Old 09-14-2007, 01:40 PM   #29
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by jimspeer
Hi, Jim,
Last summer we visited the part of Georgia you mentioned in our 28' Safari being towed by a 4WD F-150 crew cab rated to tow 8800#. We had absolutely no problems. This year we are in the Virginia Blue Ridge Mountains with, again, no problems. I think our Hensley hitch and Prodegy controller help a lot, too.
Cheers,
Thanks for the info. I have a Hensley and a Prodegy also so should be good. I do have 2 wheel drive which should not make a difference in good weather.
Thanks Jim
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 09-21-2007, 08:51 PM   #30
shantz's Avatar
1979 25' Tradewind
virginia beach , Virginia
you can always regear your F150 to 4:10 gears
when I added larger tires I regeared to 4:56 and now have no issues pulling my 25" Tradewind
I will be upgrading in the next two years to a Dodge 2500 Cummins Diesel
shantz is offline   Reply With Quote
Old 09-21-2007, 11:08 PM   #31
Wayward's Avatar
Cary , North Carolina
Jim, the F150 is an exceptional truck and more than capable of hauling the Safari. The advice above is good especially the tranny cooling. Only wishing I had the power of the 5.4 , I can pass along a few things that have made things easier towing with my F150:
- Consider a lower gear (4.10 or so) in the differential if your f-150 does not already have one. I run 4.30 Ford Racing gears.
- Use Redline lubricants exclusively and change often, especially in the transmission - your tranny will take the brunt of uphill towing
- Add Water Wetter to the cooling system for an extra margin of protection
- A limited slip differential, if you do not already have one, significantly improves traction and control. I added a Ford Racing Traction Lock with the new gears.
F150Online has a forum dedicated to towing with the F150 that you may find intersting: F150online Forums . There is a lot of experience there on shifting when towing with the F150 auto tranny.
And if you still feel an urge to fly up the hills with the big diesels, visit Troyer Performance. Mike can send you things like chips, intake, electric fans and underdrive pulleys etc that will add 60-80hp and similar torque gains without affecting the reliability of the 5.4.
...........Scott
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Safari 23 SE - lock fresh water intake? TheThreeSeas 2006 - 2010 Classic (all lengths) 16 02-07-2007 05:03 PM
re-plumbed '67 Safari tod47d Plumbing - Systems & Fixtures 4 01-30-2006 11:04 AM
'99 25' Safari water leak driving me crazy Raptorrider2001 1999 Safari 4 12-06-2002 06:34 PM
Help - price of new Safari & towing with 2002 Explorer dmac Our Community 0 11-22-2002 04:26 PM
Georgia Rally ALANSD WBCCI Rallies & Events 0 04-18-2002 09:35 AM
