Old 05-18-2014, 09:24 PM   #43
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Brad, hope you get the drum fixed up quickly tomorrow. Hard to tell from the pictures, but looks like one or two bolt holes on the wheel may be damaged. As suggested by several others, probably a good idea to check the torque on the other wheels. Maybe your mechanic can tell from the remaining stud heads how they failed.
Sorry for the hijack, but this seems like a good time/place to ask.
So, since I'm heading out Thursday for Cedar Key for the first trip on my new Sendels and 16" Michelin LTs, what should I torque them to? Someone on here said JC's spec was 100 lb.ft. That's what they are at right now. I will stop about 50 miles down the road and check them.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-18-2014, 10:23 PM   #44
2014 30' Flying Cloud
Ponce Inlet , Florida
According to my 2014 FC manual 110 ft lb max torque
Sent from my ADR6400L using Airstream Forums mobile app
Beach Bum is offline   Reply With Quote
Old 05-18-2014, 10:27 PM   #45
Thanks Beach Bum. I'll crank them up to 110 before I leave.
S/OS #004
Old 05-18-2014, 10:41 PM   #46
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Attachment 212290
Hi, if Airstream could be more consistent; My owner's manual states that my lug nuts are to be torqued to 110 lbs to 120 lbs. I torque mine at the max 120 lbs. It also says to torque my spare steel wheel to only 90 lbs.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 05-18-2014, 11:27 PM   #47
ottawa (greely) , Ontario
Originally Posted by ROBERTSUNRUS View Post
Hi, yes in some cases, but not when the hub and drum don't separate.
You still just drive the old studs out, hammer them from were the wheel nut was and install them from back side of drum ,you can hammer them in ,but best to use the wheel nut with a spacer under it,and just torque it to specs 120 lbs?then recheck wheel torque first mile then follow normal retorque as per manual .and yes you must take drum off to perform this repair .
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 05-19-2014, 05:49 AM   #48
Baltimore , Maryland
you might notice four broken studs and two empty holes? The two came off and the rim broke the rest off… that's my story and I am sticking to it.
I love these aluminum wheels they use. They keep my shop and many of my competitors flush with body work.
Old 05-19-2014, 06:07 AM   #49
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Originally Posted by Al and Missy View Post
So, since I'm heading out Thursday for Cedar Key for the first trip on my new Sendels and 16" Michelin LTs, what should I torque them to?l
When I bought mine a few years back JC told me 125-130. That's what I've been doing with no problems.
2012 Dodge Durango Hemi/AWD
Old 05-19-2014, 07:15 AM   #50
1981 31' Excella II
New Market , Alabama
Are you saying that the Aluminum wheels have issues Frank? I remember my manual saying something about rims needed to be removed and places with the holes aligned the same way or a wire brush should be used to remove all oxidation from the rim and seating area on the drum. His rim looked clean as far as oxidation.
Perry
Old 05-19-2014, 07:27 AM   #51
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
From what I see in the pictures, it seems that there are witness marks on the wheel and the hub that seem to indicate that the wheel ran loose for a while.
Old 05-19-2014, 10:05 AM   #52
nilesrob's Avatar
Marietta , Georgia
Images: 12
I think the wheel did come loose a bit with two studs (broken off inside) and then the rest sheared off. Had Rubio's out here this morning, and as you would expect they need to overnight the correct studs, so final repair (hopefully) tomorrow morning.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 05-19-2014, 10:45 AM   #53
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Torque specs are different for STEEL wheels and ALUMINUM ones. 110 for Aluminum, I think steel is higher - 125 - but that's memory not fact.
Paula
Old 05-19-2014, 10:51 AM   #54
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Airstream manual calls for 110 lbs torque for aluminum wheels and 100 lbs for steel wheels.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 05-19-2014, 10:58 AM   #55
Yes, but, my (2001) manual calls for 85 on Aluminum wheels. I emailed AS to ask. We'll see what they say.
Al
S/OS #004
Old 05-19-2014, 11:00 AM   #56
TinTin's Avatar
Canmore , Alberta
Al
Could well be that torquing specifications have changed over the years, with new casting techniques for wheels, etc.
Bob and Nancy
Rear Running Light Wire snapped spat61 Airstream Motorhome Forums 0 06-12-2010 08:10 PM
Vent replacement parts/Shaft snapped Lothlorian Roof Vents, Skylights & Fans 6 11-13-2008 04:47 AM
Door Lock Snapped Off ssolid Doors & Locks 8 02-13-2008 08:08 AM
My Z lock lever "snapped off".. oh my! Director Awnings 7 10-20-2007 09:13 PM
1067 Radio Antenna Snapped Off flamingo-kid1 Audio, Video & TV 0 04-06-2004 09:15 PM
