Old 11-13-2015, 04:24 PM   #113
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Or it may shift more...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-13-2015, 06:33 PM   #114
1998 30' Excella 1000
Livingston , Texas
I find that the tow/haul mode on the newer transmission reduces "hunting" in slight to moderately hilly terrain.
On a related note, I recently let the tranny shift fairly often in more than moderately rolling hilly terrain, while monitering the temperature. It went no higher than 190 degrees. I'm wondering if the newer transmissions are more resistant to over heating during frequent shifting--- better cooling, new fluids, electronic shifting, etc? Any one know if this is true or what could explain it?
Siegmann is offline   Reply With Quote
Old 11-13-2015, 06:52 PM   #115
m.hony's Avatar
2013 30' Classic
A Duramax/Allison doesn't downshift when climbing a hill-
TAC #MS-10
Airforums #70955
Old 11-13-2015, 06:55 PM   #116
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The pickup gas V8's have plenty of torque, later models with five plus liters around 400 ft lbs, it's just reached at higher rpm's. The problem with constant shifting is easily cured by simply lowering the transmission into a lower gear and finding an engine speed generating enough torque. That will stop repeated shifting for hills and headwinds.
On our Ram 1500 5.7 Hemi towing our 25' FC, that gear is 4th or 5th of six gears depending on terrain, 1800 to 2100 rpm about 60 mph or so. The fuel economy is actually better when the engine is held at a constant speed, normally 10-12 mpg towing 60-65 mph, 20-21 mpg 65 mph not towing. We've seen better, but that's not the usual.
Doug and Cheryl
Old 11-14-2015, 05:20 AM   #117
2007 28' International CCD
1999 34' Limited
2009 22' Interstate
Woodbury , Minnesota
Thanks for the input. The only trip I have taken is from New Mexico where I bought it to Minnesota. I have the 8 speed and did not feel that it shifted excessively.
dickschaak is offline   Reply With Quote
Old 11-14-2015, 06:25 AM   #118
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My dodge with 6.7 come along and 6 speed auto don't either, it is called horsepower and torque, it will keep pulling at 1000 rpm....
Old 11-17-2015, 08:09 AM   #119
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My 2015 Ram CTD in tow haul will shift from 6 to 5 when it hits a hill to maintain 60 just towing over Ozark hills. It will stay in 5 after that. I've only got 1400 miles on mine.
Kelvin
Old 11-17-2015, 09:24 AM   #120
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
High loads plus low RPMs beats the crap out of your crankshaft bearings, both mains and rod journals. Downshifting is not evil.
Gearheart is offline   Reply With Quote
Old 11-18-2015, 10:22 AM   #121
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I keep the 6.7L Cummins between 1,450 and 1,650 rpm on the level and closer to 1,650 or higher on significant hills or mountains. The 1,650 rpm number is peak torque.
Best SUV to pull my big 30 foot Airstream with? Melimelo On The Road... 29 12-01-2013 09:46 AM
Truck suggestions to pull '68 Tradewind Splinter Tow Vehicles 12 03-26-2013 05:33 AM
Anybody here pull their Airstream with a big truck? scarylarry Tow Vehicles 25 10-03-2011 09:09 AM
Will truck I love pull the A/S I Love? Pudentane Full-Timing 55 07-28-2008 04:53 AM
Looking for opinions on a truck (pull vehicle) Northway@mag Tow Vehicles 18 12-30-2007 06:53 PM
