05-27-2015, 10:18 AM
2010 28' Flying Cloud
Lower Alabama
, USA
Which EZ Up to buy?
Want to get an EZ-Up. I'm told the EZ-Up is the brand to go with.
Which model should one get?
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
05-27-2015, 10:49 AM
2012 27' FB Classic
Jamestown
, Rhode Island
We have a 10 X 10 and a older Pagoda style, I like the 10 X 10. EZ up has a heavy duty frame and comes in a roller bag. Greg
05-27-2015, 10:52 AM
Biloxi
, Mississippi
10x10 is a good size.
MICHAEL
05-27-2015, 10:59 AM
1976 31' Sovereign
Oswego
There several sizes. you will have to decide size wanted, but make sure has vertical strait legs not angled. I have both but like strait leg more, also pur. side panels, they fasten with velcro, much better than trying to use tarps. Sides are must have if raining or cold. Larger sizes are heavy. I have 10x10 suits me fine. Make sure buy or make pegs to anchor canopy and bottom of sides. Pole barn nails also make good pegs
05-27-2015, 11:27 AM
2006 19' Safari
New Smyrna Beach
10x10 from Walmart.(I think the brand now is Ozark Trail).
I have several that I use camping and have held up well in downpours.
05-27-2015, 12:15 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I've had an EZ -Up ( I think it's 10') for several years but only use it occasionally. Very sturdy and easy to use.
2019 Ford Expedition Platinum
05-27-2015, 12:34 PM
1995 30' Excella
Bowie
, Maryland
I think ours is a 12x12, and it's nice, but it's larger and that much heavier to move around, too, and you can pretty much forget putting it up alone - the smaller ones you can usually do alone if you have to, but ours has to have two people. We use ours a couple times a year - sometimes for rallies, or at home if we're having a cookout. It's handy to have around. (Ours isn't an EZ-Up brand, I think. We got it at Dick's.)
We had a 10x10, but unfortunately it was destroyed by a sudden rain storm during its fourth use. Not its fault, of course, and some food vendors lost one or two of theirs in the same storm. The metal frame went completely bananas, and replacing the frame cost as much as buying a whole new unit.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
05-27-2015, 02:00 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I use the 10x10 slant leg with sides. Mine is the Quest brand, I agree that EZ up is the one to go with. You can buy parts for it pretty easily. My Quest needs a new top, cheaper to just buy a whole new unit.
Aaron
WBCCI #XXXX AIR #2495
05-27-2015, 02:35 PM
2010 25' FB Flying Cloud
Davenport
, Iowa
SIZE DOES MATTER; I have the 10X10 with both screen and solid sides. I take it on most trips. There is now a 10X 15 and that will be the next one. It has the same functions as the 10x10 and 12x12.
Check on Ralleys for Spring in Northern Illinois at Lowden SP and see how we have them arranged. Two are Featherbedders , 1 Tom Nuglers and one is mine.
We could have used a "Circus Tent"
mike
05-27-2015, 02:37 PM
Davenport
, Iowa
P.S. GET ONE WITH STRAIGHT LEGS. Easier to enclose if needed.
05-27-2015, 03:41 PM
2016 28' Flying Cloud
Brandenburg
, Kentucky
Also get an Ez-up with the silver reflective coating on the inside. They stay lots cooler in full sun exposure. I've had my Ez-up for a long time and am very happy with it.
05-27-2015, 03:52 PM
1976 31' Sovereign
Oswego
ezup
My 10x10 has silver coating inside, and most I have seen have coating, The slant leg is not ezup, little harder to set up plus no storage bag and no coating. Cheapy I think from harbor frt. In pics. of spring rally sides not on but we put on both sides and one end as some times heavy rain, every thing stayed dry so it was enjoyable for pot luck and just lounging.
05-27-2015, 04:59 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
E-Z Up makes both straight leg and slant leg. I have a Qwest which appears to be a direct copy of the E-Z UP. Mine has silver coating, slant legs and came with a full set of screens, shelter pieces for 3 sides and a roller bag. IIRC all in was ~$110 from Dick's on sale. E-Z UP would have been 3-4 times that. The closest thing they have to the one I have would be the Vista and they don' appear to make shelter panels for that one.
Aaron
05-28-2015, 11:26 AM
Tomball
We have two of the 12X12 EZ Up canopies with straight legs. They are heavier and although my husband has done the putting up and taking down alone he finds that I can be a helpful asset. We would not consider any that were not straight legs because you can tie wrap together easily. We use with our teardrop camper right now but they will be going along if we ever get that Airstream.
05-28-2015, 09:21 PM
1976 31' Sovereign
Oswego
Ez up slant leg is cheapest version and not as sturdy as strate leg version.
05-28-2015, 09:53 PM
1969 25' Tradewind
Shasta Lake
We have 2 genuine E-Z UP's . 10'x10' in white and a 8'x 15' in black.
Believe it or not the back is cooler as it blocks the Infrared rays and the white doesn't very well.
I find it easier to set up and take down the 8x15.
BTW a little WD-40 wiped in the legs make it a lot easier and should be part of your regular maintenance .
05-29-2015, 07:27 AM
1976 31' Sovereign
Oswego
Ez up
Why not spray dry lube on legs instead of wd-40 no mess easier to apply and legs slide easy? I spray dry lube on Zip-Dee awning arms for same reason, plus use for many other items that need lube.
