Old 04-29-2003, 08:44 PM   #1
working's Avatar
1967 22' Safari
athens , West Virginia
Rivet weight chart
Looking for site that shows the dry weight of AS's. I know I've seen it somewhere... As I rememeber my unit (67 Safari) runs about 3200 with the tongue at 10%? Help me out folks, Need to buy a WD hitch before I pull this summer. Need to get the right size. 500lb bars is my thought.
working is offline   Reply With Quote
Old 04-29-2003, 09:00 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Weight Chart
Greetings Working!
Welcome to the froums and the world of Vintage Airstream ownership. The information that you desire can again be accessed at the Airstream corporate site at its new address found below:
Airstream Empty Weights, Ball Heights, Etc.
I had been looking for this information for some time as it was displaced when the Airstream corporate site was reconfigured.
Based on my experience with my '78 Argosy Minuet, I suspect that the 500 pound bars should be nearly ideal for your Safari. The 400 pound "light-weight" bars might also be a possibility as well. I know the hitch weight on my Minuet runs between 410 and 425 pounds (20' with total weight of approximately 3,250 pounds).
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 04-29-2003, 09:23 PM   #3
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
weight chart/missing years
It's odd that there's no listing for '56, 58, 59 and 60. I thought i found the weight on my former '60 Overlander (3750) there some time ago but I guess not.
Rog0525 is offline   Reply With Quote
Old 04-29-2003, 09:37 PM   #4
working's Avatar
1967 22' Safari
Rivet
Thanks overlander64.
Shows the dry @ 3450 with tongue of 405. I think that the 500lb bars will be a little light once I'm loaded. The water tank is forward and my unit has a hitch mounted spare(possibly orginal & included in 405?) Will check the next available bar weight and make my choice with my new knowledge.
so it goes...
Old 05-02-2003, 12:03 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Rog0525,
I printed off a copy of the weights last year and after looking at them again, I do not see those years listed for your Overlander either.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
weight distributing bars/trunnion bars teutonik Hitches, Couplers & Balls 2 12-04-2003 06:58 AM
Dry weight variances Moonshot On The Road... 1 09-11-2003 08:06 PM
30' 70th Anniversary Edition Weight Dusty601 1997 -2001 Excella 1 09-01-2003 04:33 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 02:48 PM
