Old 11-29-2014, 08:01 PM   #1
Texasmommy's Avatar
2015 22' FB Sport
Paradise , Texas
What was that noise?
Just spent a wonderful week camping in the new AS at San Augustine COE park in the Texas piney woods All went really well (especially the campfire Thanksgiving turkey!) but we were awakened early this morning by a loud bang. At first I thought it was just an acorn falling on the roof, then heard the same sound again about an hour later. Sounded like a loud pop coming from the front left side (near the water heater maybe). The water heater was not on. Propane was on but furnace wasn't running at the time. It happened again after we woke up and it was definitely not acorns! Sounded almost like metal popping. Any ideas what could have caused the sound?
Texasmommy is offline   Reply With Quote
Old 11-29-2014, 08:19 PM   #2
2007 22' International CCD
Some AS units have an issue with the bellypan 'tin canning' when temperature or stress in the belly pan changes. There are some other threads on this issue.
rmkrum is online now   Reply With Quote
Old 11-29-2014, 10:04 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Was anyone moving in the AS at time of the sound? Was it a metallic sound or percussion?
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-29-2014, 10:06 PM   #4
Texasmommy's Avatar
2015 22' FB Sport
Paradise , Texas
Nobody was moving. We were asleep the first time it happened. It was a loud pop, not ringing or rumbling.
Old 11-30-2014, 05:07 AM   #5
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Sometimes the Aluminum skin on the outside will change --or as it changes temp, will pop. Just depends on your skins age I guess. But thats what this one does - and not all the time...Just depends on the weather outside.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 11-30-2014, 06:56 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If the sound was coming from near the water heater, it could have BEEN the water heater making that sound. Pressure relief valve is one possibility. Another possibility is heat from the water heater cause the "oil-canning" effect that others described. After all, the water heater comes on and goes off according to the thermostat, so there is heating and cooling happening all the time.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-30-2014, 08:02 AM   #7
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Try leaving water heater off during the night. As a routine we always turn ours off and the first person up turns it back on. We sleep better (No jet sound) and save propane.
knunut is offline   Reply With Quote
Old 11-30-2014, 08:17 AM   #8
Texasmommy's Avatar
2015 22' FB Sport
Paradise , Texas
We never turned the water heater on. Just the furnace, but it wasn't running at the time.
Old 11-30-2014, 08:19 AM   #9
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
The OP said the water heater was not on.
Ahab is offline   Reply With Quote
Old 11-30-2014, 08:29 AM   #10
knunut's Avatar
2007 20' Safari
Missed that "reading class" and some other one .
Old 11-30-2014, 09:42 AM   #11
Missed that. Thanks for the correction. Hopefully that's my only mistake for the day! (But law of averages says it isn't, darn it!)
WBCCI #1105
TAC LA-4
Old 11-30-2014, 10:37 AM   #12
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
If the sun was overhead enough to beat on it in the Texas warmth I would look to the aluminum flexing. Overnight cold on one side and bright sunlit warmth on the other. Check around to see if any rivets may have popped. Hopefully nothing more than a new trailer flexing it's skin a bit. We did not get our trailer NEW so we've not had such experiences.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-30-2014, 10:43 AM   #13
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Another reason to sleep with ear plugs.
Ken
Old 12-01-2014, 08:42 AM   #14
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
As the sun comes up and the temperatures increase the trailer makes popping sounds as the aluminum is heating up and expanding.
My wife will ask, "What was That?"
I'll reply, "Nothing, really. The sun is warming up the metal and it is expanding."
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
"Whirring" Noise in the Driveline at Speed swebster Airstream Motorhome Forums 20 08-15-2003 05:57 AM
Noise dry camping ChrisAich 2002 - 2005 International 24 07-28-2003 06:58 AM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 06:23 AM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 04:41 PM
