2008 03:37 PM
Broadband Access with a PC Wireless Card Frank S Computers, Internet & Satellite 5 11-14-2006 01:53 PM
Free wireless internet Pop Rivet Computers, Internet & Satellite 41 09-12-2006 10:56 PM
Wireless internet? krowsea Electrical - Systems, Generators, Batteries & Solar 9 08-20-2004 10:17 AM
wireless internet lmbando Electrical - Systems, Generators, Batteries & Solar 10 11-06-2003 11:10 AM
