05-18-2014, 08:00 PM
#41
Hampton
, New Hampshire
Originally Posted by Landrum
I'm seeing something strange I think.......do your wheels not match?
I suspect you may be looking at Safari Rick's picture and mistaking it for mine.
Brad (The Slowsky's)
2019 Airstream Classic 30RBT, 2021 Ford F350 King Ranch 4X4 w/6.7L Diesel, Hensley, ACI #1313
travelwiththeslowskys.com
05-18-2014, 08:12 PM
#42
2014 25' FB International
Little Rock
, Arkansas
Yep
05-18-2014, 08:24 PM
#43
2002 30' Classic S/O
Fleming Island
Brad, hope you get the drum fixed up quickly tomorrow. Hard to tell from the pictures, but looks like one or two bolt holes on the wheel may be damaged. As suggested by several others, probably a good idea to check the torque on the other wheels. Maybe your mechanic can tell from the remaining stud heads how they failed.
Sorry for the hijack, but this seems like a good time/place to ask.
So, since I'm heading out Thursday for Cedar Key for the first trip on my new Sendels and 16" Michelin LTs, what should I torque them to? Someone on here said JC's spec was 100 lb.ft. That's what they are at right now. I will stop about 50 miles down the road and check them.
Al
05-18-2014, 09:23 PM
#44
2014 30' Flying Cloud
Ponce Inlet
According to my 2014 FC manual 110 ft lb max torque
Sent from my ADR6400L using Airstream Forums mobile app
05-18-2014, 09:27 PM
#45
Fleming Island
Thanks Beach Bum. I'll crank them up to 110 before I leave.
05-18-2014, 09:41 PM
#46
Salem
, Oregon
Attachment 212290
Hi, if Airstream could be more consistent; My owner's manual states that my lug nuts are to be torqued to 110 lbs to 120 lbs. I torque mine at the max 120 lbs. It also says to torque my spare steel wheel to only 90 lbs.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
05-18-2014, 10:27 PM
#47
ottawa (greely)
, Ontario
Originally Posted by ROBERTSUNRUS
Hi, yes in some cases, but not when the hub and drum don't separate.
You still just drive the old studs out, hammer them from were the wheel nut was and install them from back side of drum ,you can hammer them in ,but best to use the wheel nut with a spacer under it,and just torque it to specs 120 lbs?then recheck wheel torque first mile then follow normal retorque as per manual .and yes you must take drum off to perform this repair .
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
05-19-2014, 04:49 AM
#48
Baltimore
, Maryland
you might notice four broken studs and two empty holes? The two came off and the rim broke the rest off… that's my story and I am sticking to it.
I love these aluminum wheels they use. They keep my shop and many of my competitors flush with body work.
05-19-2014, 05:07 AM
#49
2014 25' Flying Cloud
Cuddebackville
, New York
Originally Posted by Al and Missy
So, since I'm heading out Thursday for Cedar Key for the first trip on my new Sendels and 16" Michelin LTs, what should I torque them to?l
When I bought mine a few years back JC told me 125-130. That's what I've been doing with no problems.
2019 Ford Expedition Platinum
05-19-2014, 06:15 AM
#50
1981 31' Excella II
New Market
, Alabama
Are you saying that the Aluminum wheels have issues Frank? I remember my manual saying something about rims needed to be removed and places with the holes aligned the same way or a wire brush should be used to remove all oxidation from the rim and seating area on the drum. His rim looked clean as far as oxidation.
Perry
05-19-2014, 06:27 AM
#51
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
From what I see in the pictures, it seems that there are witness marks on the wheel and the hub that seem to indicate that the wheel ran loose for a while.
05-19-2014, 09:05 AM
#52
Hampton
, New Hampshire
I think the wheel did come loose a bit with two studs (broken off inside) and then the rest sheared off. Had Rubio's out here this morning, and as you would expect they need to overnight the correct studs, so final repair (hopefully) tomorrow morning.
05-19-2014, 09:45 AM
#53
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Torque specs are different for STEEL wheels and ALUMINUM ones. 110 for Aluminum, I think steel is higher - 125 - but that's memory not fact.
Paula
05-19-2014, 09:51 AM
#54
2009 23' FB Flying Cloud
Canmore
, Alberta
Airstream manual calls for 110 lbs torque for aluminum wheels and 100 lbs for steel wheels.
05-19-2014, 09:58 AM
#55
Fleming Island
Yes, but, my (2001) manual calls for 85 on Aluminum wheels. I emailed AS to ask. We'll see what they say.
Al
05-19-2014, 10:00 AM
#56
Canmore
, Alberta
Al
Could well be that torquing specifications have changed over the years, with new casting techniques for wheels, etc.
05-19-2014, 10:09 AM
#57
Hampton
, New Hampshire
Al
I don't expect you (or anyone else) will experience my issues, but if you are traveling on the keys Rubio's (786-412-3108) is probably a good name to have in your book. They provide mobile maintenance on the keys, and while my repair is still only halfway completed (waiting on parts - lugs) these guys seem to know their business.
I would never in a million years have thought carrying an extra set of lugs in my toolkit would be a good idea, but I may be re-thinking that in the near future.
05-19-2014, 10:27 AM
#58
Retired.
, At Large
There is a difference in torque spec between 3/4" and 13/16" hex, as well as stud diameter and wheel type. I have seen some 3/4" hex lugs for Airstream trailers at 90 pounds.
05-19-2014, 11:45 AM
#59
Normal
Originally Posted by GCinSC2
Recently retired and now broke down in the Florida Keys and you want us to help and feel sorry for you.
Let me think about it. Nope, didn't change anything.
Gary
You're bad!
Glad no one was hurt. If this had happened as you were barreling down an interstate, could have been an unhappy ending rather than an inconvenience.
If you have to break down, the Florida Keys are not a bad place to spend some time.....ocean every direction you look, lots of sunshine.
Hope all is resolved soon.
Maggie
05-19-2014, 11:52 AM
#60
Mantua
, Ohio
I know this has been mentioned before but, be sure the torques are checked on all the nuts on all the wheels. You may have another one damaged already. Be careful and good luck. Jim
