Old 01-17-2011, 11:59 AM   #1
FullTimin2HI's Avatar
2004 28' International CCD
Palm Beach County , Florida
We got it!!!
Just drove 2600 miles round trip and picked our used beauty! Couldn't sleep in our new (to us) Airstream on the way home, LP leaks somewhere... Anyone know if the A/C will run off 15 amp? or must it use the full 30 amp? We are back home in South Florida and are resting... 5 days roundtrip is way too much road time... Here we are taking delivery of our 2004 International 28!!! I'll sign back on in a day or two after we have caught up on some sleep with some more photos! Couldn't wait to show her off here!
FullTimin2HI is offline   Reply With Quote
Old 01-17-2011, 12:05 PM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Better to have 30 amp power to operate the air conditioner. The compressor can be damaged when the amperage is low.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 01-17-2011, 12:08 PM   #3
MO Airstream's Avatar
Springfield , Missouri
Congrats!!
MO Airstream is offline   Reply With Quote
Old 01-17-2011, 12:12 PM   #4
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Nice purchase.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 01-17-2011, 12:57 PM   #5
withidl's Avatar
2002 31' Classic
Houston , Texas
The AC draws about 14-15 amps when running, but draws 16-18 amps at compressor start-up. Your converter (AC to DC) draws several amps also, so your amp draw is about 18 if no other draw is there (like the refigerator).
That being said, I run the AC on my 2002 31 foot ASCL from a 20 amp outlet just 3 feet from the 20 amp breaker using a double prong adapter (plugs simultanously into both recepticles with a 30 amp recepticle for the 30 foot umbilicle from the Airstream); thus due to the short run of about 33 feet my current/volt drop is minimal and my AC runs without any problem.
withidl is offline   Reply With Quote
Old 01-17-2011, 02:13 PM   #6
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
Congrats.......SUPER looking unit.......I'm sure it will be a quick fix on the LP leak, it usually is!
62bam is offline   Reply With Quote
Old 01-17-2011, 02:22 PM   #7
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Congrats!! She's a beauty.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 01-17-2011, 02:22 PM   #8
Kevin245's Avatar
Congratulations on the new rig. Sounds like quite a trip. As for the AC question, the general consensus is not to run it on 15 amps.
Kevin
Eleanor Roosevelt
Old 01-17-2011, 02:23 PM   #9
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
Aluminum-the gift that keeps on givin!
Congratulations and bravo for the 2600 miles. Your smiles are about the same as ours when we got our 1968 Globetrotter. Go slow, read this forum and the more you fix yourself the better you will feel. See you on the road.
Randy-CA
Randy Gates is offline   Reply With Quote
Old 01-17-2011, 02:30 PM   #10
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Congratulations!! Definately go with 30 amp if possible. It will help protect that investment. We look forward to more pictures!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-17-2011, 02:32 PM   #11
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Congrats on your new Airstream. It's beautiful. Can't wait to see more pics.
NicheVintage is offline   Reply With Quote
Old 01-17-2011, 02:55 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
30 amps for sure. It's not worth the risk of damaging the compressor motor. It's not so much the current (amps) drawn as it is the voltage drop. If it gets below 110 volts, serious damage can occur.
Old 01-17-2011, 03:24 PM   #13
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Looks like lots of fun in the near future. Consider coming to the Beachstream rally in September, its only 600 miles from your location!
Greg
Roadtoaster is offline   Reply With Quote
Old 01-17-2011, 03:30 PM   #14
blmitch5's Avatar
Olathe , Kansas
My better half decided to run the AC on 20 amp and melted the adapter. AC was fine but geeze! The heat strip works fine on 20 AMP but no AC.
