Old 12-28-2016, 09:40 AM   #43
2011 23' Flying Cloud
Durango , Colorado
Originally Posted by JamuJoe View Post
Al, you are certainly correct. There will be heat transfer which is increased to some extent by airflow over surfaces. This is why the automobile radiator has so much surface area created by the fins, and fan speeds and temperature differentials that are significant. Low air velocity over a smooth surface is less significant. The calculations could get quite meaty and it's been a long time since my thermodynamics courses😴. My opinion was that the advantage of skirting a thin skinned aluminum shell trailer would be relatively minimal and not worth the bother in traveling mode.
ps; By 'travelling mode' I mean camping for overnight or short periods only, as opposed to a more permanent setup.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 12-28-2016, 09:56 AM   #44
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
My wife and I are completely into winter camping. In Maui. In a condo.
Mike
Caffeinated is offline   Reply With Quote
Old 12-29-2016, 11:42 AM   #45
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
Mike
Do you have courtesy parking? 😉
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 01-05-2017, 04:56 AM   #46
Long Island , New York
Would be curious for an update whether you made it through the recent cold spell (with strong winds), without any damage to your plumbing including the outdoor shower? Your new thread about better insulation highlights the main point I was making last week about massive infusion of propane being required to keep an Airstream's plumbing functional during extreme cold.
What kind of propane usage did you find was necessary to keep the pipes from freezing?
Peter
Originally Posted by Vitaver View Post
Furnace does blow hot air to the plumbing below, so in subfreezing it needs to run. The combo space-heater/s - furnace is a balance. I sat the space heaters (2, a larger one by the galley and a smaller for the bedroom aft) at 50% heating capacity AND the thermostat for the furnace to kick in at 50 F. I assume (correctly so far) that if the cabin is kept above 50, leaving cabinets open will suffice to keep the plumbing above 32 F. This way I use a lot less propane and not much electricity. I am connected to the grid. Outside temp falls below freezing every day and (touch wood, cross fingers, etc.) fully functional, full enjoyment of the rig so far. About $30 of electricity in about a month. BTW, not trying to prove any point, just enjoying life
Old 01-05-2017, 06:06 AM   #47
Thanks for the entertaining video!
StrmyWeather is offline   Reply With Quote
Old 01-05-2017, 07:21 AM   #48
2016 FC27FB - F350 2017
2016 27' Flying Cloud
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
Hi Peter, I just posted a lengthy reply in a different forum. If you don't see it or incomplete, please ask and I will send it to you as a message. Thanks.
2016 FC27FB - 2017 F350 Platinum 6.7L Diesel, Crew Cab. - 2017 Audi A7S - 2018 Land Rover Discovery HSE
Accuracy International + SB, various.
GSD Sigrid - Fort Lauderdale, FL, Golden, CO and Silverthorne, CO
Vitaver is offline   Reply With Quote
Old 01-05-2017, 08:03 AM   #49
Thanks I saw it.
Old 01-06-2017, 10:08 PM   #50
Today one of my propane bottles emptied, after a month of use. I did experience freezing on the black tank valve and on the shower elbow, so I added 2 lamps under the rig with some wood boards around the tanks to keep more of the heat. One space heater on high, one on low (1.5KW and 750 W), and the thermostat on the wall set at 69.
Old 01-06-2017, 11:21 PM   #51
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Originally Posted by Wesair View Post
I ran two 1500 watt space heaters and blew a breaker. Can anyone tell me if there is more than one circuit for AC plug ins and if so how do I tell what is on which circuit?
The owners manual for my 2013 Flying Cloud lists all the 120V circuits for each model of trailer. For the 25FB, the two bedroom outlets share a circuit with the battery charger. The remaining outlets are all on a different circuit. That's for a standard 25FB with single air conditioner.
SSquared is offline   Reply With Quote
Old 01-06-2017, 11:51 PM   #52
SSquared's Avatar
Longmont , Colorado
Another thing to be aware of....inside the 120 volt electrical panel, the wiring is done with screw-down fasteners. Sometimes these work loose. When you run high current loads over long periods, the loose connectors get hot an things go downhill. It would be a good idea to open the box up and tighten down the screws, especially on the neutral buss bar.
You can see scary pictures and a better explanation at http://www.airforums.com/forums/f44/...re-158530.html
Old 01-07-2017, 06:06 AM   #53
2015 25' FB Flying Cloud
Fairmont , Minnesota
Good information, thanks. Its amazing how many things there are to keep track of. Tightening the screws would be a good thing to add to the dewinterizing process.
Wesair is offline   Reply With Quote
Old 04-16-2018, 02:44 PM   #54
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Springtime in Ontario
Glad we have our Dickinson Fireplace.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 04-16-2018, 03:59 PM   #55
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
My wife and I winter camp every year, in all kinds of conditions, and we absolutely love it! In many ways we enjoy it more than camping in the warmer months. We really enjoy the solitude of having complete state park campgrounds to ourselves or very few other hearty souls. I think that's what we love the most, not having to deal with the crowded campgrounds in season. We see much more wildlife in the winter, I assume because there are less people to scare off the animals. Literally herds of dear strolling past our rig seemingly without a care. When it's not too cold, night time walks through the park can be just amazing. Lit up by only the stars and the moon. No need to make reservations however always need to check if the campground is open year round. Our 310TD keeps us warm and toasty with proper care and use of the furnace and a couple of electric ceramic heaters. Some of our most memorable camping experiences have been during our annual winter camping adventures. We've made small mods over the years to make the rig warmer and to keep all systems running properly without freezing up. We usually camp for 4 to 8 weeks during the winter months usually between mid Dec and the middle of Feb or there about. Our kids live out west in CO so that's where we have done most of our winter camping. Also in MO, KS, IL, NB, NM.....we absolutely love it!
Lyons Colorado along the St Vrain river, one of our favorite spots.
mayco is offline   Reply With Quote
Old 02-20-2019, 03:54 AM   #56
Mary Esther , FL
Hello, Vitaver.
Would you mind sending this to me? Our first foray into full-time Airstreaming will likely start in January in New Mexico, so I am vaccuuming up every ounce of experience I can find!
Thanks!
Lindenwood is offline   Reply With Quote
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 09:17 AM
Winter Camping ajjohnsons Our Community 5 10-07-2004 07:42 PM
Winter camping - low temps etc. Mariner On The Road... 5 12-12-2003 08:45 PM
winter camping wheel interested Winter Living 12 11-02-2003 11:30 AM
winter camping murphy Our Community 1 10-27-2002 06:31 PM
