Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 12-01-2008, 04:59 AM   #1765
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Regular $1.71
Diesel $ 2.71
Towed home from the mountains yesterday - 16.2 MPG in the Diesel
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 12-01-2008, 07:55 AM   #1766
Phantom's Avatar
Profile:  2007 19' Bambi
Delton , Michigan
Images: 12
Phantom & Bunny - Mich to FL
Hi All Fuelish Airstreamers...
Gas is what it is.
We were all committed when we bought our trailers and decided to travel!
We left MI on 11/12... are now in Savannah.
2007 19' Bambi Safari and 2005 Toyota 4-Runner V-8
Averaging 14.4 mph on regular.
Gas (regular) has been around $1.70 most of the trip.
Low was $1.65... high was $1.85.
I'm just thrilled that its not still $4.50 like last summer!
I never would have imagined it would be this low
for our first 6-month-long winter trip. Bonus!
I am very happy and thankful.
I did predict to a friend that I thought oil would return
to below $50 a barrel after it spiked to $1.47.
So glad that it has.... probably won't stay there for long...
We budgeted for gas at $3.30 x about 300 miles per week for the trip.
We've traveled a lot more than that thus far...
needing to be in Orlando by 12/5.
2400 miles so far.... the miles will taper off after Christmas
as we slow the pact of our travels.
If the prices stay where they are,
we'll be well under budget as the weeks go by.
Happy trails to everyone...
Hope to meet some of you on the road some day.
Phantom
Phantom is offline   Reply With Quote
Old 12-01-2008, 08:31 AM   #1767
Larry in MO's Avatar
Profile:  1957 22' Flying Cloud
Lone Jack , Missouri
Images: 27
Originally Posted by ROBERTSUNRUS View Post
. And I stated that all my vehicles require Premium fuel as listed:
2000 Lincoln Navigator..............Tow Vehicle..................Premium fuel
2005 BMW X-3.........................wife's car.....................Premium fuel
2004 Aprilia Mojito Custom 150....Motor scooter...............Premuim fuel
1959 Ford Galaxie.....................hopped up 292..............Premium fuel
I bought a 2006 Nissan Maxima a couple of years ago. The salesman (who seemed more honest than most) made sure I understood that the vehicle used premium gas. He went on to say that the car would perform the best on premium but regular would work fine unless the car was pushed really hard. Ok, I thought, a car salesman at work.
A couple of days later I spoke w/ a GM tech whom I've known for years and I truly trust his ability. He said the same thing--regular (87 octane around here) is just fine for the newer computer operated "premium" vehicles. He related that some consideration must be given for towing heavy loads, racing, and other performance activities but, as a rule, 87 is fine and will not hurt the engine. The computers retard the timing slightly to adjust for the lower octane so no knocking or pinging. His opinion is "slightly less mileage but not enough to buy premium".
Your mileage may vary. Any modern day computer mechanics with an opinion?
Larry
"Turleen", the '57 Flying Cloud
Lone Jack, MO
Pop.528
"You better learn it fast; you better learn it young"-John Fogerty
Larry in MO is offline   Reply With Quote
Old 12-01-2008, 09:00 AM   #1768
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Larry
I have never heard of a GM PCM that can determine what grade of gas you are using. If the OM recommends 87 then that is what you should use and visa versa. Using premium when regular is recommended can actually degrade performance due to the difference in burn rates.
There are aftermarket programmers that allow you to change the parameters for increased performance etc. Some settings do require using 97 octane.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 12-01-2008, 11:09 AM   #1769
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
02-23-2003, 07:07 pm
http://www.airforums.com/forums/show...6&postcount=45
Over 5 yrs ago and, I reported that diesel was 1.77$ then..
Yesterday, it was sighted at 2.85$
Last I heard the price of crude oil was at the level it was 5 yrs ago~!
Something is fishy here..
Robert Cross, I agree..
Reg today 2.39 News reports that WNY is the highest in the Country. NY att general "looking into" the problem. We are within two cents on the wholesale cost, sump'n don't add up
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-02-2008, 09:01 PM   #1770
mrmossyone's Avatar
Profile:  1975 Argosy 24
Collierville , Tennessee
That's an easy one. The demand has increased by more than the supply.
THanks, I'll be here all night.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
mrmossyone is offline   Reply With Quote
Old 12-03-2008, 01:18 AM   #1771
Ifihadtime's Avatar
Profile:  1981 27' Excella II
Lynnwood , Washington
I'm not a mechanic but I did sleep at a ........... never mind
If an engine was designed to run on 92 octane then it would make since to use it. The higher the octane the harder it is to ignite, higher performance engines generally have higher compression requiring the higher octane. He is technically correct the computer will sence the knock of lower octane and retard the timing but probably not enough to eliminate it during acceleration or climbing hills. If there is pre-ignition over a prolong period it could harm the engine.
As long as were at it the same holds true for an engine that is designed to run on 89 octane, switching to a higher octane has little to no benifit except to the oil companies That's my take on it, anyone else?
Ron
81 Excella II "McTwinkie"
I am always doing that which I can not do, in order that I may learn how to do it.
Ifihadtime is offline   Reply With Quote
Old 12-03-2008, 02:44 AM   #1772
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Wrong grade of fuel.
Hi, [short version] Using a lower octane fuel will cause spark knock [pre-ignition] and this breaks pistons. The knock sensor will retard the timeing some, but will only get you by in a pinch. [not recommended] Using a higher octane in a modern car [versus a points/condensor/carbureted old car] does nothing for it because higher octane burns slower and with my personal experience my car lost 4 miles per gallon while burning 92 octane in a 87 octane car. When all else fails, read owner's manual.
Back on topic, no new, or lower fuel prices to report today.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 12-03-2008, 04:43 AM   #1773
balrgn's Avatar
Images: 74
Diesel $2.69
Regular $1.73
Member of VAC
www.balrgn.com
Old 12-03-2008, 10:22 AM   #1774
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
$1.69 in Cory Colorado
I paid $1.58 at safeway in Delta with my discount... YEAH
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 12-03-2008, 02:19 PM   #1775
Profile:  1965 26' Overlander
Arlington , Tennessee
Bout time
Kroger gives a $.10 discount with qualifying purchase Paid $1.399 today.
Cottonboll is offline   Reply With Quote
Old 12-03-2008, 02:22 PM   #1776
U.S.Navy Retired
Safari-Rick's Avatar
Diesel: $2.43 a gal.
Unleaded: $1.83 - Mobile Oil Co.
Long Beach/Lakewood CA......
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 12-03-2008, 02:46 PM   #1777
Profile:  Currently Looking...
Banff , Scotland
Here in Scotland our diesel is the equivalent of USD 6.54 and our prices have dropped!!!
JanB is offline   Reply With Quote
Old 12-04-2008, 10:35 PM   #1778
mrmossyone's Avatar
Cottonbol beat me to it, just down the street here in Cooterville, TN., USA reglur was a buck39 and falling. I'm still looking for 98 cent.
Heinlein
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 05:35 PM
Trip report (fuel filter issues) PeterH-79MH Airstream Motorhome Forums 10 08-01-2003 06:57 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 11:16 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 12:11 PM
fuel pressure PeterH-79MH Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 09:40 PM
