10-19-2008, 06:40 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
Winter driving with an Airstream
I'm not looking to tow our Safari on snow or slush or ice, but living where we are, I know that time will come someday. Just to get to a warmer clime means snow can happen anywhere from September to June in Colorado. Even if the state highways are clear, the 4 miles of county road from my house to the state highway are poorly maintained and have some very steep sections, well shaded to make sure the snow doesn't melt.
I've looked for a thread on this, even tried the "search" engine, and found nothing.
The salesman told me to turn on the brake controller to the minimum setting on snow—that made no sense to me. I've driven through blizzards for decades without mishap, but never with a trailer. I don't want to see the Safari try to pass me. Other than the usual admonitions (drive slower, never make quick changes of anything, brake gently, downshift going downhill—maybe that last one doesn't make sense?), what do I need to know?
Gene
10-19-2008, 06:47 PM
1968 28' Ambassador
Cedaredge
Hey Gene, I think he is right about the controller... If those wheels lock up, and they will on snow and ice the trailer will for sure come around...
I wonder if you could put drag chains on like the semi truck drivers do??
Drag chain goes on one tire on the trailer "man now I forget if it's the road or curb side" to stop the trailer from going into traffic if it slides... I think it's road side...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
10-19-2008, 06:50 PM
2002 25' Safari
Dewey
If you have a friction sway device it should not be used on slippery roads either.
Richard
10-19-2008, 06:58 PM
1968 28' Ambassador
Cedaredge
Why's that??? the trailer could pull you in the ditch??
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
10-19-2008, 07:22 PM
Master of Universe
Grand Junction
I can see not locking the trailer brakes, but I would have to hit the pedal pretty hard for that. Which makes me wonder about this—with ABS you're not supposed to pump the brakes, but the trailer brakes are not ABS. Pump or not to pump?
And, Richard, what is the reason for disconnecting the anti-sway bars? It seems to me they would make it harder to jack knife.
Gene
10-19-2008, 07:35 PM
2002 25' Safari
Dewey
The reason as I understand it is to prevent "understeering". With the TV and trailer locked together with the device on a snow or ice covered road. It is possible that you could turn the steering wheel and not turn. It is difficult to picture happening, but all of the friction sway companies will tell you not to use the device in slippery conditions.
Richard
10-19-2008, 07:42 PM
1993 34' Excella
Estancia
, New Mexico
Don't forget to pump the brakes, don't lock them. If towing in the snow is inevitable do some practicing. I wonder if manually applying the trailer brakes would help to bring it in line if it starts to wander. Another good question is does the general rule of steering into a skid (with a rear drive vehicle) apply when towing?
10-19-2008, 09:32 PM
2019 22' Sport
High River
, Alberta
It's possible to have friction sway controls too tight on dry pavement. This situation will show up when the steering wheel ends up off centre after making a turn. It means some of the tires are scrubbing a bit. This will happen more easily on wet or snow-covered pavement.
I've also discovered that it's beneficial to use less friction on winding roads (while driving at moderate speeds) so that the steering will unwind normally when accelerating out of curves. Otherwise you need to keep feeding it back to centre.
10-19-2008, 09:42 PM
Silver Mist
Riverhead
, New York
I've read some stuff towing in the snow, leave the brake controler settings the same, just drive slow a set of chains on one TT axle, maybe the the TV as well
I read that the ski resorts out west have plenty of TT in the parking lots on weekends.
10-19-2008, 10:19 PM
1968 28' Ambassador
Cedaredge
I change my trailer brakes sometimes... They seem to lock the wheels up on the trailer in gravel. So I'm guessing they would in snow... I would differently turn mine down...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
10-19-2008, 11:12 PM
2005 22' International CCD
Buckhorn
, Ontario
Hi CrawfordGene;
Not into the hi tech friction this or that or sway this or that....Our set up stays the same from dry/wet and snowy conditions. (except brake controller) It is our driving methods that adjust to the road conditions. Just as they should if you were not towing.
