Old 10-17-2015, 12:20 PM   #1
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
Weather map online
FYI , I lately have come across an online weather reports site without any of the ads. etc.. Would be assist to anyone traveling or just want to get to the real weather without all the garbage advertising that seems to plague web sites today .
Check it out what do you think, just dial in any location
Hourly forecast for New York (United States) – yr.no
You can dial in your places and see the full meteorological map on temp, winds , precipitation etc. On the map it gives you a 48 hr. window .
About them ;
Norwegian Meteorological Institute
MET Norway is the meteorological service for both The Military and the Civil Services in Norway, as well as the public. Our mission is to protect life, property and the environment, and to provide the meteorological services required by society.
Laurence
LAWBC is offline   Reply With Quote
Old 10-17-2015, 12:31 PM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . good one, thanks...... Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 10-17-2015, 12:58 PM   #3
Zil
egg harbor city , South Jersey
Fine for the major city, maybe. I use this. Just plug in a zip code. National Weather Service
Zil is offline   Reply With Quote
Old 10-17-2015, 01:54 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Weather Bug app shows a map of where your are that can be expanded to the whole country. It shows the last 20 minutes of weather movement so you can get an idea of what is coming. Hourly forecasts for 10 days. I can save dozens of locations across the country, each with a pin on the map, so I can look out hours or days ahead to see what to expect as I travel.
2004 Excursion 4x4
Airstream Forums Map!! Rivetedude Our Community 137 04-27-2006 02:47 PM
Really neat fridge door 1963 World map RichardT Refrigerators 4 05-08-2005 06:24 PM
State by state map displays-where do you maxandgeorgia On The Road... 9 05-31-2004 12:14 PM
need plumbing map for water pump silverbullet Water Heaters, Filters & Pumps 1 09-22-2002 09:13 PM
DeLorme Map Print Pack Pahaska On The Road... 0 08-17-2002 11:37 AM
