Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 09-15-2003, 05:10 PM   #1
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
What is your favorite "oops" story?
I have my first "oops" story to share with everyone. I went home at lunchtime last Friday to pick-up the Airstream and dogs so I could leave for my camping trip directly from work. When I arrived back at work, I turned on the water pump so I could draw some water from the kitchen faucet for the dog bowl. Knowing I would be returning in an hour or so to check up on the dogs, I left the water pump on. Unbeknownst to me, the bathroom faucet was turned on slightly -- not enough that I heard water running but enough so that water was coming out. To make matters worse, as a rule of thumb, I always keep the plug in place in the bathroom drain so nothing falls inside it.
Everyone can now certainly figure out what my "oops" is but I will keep going with the remainder of the story details for those that are interested. An hour later, when I came back into the trailer, all I heard was this rrrrrr-whrrrrrr-rrrrrr-whrrrrr noise. In an effort to satisfy the demand of the open faucet, the poor water pump was spinning around endlessly trying to pull water from the now empty fresh water tank! Horrified, I immediately knew what the problem was so wildly started searching for the source of the water draw. This story does end on a good note. The trailer was off-level and leaning lower on the bathroom sink side so all the water from the overflowing sink ended up seeping through the crevice between the back wall and the back of the counter instead of onto the carpeting (and the poor dogs).
I went outside to confirm that the water wasn't stuck inside the innards of my Airstream and found there was water leaking out from every crack and crevice in the belly pan! Later on, when I refilled my fresh water tank, I checked my water pump and found it was working just fine. I was lucky I didn't burn that out in the process.
I can't be the only one out there in Airstream-land who has an "oops" story! Feel free to share your favorite "oops" story here.
yukionna is offline   Reply With Quote
Old 09-15-2003, 06:04 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
How about this...
Ours was on one of our first trips, when we still had our under-powered tow vehicle, which means we arrived to our "perfect" site a bit frazzled. We both immediately jumped out of the Jeep and started setting up camp. I went inside to set-up all the housekeeping things and Rob went about his business setting up the outside things. Well, we leveled the travel on the tongue jack stand which was on somewhat sandy ground. We thought we were good to go except we forgot to place the chocks at the tires and the trailer jumped about a foot off the tongue stand while I was inside! Yikes!!! Scared me to death I though the truck hit the trailer! I sure let the neighbors know I had plenty of four-letter words in my vocabulary!
Fortunately, we've only made that mistake once! Now, no one goes inside until the chocks and the stabilizers are placed...
Shari
Old 09-15-2003, 06:18 PM   #3
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Make sure you unplug shore power...
before you move the coach!
I had only had out 325 motorhome for a couple of weeks and had it plugged into a 100' extension cord that ran across the yard and through the basement entrance of the house we lived in then. Since I don't like having the trailer cord-extension connection exposed to weather, I had the connection inside the cord reel compartment.
A few days later, we were preparing for a trip and I needed gas. So, I jumped in, started 'er up and drove off. I heard something go 'ping' and stopped immediately AFTER pulling the female end right off the extension cord. Then I found out that I had also pulled all of the phone wires out of the wall of the house as I had run the extension cord near the foundation and behind the phone conduit!
I too uttered some naughty words, then went about calling the phone company and getting a new end for my cord. All was repaired the next day, and I learned a fortunate lesson about preparing a motorhome for travel.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 09-16-2003, 05:55 AM   #4
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Not nearly as exciting, but we left for a trip and forgot to deadbolt the main door. Sometimes our latch does not catch. 5 miles down the road we were sitting at a stop light and a motorist rolled down thier window and told my wife our trailer door was open. Horrified, having visions of a new $600 screen door and or $1??? main door, I got out and made about 10 vehicles miss the green light, while I investigated. Whew! No damage done.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 09-16-2003, 10:18 AM   #5
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Ops, Just did it !!!
Using aircraft stripper on the front of AS. Covered the BRAND NEW rock guard with news paper. after 15 min rinsed off the stripper uncovered the rock guard and it has streakes all down the front. Guess the stripper went through the paper !!!!
Wife dosen't know it yet.
Garry
Old 09-19-2003, 04:40 AM   #6
yukionna
yukionna's Avatar
Images: 18
Chock both wheels!
I recently witnessed an "oops" done by a friend of mine. He forgot to chock one side of his Airstream while parked on a slight slope. The tongue "slipped" and the trailer rolled/spun in the direction of the chocked wheel. Moral of this story: be sure to chock both wheels, front and back!
Old 09-19-2003, 05:22 AM   #7
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
On my last trip over Labor Day in South Texas I left the campsite and forgot to retract the awning. A tropical storm which was supposed to miss us decided to dump 3 inches of rain. As I was at a restaurant a few miles away having a good old time it dawned on me that a major storm had settled in and I forgot the awning. I was with my wife's family so I didn't want to panic and make a big deal of it. (margaritas helped with that) After dinner I went back and was horrified, the awning looked like a pretzel, one end up in the air about 10 feet and the other end on the ground. I rolled it up the best I could and decided to survey the real damage in the morning. I checked it out the next morning and was amazed, all it did was put a slight bow in my main tube which Zip Dee says can be straightened, no bent arms, ripped out mounts or torn fabric!! I was able to use it the next day. Those Zip Dees are tough, an SOB awning would have been toast!
Chas
Chas is offline   Reply With Quote
Old 09-19-2003, 09:12 AM   #8
Gordon Watt
Gordon Watt's Avatar
Profile:
"OOPS"
I stopped to overnight while bringing my 31 ft. A/S back from having the rear frame separation repaired.
I left it connected to my truck and put the stabilizers down and slept in the trailer.
The next morning I arose, showered and got in the truck and drove off ------ for a few feet when I realized (too late) I forgot to raise the stabilizers.
