Old 12-15-2009, 04:08 PM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Water thief proof water hydrant
A while ago I was at Cleary Lake campground in Prior Lake, MN. There are some group campsites with electric only we were using.
There was only one place to get water and they'd gone to great lengths to be sure there was absolutely no way to attach a hose. The hydrant was a 12" square heavy steel box with a valve lever, and an outlet about 12" from the ground. The outlet was built into a sort of angled ledge so that there was no way to get a water thief on there.
I've never seen anything like it before or since.
Old 12-15-2009, 09:00 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Guess they don't want you (us) to fill tanks with a hose! I hate when that happens. We carry a 5-gal water container to transfer water to the trailer's tank if we need it...just far circumstances like this.
TB & Greg and Abbey Schnauzer
#3954
Old 12-18-2009, 12:09 PM   #3
vctrhdgs's Avatar
Seattle , Washington
I realize that some campgrounds may not want to give unlimited access to their water supply, however, as a camper you are going to need water (even over electricity).
I find myself confused by the idea of not giving campers access to the water supply.
I haven't seen the exact set up your talking about... but I have seen others in my travels.
Do they not want folks in their campground?
Hmmm
Victoria
vctrhdgs is offline   Reply With Quote
Old 12-18-2009, 12:23 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Time to buy a 2nd pump. I found a little pump that can be run by an electric drill. I use it to pump water from my shower into the toilet and black tank when I'm boondocking. I also can use it to run water in a bucket through the black tank rinser when I'm rinsing the black tank (normally I use a hose with a backflow preventer, but some campgrounds are paranoid about backflow into their white water. Fill a bucket with clean water, hook up the pump exhaust to the tank washer and turn on the drill! Voila.
If this becomes more common - I'll spend $15 more for a "White water pump".
Paula
Old 12-27-2009, 04:24 PM   #5
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I can see why public CG's want to make it hard to get water via a hose in the west. Water is scarce here. If the CG is in a desert, it's very scarce. And desert includes the high desert where piņon and juniper grow. It can be a desert without sand dunes and much of the west is high desert. You might not want to drink that water even though it's "potable". Sometimes it tastes downright nasty.
Why they do that in well watered areas is beyond me other than a one size fits all attitude.
Gene
Old 12-27-2009, 04:38 PM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
WE carry a second shur flo pump with a hose on each end. Have a cigarette lighter plug on it and an outlet installed in a side compartment.
I don't mind carrying the water to the trailer, but the pump means we don't have to hold the jugs up to fill, just pump it in.
We have tried the drill pumps, but had several fail. They don't seem to be very tolerant of running dry, even for a few minutes
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 12-27-2009, 05:01 PM   #7
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I think I ran into one of the devices Jammer is talking about. It was at a group campsite at Baker Park, west of Minneapolis. I was confused by it.It must be some cost saving device in our park systems.
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 12-27-2009, 05:22 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Mmm... Baker Park has a good reputation. I feel like my location gives me a jumpstart on Twin Cities traffic. But for that silly little anachronism, "the reservation" ... But I've actually considered Baker Park; just haven't gotten there yet.
Any pictures of these water thief obfuscation devices?
This is one of the reasons I'm rarely without a dedicated 5 gallon plastic jerry can for toting water. Mine says "diesel" on the side but our dishwashing knows better....
5 meter Langford Nahanni
Old 12-27-2009, 06:43 PM   #9
Images: 59
Both of these campgrounds are part of the Three Rivers Park District. The District is one of the best organized and run independent park districts in the US, with assets of $170,000,000 and twenty sites covering almost 27,000 acres within 30 miles of Minneapolis.
I'm gonna assume they put in "cheater-proof" hydrants to prevent backflow and cross connections, not to keep you from stealing more than your fair share of water.
Old 12-27-2009, 07:14 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have seen those before, the supposed reason is to keep some people from running a hose to the faucet and using for their use and others not being able to get water. I have had this happen at a state park in NC. The people were not very nice when someone reported it to the rangers, after dark they hooked it back up. Someone cut their hose in about 4 pieces later that night.
Aaron
WBCCI #XXXX AIR #2495
Old 12-27-2009, 08:52 PM   #11
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There is one thing I like even less in campgrounds. Those TP dispensers that will only let you get 3 or 4 sheets at a time.
Old 12-28-2009, 03:26 AM   #12
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
That is why I take my own roll with me...ALWAYS I have also had one to many experiences where there was no TP or someone thinking they were being cute had wet it down.
Aaron
Old 01-05-2010, 04:28 PM   #13
Aaron
uh... oh... Well I COULD top that story, but discretion and good taste have momentarily risen to the surface of my brain... so no funny but awful story.
Paula
Old 01-05-2010, 07:26 PM   #14
Jammer, we'll start asking you to bring along an easy-to-carry camera to post photos back here. We'll provide the hack to show 'em the error of their ways....
1969 Overlander Int'l water question - filter on outside water hook up? edmund015 Water Heaters, Filters & Pumps 3 08-20-2009 10:30 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
1974 safari water leak when hooked to town water Jasper_pilot 1974 - 1979 Safari 8 06-09-2007 02:18 PM
skin damage by hydrant Astrodokk Ribs, Skins & Rivets 7 12-20-2006 10:00 PM
Anti-Thief 53flyingcloud Off Topic Forum 0 03-27-2004 03:38 AM