We ran to Florida three years and each time headed smack into terrible snowing conditions in NY state as well as PA in February.
Fresh rain on a slick hot ashfault road can be just as if not more dangerous than Snowy conditions ...so I am not sure why everyone gets freaked when the stuff is white - in fact snow is better traction at the best of times than slick ashfault.
Now ice is another story and if you are facing that condition then the smartest thing you can do is make it to your first exit and get off the road - until they are salted or become clear and dry.
If you have to travel during snowy conditions stick to the School Bus routes and if the school busses have been cancelled off the road then so should you be whether you are trailering or not.
As for the brake controller - we have a prodigy - and depending on the road conditions as well as the traffic conditions we adjust on the fly to the feel of the whole package. Well at least I do not sure what the Hubby does....if I find she is grabby I touch her down a bit. If I am having difficulty and feel like I have too much braking on the vehicle then I touch her up a bit. That way I feel the whole package braking rather than just one or the other. This helps me to drive accordingly in snowy conditions. Just as if you were in your car you can feel the speed at which you can loose control easily so you adjust your speed accordingly.
Not sure if you drive in consistent snowy conditions but trailering in snow is not that much different than driving your car in snow - but you do have to account for the trailer being behind you just as in normal driving conditions....
Not sure if this helps other than it is not hard to drive in snow if you are careful understand how your vehicle reacts and use your common sense to the severity of the road conditions.
Good luck and drive safe....
10-20-2008, 12:06 AM
Salem
, Oregon
Absolutely no experience.
Hi, I have absolutely no experience in towing on snow or ice, but my thought would be to put tire chains on the rear wheels of my tow vehicle and to use tire cables on my trailer useing two on the front tires or do all four. Turning down the brake controller makes sense. We want to camp in the snow, at least once, but that means that we will almost for sure have to travel in the snow, one or both ways.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
10-20-2008, 12:43 AM
Buckhorn
, Ontario
Originally Posted by ROBERTSUNRUS
...............but my thought would be to put tire chains on the rear wheels of my tow vehicle and to use tire cables on my trailer useing two on the front tires or do all four. .......
Well up here in the big old CAN that is what we use the 4X4 for.
Just think about what would happen if one of those chain links came loose - ouch on the side of your trailer...ripping and tearing comes to mind....
Using a lower gear would do you much better than chains... with 2 wheel drive....and I don't think there are too many US folks that tow with a 6C with front wheel drive which is way better in the snow than rear wheel drive. Speaking from driving in snow for many many years and never landed a ditch or a snow bank - knock wood....
10-20-2008, 01:23 AM
Yakima
I have pulled trailers, Horse trailers, etc in snow ice etc. If things are real bad put chains on the rear tires of your truck and Put chains on the front axel of your trailer. AND SLOW DOWN. If you own a new Ford with trailer brake controller the system will act like a anti lock system on both the truck and the trailer you just push on the braks and (NO PUMPING THE SYSTEM DOES THAT FOR YOU). Its the best in the business. Slow down.....I have pulled trailers in very bad conditions while hunting and had to put chains on all four wheels on the tow vehicle. I don't worry about me....its the other idiot on the road we all need to worry about because when its slick WE can't get out of the way. Chains on the trailer works well tho....you will be surprised.
10-20-2008, 09:45 AM
Airstream - Other
Bosque Farms
, New Mexico
Basically, what you need to do is to make it from Crawford down to Hotchkiss, maybe to Delta, right?
Two options: One, go really slow until you're onto clear road. Two, wait until the storm has cleared, and do the same as One.
The real trick, I think, would be to find a way out of the valley towards warm country on lower-altitude roads. That's where your area isn't the greatest. You could go up to Junction and do a major end-around, I guess, but the straightest shot, sort of straighter south from Delta, just goes up and over snowier areas.
We're more or less in the same spot. To go southwest, we have to go over some high country, and it's not a pleasing option. But the best in this regard is to make it to Taos and then head south by following as straight as possible a route. Alas, that also lands us right onto I25/I40, an option we prefer to avoid if at all possible, too.
