Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 07-14-2004, 01:57 AM   #1
Profile:
Rivet Want to buy diesel 4x4 for $5,000 or less!
I am looking for a diesel 4x4 Suburban or crew cab (4 door) pickup truck, in good working condition. I want a vehicle, model year '95 or older, which I can pay $5,000 or less for, in cash. I also would consider a trade for my 1995 4x4 Chevy Suburban (gasoline). I am located in Oklahoma. If you have what I am looking for, or any leads for me, please contact me at WaterSpryt@aol.com.
WaterSpryt is offline   Reply With Quote
Old 07-14-2004, 11:07 AM   #2
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
No offense but for what you want to spend I'm not sure you want the deisels in those years. I'm a Chevy guy and I want nothing to do with the 6.2 for towing especially in the mountains. No Trub and elevation and it's an absolute dog. The 6.5 was not a great motor. They are Prone to the cranks failing.
The really good Ford Powerstrokes started in 95.
I think hands down the best Diesel tow rigs are the Powerstroke fords with the 7.3's and the Cummins Dodge trucks with 5 speeds. The Dodge Auto has issues. That's going to be the only ones even close to that price range. Then New Duramax diesles are good but no old enough to be any where near that price range.
That was about my ideal price range and that's why I iended up picking up a very clean low mile 454 Suburban beacause I didn't want those diesels. Hate the MPG but otherwise happy with the vehicle. I'd stick with the Brub you already have. Maybe regear if it has some issues with the weight. Most 4x4 half ton burbs are 3.54 gear I think. If you went to a 3.73 or a 4.10 it would be a good puller and not really get much worse MPG. If it has the 10 bolt rear I would replace it with the Semi Floating 14. If you look you can buy them for $200 if patient. That's cheaper then the regear and it would be a bolt in in most cases.
Good luck.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 07-21-2004, 02:21 PM   #3
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I am driving a 92 Dodge cummins 4x4 5 spd in excellent condition 125K miles on it. If you can find this truck it would be in your price range.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 07-21-2004, 03:00 PM   #4
Craftsman
Guest
Profile:
Posts: n/a
I find myself looking for the same truck. I just bought a 31' 1976 Sovereign and now I need sutiable tow vechile. My thoughts are to buy about a 95 Ford 7.3 Powerstroke for around $5K cash. Is this realistic? I talked to a guy the other day that had 237 thousand miles on a74 F250, and he said it was still going strong.
Jack
Old 07-21-2004, 03:53 PM   #5
Coastalview's Avatar
Profile:  1978 29' Ambassador
Carmel , California
Images: 12
Airstream Registry
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
Finding a suitable diesel pickup in that price range,is going to be hard to find. I would recommened the first generation Dodge cummins,with the 5 spd. only. Like 59toaster
stated,the dodge automatics are troublesome.You may find a pre powerstroke Ford with the non turbo charged 7.3 indirect injected engine,for the price range your looking for.There are aftermarket kits available to turbo these engines when financies become availible,and can achieve decent torque increases if needed,other wise the stock 7.3 motor will pull fine,just plan on accelerating prior to climbing any grades. Good luck on your search,Jeff
AIR# 649
NorCal Spring Rally, Casini Ranch, April 9-11 2010
NorCal Spring Rally, Casini Ranch April 9-11, 2010
NorCal Fall Rally, Jackson Rancheria, October 15-17 2010
NorCal Rally, Jackson Rancheria, October 15-17, 2010
Coastalview is offline   Reply With Quote
diesel truck-----what to watch out for? Ghost Rider On The Road... 24 06-29-2004 06:51 PM
Diesel Mtrhm Data 1995 - 2003 phred Airstream Motorhome Forums 0 02-13-2004 06:40 PM
Poll: Isuzu Diesel MH - Would you do it again? 1985air345 Mechanics Corner - Engines, Transmission & More... 1 11-10-2003 06:06 PM
Diesel truck owners FrankR Off Topic Forum 3 11-23-2002 05:35 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
