Old 05-21-2014, 05:25 AM   #113
Baltimore , Maryland
Originally Posted by Top View Post
I think those wheels are a tad unsightly. I normally don't say anything unless I have something nice to say, but I just want it to be clear that I think those wheels and tires should remain unseen.
I am glad Lance has the stuff to say the truth. I used to, but refrain from saying what I really feel these days.
The blue wall with the white wall and all that blue just make that rim gaudy.
Old 05-21-2014, 06:38 AM   #114
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Random thought...anyone know how a Nascar tire change is done? That process doesn't look very precise...does the wrench they use always tighten to the correct value?
Ha, love it Alumaminum! I never had lugs though with issues like this on my cars- just in my limited experience doing my own rotating etc. I agree though that it should not be so riddled with technicalities.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-21-2014, 03:52 PM   #115
Are these too over the top(no pun intended)?
My shop did not do these rims even though we did change out the axles.
This is a Frank's Trailer Work special. Double silver pinstripes on a black powder coated rim, topped off with a baby moon.
Old 05-21-2014, 04:35 PM   #116
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
love those black rims Frank. All that kind of stuff is a matter of taste of course. Some don't like polished trailers.
How does the powder coating hold up?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-21-2014, 05:02 PM   #117
nilesrob's Avatar
Marietta , Georgia
Images: 12
You can never have too much bling.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 05-21-2014, 05:03 PM   #118
nilesrob's Avatar
Marietta , Georgia
Images: 12
Or on further observation, are those pictures just selfies?
The Slowsky's
WBCCI #1271
Old 05-21-2014, 05:11 PM   #119
you cannot remove yourself from a photo of a baby moon so yes, they are selfless.
Old 05-22-2014, 02:16 PM   #120
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
I'm with you, Frank--understated vintage elegance is always my preference rather than having everything that is possible. But although that is just personal taste, it just goes to show that your taste and mine is better than others'!!
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Old 05-22-2014, 04:32 PM   #121
Gainesville , Florida
If those wheels get to you, come to a TinCan Tourist rally and see some of the outfits there!some real imagination in the trailers, mostly vintage. Great looking. Jim
Old 05-31-2014, 09:00 AM   #122
2014 23' Flying Cloud
Reed Point , Montana
Torque isn't Tension........
Good video, explaining bolt tension.
It explains to me why even with the torque set properly on your A/S your wheel could be loose.
Bigskyrider8 is offline   Reply With Quote
Old 05-31-2014, 09:29 AM   #123
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The wheels in the pictures work for me. Somehow, in my mind "retro" and Airstream go together well.
J. Morgan is online now   Reply With Quote
Old 05-31-2014, 09:38 AM   #124
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I thought the video above was very informative. Does this dispel the common thought of NOT lubricating the threads on wheel applications ???? That's what I was always told but now I'm not so sure ??? Maybe the engineers could tell us.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-31-2014, 10:04 AM   #125
K.C. , Missouri
( This vid has also been posted in another thread. I will throw my comments in here as well )
....and while that is interesting and accurate as far as it goes, it does not tell us the whole story, as it applies to attaching wheels to trailers.
We are generally spec'ed to use "clean, dry" threads and the cone as well.
It would have been interesting to see what results he would have acquired had he taken one of the "slightly rusty" bolts, nuts and washers, wire brushed them, cleaned the threads with solvent and then done up the assembly in the test rig.
I go back to my statement in another thread here about lug studs snapping off, that if we really knew the truth, the studs more likely failed because the assembly was "loose" ( not enough clamping force ), and the studs were subjected to shearing forces. Not because of over-torque ( although that is possible, it just seems less likely to me. Read the bolt specs on what the tensile strength of a 1/2" grade eight fastener )
gmw photos is offline   Reply With Quote
Old 05-31-2014, 10:24 AM   #126
Good point, made by an engineer friend....
That is an excellent video. It addresses the relationship between torque and "tension" which I most typically see referred to as "clamping force".
A single rotary torque specification expressed as a certain number of ft. lb., in. lb., or newton meters has two components: tension or clamping force is one and friction is the other.
The video clearly shows how important the friction component is, even though what we want to achieve is sufficient clamping force.
Manufacturers usually supply torque specifications in two parts: thread condition and numerical value. The thread condition is usually "clean and dry", although "lightly oiled" is occasionally specified.
As the video clearly demonstrates, with a given torque value, altering the thread condition drastically changes clamping force (tension).
And, the reason this is of more than passing academic interest is that the tension or clamping force is what is applied to the threads and shank of the capscrew or bolt, and is what will strip threads, or allow them to loosen depending.
Rear Running Light Wire snapped spat61 Airstream Motorhome Forums 0 06-12-2010 08:10 PM
Vent replacement parts/Shaft snapped Lothlorian Roof Vents, Skylights & Fans 6 11-13-2008 04:47 AM
Door Lock Snapped Off ssolid Doors & Locks 8 02-13-2008 08:08 AM
My Z lock lever "snapped off".. oh my! Director Awnings 7 10-20-2007 09:13 PM
1067 Radio Antenna Snapped Off flamingo-kid1 Audio, Video & TV 0 04-06-2004 09:15 PM
