Old 05-28-2015, 09:21 PM   #15
1976 31' Sovereign
Oswego , Illinois
Ez up slant leg is cheapest version and not as sturdy as strate leg version.
Old 05-28-2015, 09:53 PM   #16
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
We have 2 genuine E-Z UP's . 10'x10' in white and a 8'x 15' in black.
Believe it or not the back is cooler as it blocks the Infrared rays and the white doesn't very well.
I find it easier to set up and take down the 8x15.
BTW a little WD-40 wiped in the legs make it a lot easier and should be part of your regular maintenance .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 05-29-2015, 07:27 AM   #17
1976 31' Sovereign
Oswego , Illinois
Smile Ez up
Why not spray dry lube on legs instead of wd-40 no mess easier to apply and legs slide easy? I spray dry lube on Zip-Dee awning arms for same reason, plus use for many other items that need lube.
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
