I weighed the 34' and Tundra before I took it to storage. I did not get empty weights, just loaded weights as I towed it. I wanted to see how much margin I had, if any, between the loaded axle weights and the axle ratings. I was traveling pretty light. No wife, no dog and only about 150 lbs in the bed and pretty much an empty trailer.
front axle- 3,140 lbs, weight limit- 3,900 lbs, margin is 760 lbs.
rear axle- 3,520 lbs, weight limit- 4,100 lbs, margin is 580 lbs.
Total TV- 6,660 lbs, weight limit- 6,900 lbs, margin is only 240 lbs.
34' plus Tundra- 14,000 lbs, combo weight limit- 16,000 lbs, margin is 2,0000 lbs.
34' trailer- 7,340 lbs, weight limit 8,900 lbs, margin is 1,560 lbs.
It is safe to say that I will probably be over the Tundra gvwr of 6,900 lbs by the time the Tundra and 34' are fully loaded. If I remove the Tundra cap, this will reduce the Tundra weight by about 200 lbs.
We shall see.
Dan
