Old 05-31-2014, 12:30 PM   #127
Images: 59
I see the engineer in the video waxed the washer and the threads. Should I have my lugs and studs waxed?
Brazilian?
Old 05-31-2014, 12:38 PM   #128
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The most reliable way to measure proper fastener tightening is by measuring the stretch of the bolt or stud. Unfortunately that can be difficult in the field. Torque is the next best method for field application but as you can see it is far from perfect.
Years ago while working in power plants the large bolts on steam turbines, 6" to 8" dia. and several feet long, had a hole drilled down the center. We inserted heaters to heat the bolt to tighten the nut and then after it cooled we used a micrometer to measure the length. It was time consuming but can you imagine the size of the torque wrench you would need.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-03-2014, 04:23 PM   #129
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Did you get the wheel re-installed?
tsunami is offline   Reply With Quote
Old 06-03-2014, 09:05 PM   #130
nilesrob's Avatar
Marietta , Georgia
Images: 12
Yes we did; nothing writing a healthy check didn't cure. We were very fortunate just the same.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 06-04-2014, 07:18 PM   #131
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Brad,
What is the takeaway message based on your "experience " on this situation?
Not expecting an engineering report, just what you recommend.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-04-2014, 08:22 PM   #132
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Originally Posted by GCinSC2 View Post
Brad,
Gary
Heck yes, mindless inquirers want to know.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 06-05-2014, 08:50 PM   #133
nilesrob's Avatar
Marietta , Georgia
Images: 12
Brad,
Gary
1. I liked the blue wheels better than the black ones.
2. If you have to break down, it doesn't suck to break down in the keys.
3. I now know more (or actually less) about torque than I ever wanted.
Seriously:
1. This forum and its members rock. Thank you. Great counsel, rapid response, fabulous camaraderie.
2. I now own (and will carry) a torque wrench, and will be more diligent about checking torque. Now having said that, I have pulled (multiple) Airstreams for over 10 years and would venture a guess of having towed 50-100k miles, and this is a first experience for me losing a wheel - or for that matter even having a loose lug nut (if that even happened).
3. With all I have learned about torque (some great articles and videos on this thread), it seems like torque, and tension, and clamping values, and all the other terms used, make this whole subject one that probably deserves more attention paid to the subject by everyone who tows, from people and resources far more knowledgeable then me.
I will never know the exact cause of my wheel shearing off, but I sure don't want it to happen to me or anyone else. We were just lucky no one was injured or killed. Perhaps a primer on tightening Airstream wheels would be good general knowledge, but for me checking torque will be on my prep list now.
The Slowsky's
WBCCI #1271
Old 06-05-2014, 08:58 PM   #134
Baltimore , Maryland
and this is why the term, "to each his own" was invented...
Old 06-28-2014, 06:56 AM   #135
GCinSC2's Avatar
I saw it happen yesterday.
Driving home last evening coming out of Charleston on I-26 in the RH lane a contractor's pickup and tandem axle trailer with a scissors platform man lift on the bed. I was in the passing lane still behind the rig and the whole trailer on the curb side sorta jumps up in the air maybe a foot of so, bunch of dust and what looked like dirt flying. Grab some brakes watching for out of control rig. Next the loose wheel was seen bouncing up and down and get this, it continued to roll straight ahead, it somehow didn't do a football tumble. The driver maintained control, slowed and pulled onto the shoulder. The remaining wheel was throwing some smoke, not sure of the source. By this time I was safely past the incident and they safely were off the road. But that trailer jumped into the air when that wheel came off.
S/OS #001
Old 06-28-2014, 10:13 AM   #136
nilesrob's Avatar
Marietta , Georgia
Images: 12
Our trailer may have jumped at the time, but I was napping - had a rope tied to the steering wheel to keep us going straight, so will never know.
The Slowsky's
WBCCI #1271
Old 06-28-2014, 02:56 PM   #137
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
You have airbags, right, Nilesrob?
Skatiero is offline   Reply With Quote
Old 06-28-2014, 04:41 PM   #138
HowieE's Avatar
Princeton , New Jersey
Images: 12
I did not read the complete tread but am I to believe all 5 studs Sheared off or did the nuts just come loose?
I have seen the nuts loosen on the passenger side. That is why Chrysler used to use left hand threaded lugs on that side of the car.
2004 Excursion 4x4
Old 06-28-2014, 05:47 PM   #139
nilesrob's Avatar
Marietta , Georgia
Images: 12
Sheared off, smooth as a baby's bum.
The Slowsky's
WBCCI #1271
Old 06-28-2014, 06:03 PM   #140
HowieE's Avatar
Images: 12
Was that wheel centered by a boss on the drum fitted to the center hole of the wheel or just centered the studs. If the latter it would shear off over time.
The studs are not designed to take the vertical shock loads of the road but rather just to hold the wheel on the drum.
2004 Excursion 4x4
Rear Running Light Wire snapped spat61 Airstream Motorhome Forums 0 06-12-2010 08:10 PM
Vent replacement parts/Shaft snapped Lothlorian Roof Vents, Skylights & Fans 6 11-13-2008 04:47 AM
Door Lock Snapped Off ssolid Doors & Locks 8 02-13-2008 08:08 AM
My Z lock lever "snapped off".. oh my! Director Awnings 7 10-20-2007 09:13 PM
1067 Radio Antenna Snapped Off flamingo-kid1 Audio, Video & TV 0 04-06-2004 09:15 PM
