Old 09-23-2003, 05:41 PM   #1
wheel trim fix?
Not sure how to address this issue -- as you can see from photo the aluminum "trim" has been applied with white caulk and it's very rough. I'm guessing someone did this because of the sharp edge around wheel well area. I would like to remove the caulk and the thin piece of alumimum trim (it's on the verge of falling off all on it's own.) You can see that I already removed a bit on the right side. Not sure what to replace it with. Any suggestions would be great!
cherring is offline   Reply With Quote
Old 09-23-2003, 09:15 PM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Photo didn't work.
Yours should be the same as ours if your talking about the wheel opening trim. The original peice is an aluminum strip with a bead that forms the visible garnish. It's riveted on and it appears that riviet joins the wheel well tub to the outer body.
I'll be removing this peice by the end of weekend and try to get you a good picture.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-23-2003, 09:46 PM   #3
Images: 59
Wheel trim
I've been looking for it too. There are hundreds of extrusion shop with thousands of shapes. Best I could find so far was an edge bead for 1/16th inch open channel. It might work with a little tapping to close the channel. I'm still looking.
Old 09-24-2003, 05:15 AM   #4
Here's the photo that I tried to send last night. Thanks for the advice!
Old 09-24-2003, 07:04 AM   #5
Images: 59
Wheel Trim
Here's the part off my Ohio '59. The opening is about .060"
Old 09-24-2003, 07:24 AM   #6
Mark,
Is this the original piece or the replacement piece in the photo?
Old 09-24-2003, 10:23 AM   #7
Images: 59
Wheel trim
That's very original. I don't know how long this particular trim was used. Mine was built at Jackson Center Ohio in early '59. I know the California units were different. Where was your's built?
Old 09-24-2003, 11:03 AM   #8
Mine is a California model. It's got a '59 serial number but an additional tag on it is stamped 12/58.
I'll have to go out and look at the '60 CA model that I have and the '61 Ohio model to compare as well.
Old 09-24-2003, 11:14 AM   #9
Images: 59
Wheel trim
Saw on a previous posting (may have been a different forum) the different wheel openings used on the CA and OH models. Sorry I couln't help with your trim.
Old 09-24-2003, 01:05 PM   #10
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Airstream did the same thing as the Auto manufactures. The new model year starts in Oct. So anything dated 10/58 through 9/59 is a 59 Model.
I think The different wheel opening was more the shape it was cut. I have found the Shape on our Ohio built 59's were the first year they did that. I have heard it refered to the "Crown" wheel openings. The California plant was still cutting the wheel well with a slight slop down from front to rear for 59, sort of a teardrop. Pretty good chance the garnish used is the same.
1959 22' Caravanner
Atlanta, GA
Old 09-24-2003, 01:47 PM   #11
I checked out the '60 CA and it doesn't have any trim at all around the wheel well. In fact, it doesn't look like it ever had any. It's a very sharp edge.
The '61 Ohio model is currently at my folk's, so I'll have to check it out on my next visit.
Wheel lockup erstrong Brakes & Brake Controllers 2 10-07-2003 12:52 AM
exterior trim rivets skip Ribs, Skins & Rivets 4 08-15-2003 07:33 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Door Trim smily Doors & Locks 1 01-03-2003 08:27 PM
