Old 05-17-2014, 10:54 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by J. Morgan View Post
I have replaced lots of wheel studs. They most always will come off with the hub on the axle, sometimes just barely, but there is usually always room....
Someone on this thread said they removed a stud with a drift and hammer.....
Hi, yes in some cases, but not when the hub and drum don't separate.
ID:	212164   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-17-2014, 10:57 PM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Wheel snapped off in the Keys
Lol, yea, that makes a difference.
I concede the point.
The hubs and drums on my trailer are more conventional,
I assumed.....
Old 05-18-2014, 03:17 AM   #17
2004 16' International CCD
Chicagoland , Illinois
That could have been a disaster. Glad you're OK.
Airrogant is offline   Reply With Quote
Old 05-18-2014, 04:31 AM   #18
Gainesville , Florida
Stock wheels or were these 16 inch replacements installed improperly.? Jim
Old 05-18-2014, 05:26 AM   #19
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Recently retired and now broke down in the Florida Keys and you want us to help and feel sorry for you.
Let me think about it. Nope, didn't change anything.
Glad no damage. Good luck and safe travels.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 05-18-2014, 06:01 AM   #20
1981 31' Excella II
New Market , Alabama
I think the wheel was not tightened properly. When the lugs are loose the rim will come off in short order. Most folks think the lugs hold the tire on. Actually the friction between the rim and the brake drum hold the rim on there. The bolts just provide the compression to keep the two surfaces in contact. Bolts clamp two things together. The bolt is not designed to handle shear loads. If the bolts were to tight, you might have one or two bolts that came off. If they were loose like if they did not torque them after getting them snug, then they will come off. You need to talk to whoever put the wheels on.
Perry
Old 05-18-2014, 06:18 AM   #21
Baltimore , Maryland
Aluminum rims right?
Old 05-18-2014, 06:42 AM   #22
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
If the studs were broken due to over-torque, wouldn't that be reflected as a tension failure rather than a shear?
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-18-2014, 07:13 AM   #23
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
In all fairness, it seems logical that wheel studs will break off like that from over tightening, but it is something I have never seen in actuality.
Usually happens because;
1. Loose lug nuts
2, improper wheel pilot for hubs
3. Aluminum wheels using wrong style lug nuts
Over tightened lug nuts almost always result in stripped studs and nuts.
Now if a person were to strip every single stud on a wheel it would get loose and break the studs.
Old 05-18-2014, 07:19 AM   #24
2014 30' Flying Cloud
Ponce Inlet , Florida
We are in Marathon for the next few days. Don't know how much help we would be..... But would come over and give you a hand if it would help. Could always bring some some margaritas and moral support
Sent from my ADR6400L using Airstream Forums mobile app
Beach Bum is offline   Reply With Quote
Old 05-18-2014, 07:45 AM   #25
Totoro's Avatar
Huntington , West Virginia
Sorry for your luck. Better to lose a wheel than have a radial shred on ya.
Totoro is offline   Reply With Quote
Old 05-18-2014, 07:49 AM   #26
r carl's Avatar
Lin , Ne
There is an awful lot of assuming going on here without seeing any pics.
Old 05-18-2014, 08:39 AM   #27
ottawa (greely) , Ontario
Over torqued wheel nuts,just check the rest of our wheels with a torque wrench suspect there all over torque if so replace all wheel studs.
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 05-18-2014, 12:59 PM   #28
nilesrob's Avatar
Marietta , Georgia
Images: 12
See if I can add pics from my iPad...Click image for larger version
Name:	ImageUploadedByAirstream Forums1400439519.764790.jpg
Name:	ImageUploadedByAirstream Forums1400439563.388130.jpg
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Rear Running Light Wire snapped spat61 Airstream Motorhome Forums 0 06-12-2010 07:10 PM
Vent replacement parts/Shaft snapped Lothlorian Roof Vents, Skylights & Fans 6 11-13-2008 03:47 AM
Door Lock Snapped Off ssolid Doors & Locks 8 02-13-2008 07:08 AM
My Z lock lever "snapped off".. oh my! Director Awnings 7 10-20-2007 08:13 PM
1067 Radio Antenna Snapped Off flamingo-kid1 Audio, Video & TV 0 04-06-2004 08:15 PM