Needless to say, they were torn off the trailer and the two rear ones were trashed.
I re-installed the front ones after straightening some minor bends and installed two new ones on the rear.
Does this sound familiar to anyone???? Fess up!
Gordon Watt is offline   Reply With Quote
Old 09-19-2003, 12:49 PM   #9
Mixstream
Profile:
Unhappy
Heading home after spending a weekend in San Diego I pulled into a gas station to fill up. As I was pulling in, I thought to myself these are pretty tight quarters and this is probably a big mistake pulling this 36' motorhome in here but I thought I can do this. Sure enough I got pinned in there and ended up backing up into a pole next to the pump trying to get out. Broke a taillight and tore the rubber strip off of the bumper. It was also emabarrassing as hell!
Mixstream is offline   Reply With Quote
Old 09-20-2003, 07:46 AM   #10
jthew1
Profile:
Wide Swing in Tight Turn - Oops
I traded up from a 26' classic 76 GMC Royale to a 34' classic 86 Airstream 345 in 1990.
The dealer pointed out that they had just replaced the left rear window knocked out by the PO - I'm thinking "what an idiot"! I had a lot of experience driving the GMC and other big rigs and just couldn't imagine how anyone could do this.
Well, on our first trip with the Airstream I got detoured onto a very narrow one-way street in Gettysburg, PA (by the Fire Station, if you've been there). At the end of the street, I made a very cautious tight right turn onto an intersecting street.
At that moment, we heard what sounded like a shotgun blast from the back of the motorhome. I got out, walked to the rear - and guess what? The left rear window was gone and lay in a million pieces, mostly on the bed! It was near dusk and only then did I notice the offending object, a dark utility pole right at the edge of the curb.
Next morning we got up (after sleeping on the sofa), went to a car wash and plunked a whole roll of quarters thru their vacuum. A big piece of cardboard and roll of duct tape served as a make-shift repair and we continued on our journey.
But, it was a pretty humiliating experience cruising down the highway with our injured Silver Bullet. And my passengers (wife and mom) didn't make it any easier on my injured ego.
The dealer was very kind when I returned for installation of the second window within one month at 500 bucks a "pop" (no pun intended), but I bet the techs in the body shop had a good laugh at my expense.
I am still reminded of this at familiy gatherings or when finding another shard of glass hidden in some nook or cranny 13 years later.
O.K., I've come clean, but can't believe there's not someone else out there who's done this - now fess up and let's hear about it.
Jeff
"That rear end sure do make a wide swing in a tight turn"
jthew1 is offline   Reply With Quote
Old 09-20-2003, 08:42 AM   #11
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Here is a picture of me right after I realized that I lost my generator door, because I unlatched it prior to departure.
The full story: Hide and Seek
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 09-20-2003, 04:27 PM   #12
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Ok, I've had at least one stupid near-tragedy. I feel a lot of pressure to take good care of our new toy because it has survived 35 years relatively unscathed. Still, I managed a pretty bonehead move not too long ago.
I leave the trailer plugged in while parked next to the house before a trip, so the battery can get charged up. The plug is in the curbside utility area, which is covered by a big rectangular door. I removed the door and set it on it's end, leaning against the trailer while I unplugged it and reeled the cord back in.
Somehow I got distracted and we went on about hooking up and by the time I went back around to that side, the trailer had moved forward about a foot, just enough to trap the door betwen the ground and a side marker light. It was wedged in there good, dug into the ground about three inches, and so tight I was afraid any movement would pop the marker light off!! I finally had to grab a little shovel and dig out the soft dirt under the door and pull it out that way. End result: no damage to the door, no damage to the marker light or trailer side, and a near heart attack for me, thinking I'd finally left my mark on the poor thing. Now I don't lean the door against the trailer anymore, and we check to be sure all doors are secured before anything moves (it's on the list). Lesson learned.
Stephanie
Our family photo blog
Old 09-21-2003, 09:31 PM   #13
Creampuff
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
O.K. I've got a few!
Due to several incidents of leaving the main door or the bumper storage door open flappin' in the breeze, I now practice the age -old A/S 50 ft idiot check!- pull out 50' then check your site and do the walk around.
While we're fessin', I decided to unscrew the grab handle beside the entry door so I could polish under it and replace the rusted screws- problem being there are NUTS behind the skin that fall down inside-oops! Now what do I do??
The other sin was committed by the p.o. (honest !)- I took some rivits out of the bellypan near the black tank, as I am replacing some of it.I now see moisture dripping from the center area out of a rivit hole! Methinks the P.O. drilled the tank and it only now leaks while the rivit is out!
I'm done (for now) -NEXT!
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 11-30-2003, 07:50 PM   #14
jthew1
Profile:
50' Idiot Check
Oh man, 50' ?, the shore power cord won't stretch anywhere near that far!
I've been a motorhome owner for over 20 years and just couldn't imagine doing this. But, am now a member of those who HAVE driven away hooked up, versus those who WILL someday. No major damage, except to my aging ego.
C'mon, this is my second post to the "Favorite Oops" thread. With 3,600 members now, can't believe there are not some more good stories to be told. This ought to be the longest thread on the Forum, so let's get it going again.
Regards,
Jeff The Idiot
Favorite Jerry-Rig? Dave Cole General Repair Forum 52 12-08-2007 12:00 AM
Brake Horror Story Mike76251 Brakes & Brake Controllers 4 10-06-2003 11:41 AM
My Refrigerator, RIP, A Real Sad Story dmreilly10000 Refrigerators 10 10-25-2002 07:39 AM
Very interesting story/ back pack FrankR On The Road... 2 08-31-2002 08:29 PM
The Junkyard Wheel Story Inland RV Center, In Wheels 1 04-10-2002 06:04 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Frie