Lynn
ACI Big Red Number 21043
10-20-2008, 10:21 AM
1968 28' Ambassador
Cedaredge
Thats the good thing about Cedaredge, Just point it down hill to Delta...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
10-20-2008, 10:24 AM
1969 31' Sovereign
atlanta
, Georgia
I went from Denver to Steamboat last year in what were kinda scary conditions last December. I have chains for all 4 TV tires and also all 4 AS tires, but was fortunate and never had to use them. The key is to use good judgment, be VERY aware of your surroundings and SLOW WAY DOWN. I also will use pull offs on secondary roads to allow faster traffic by me.
10-20-2008, 11:02 AM
Master of Universe
Grand Junction
Thanks for all the comments and ideas.
Thanks Lynn. The worst for us is to make it to Crawford on the county roads. The escape route from there is to Delta, Grand Junction and then across Utah on I-70 to I-15 south. We're not planning on a February trip, but November and "Spring", a sometimes fleeting thing here, are the problem months (along with just about all of them). I can't imagine going over the mountains to Taos with a trailer in winter from Angel Fire and recall one road south is a narrow FS road. I would think the escape route is NE toward Cimarron and I-25.
But I digress. I'm still confused. I don't have a Ford, so I don't get ABS braking for the trailer. How to avoid locking the brakes without screwing up the ABS braking in the truck? Operating the brake controller manually seems too dangerous except for emergencies—it's mounted so low that I couldn't easily control the steering wheel at a time when careful control is very necessary. The truck has all the antiskid and stability controls, although when in 4WD, one is disengaged. I wonder how that affects things since they operate through the ABS system.
Lumatic asked some good questions: "I wonder if manually applying the trailer brakes would help to bring it in line if it starts to wander. Another good question is does the general rule of steering into a skid (with a rear drive vehicle) apply when towing?"
My understanding is if the trailer fishtails for any reason—maybe a blown tire, slick road, or high winds—applying the trailer brakes manually would straighten it out. So maybe that works in snow too, but reaching the the controller is an issue. Steering into a skid is to reduce fishtailing and with a trailer the dynamic may be very different—for example, if the rear wheels of the TV break to the left, wouldn't the trailer go to the right?
The worst place to be is going uphill and not making it to the top. It's bad enough backing down a slippery hill with just the truck (around here, no guardrails, the ditch really close to the road because there are no shoulders and sharp turns at the bottom), but with a trailer? It seems to me tires that cause no problems driving up such a hill without a trailer, may not have enough traction with 3.5 tons attached to the truck. And of course, backing is, well, backing.
Going downhill (forward) can be an issue, especially in traffic. Sometimes the road is so slick, the truck will slide when you are trying to stop or even when going very slow. I think that would be a time to use (very gently) the brake controller manually. Going downhill is always the most dangerous situation to me, especially with sharp curves.
Taking the Equalizer bars off is a possibility (if there's a place to pull over). It seems counterintuitive—I would think the antisway function would prevent or dampen fishtailing, though once it starts, the antisway bars could make the back end of the truck break away.
My general rule about chains is: if I need them, I'm staying where I am. I have had 4WD for so long and always with good M&S tires that I never get stuck or go off the road. Of course, towing is different and I want to have thought this out before I find myself on a snowy road.
The thought of controlling a skid with those tons behind me with a pivot point so small makes me a bit nervous. I see ranchers towing horse and cattle trailers all year and they probably grew up doing it, so they have a lot of practice. The only practice I'll get is when it snows and I'm trying to get home.
Gene
10-20-2008, 11:37 AM
1984 31' Airstream310
Ajo
Words of wisdom: we've poked our nose into the "winter wonderland" more
times than I like to remember. If you have to travel in that stuff, have full
fuel & propane, food & libations for when you finally get it & pull over.
We stay at the KOA in Flagstaff, & help land trailers & mo/ho when the storms
force everyone off I-40: you've never seen so many relieved people in your
life.
10-20-2008, 12:51 PM
1968 28' Ambassador
Cedaredge
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
