Old 05-22-2014, 07:01 PM   #1
2012 25' Flying Cloud
Tacoma , Washington
Use or store
Can never remember this if the trailer is not hooked to shore power which setting should be used on the panel
BigGrey is offline   Reply With Quote
Old 05-22-2014, 07:15 PM   #2
richw46's Avatar
Lexington , Kentucky
Can you provide more description? What panel are you asking about?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-22-2014, 07:28 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Use or store switch - put it on store for short periods of non-use when it's not hooked to power.
However, there are still a few phantom draws - the CO detector is one I believe. Remove the battery or batteries if you're putting it into storage for an extended time. Keep the batteries in a cool dry place. Consider a charge minder to keep them topped off too.
Paula
Foiled Again is online now   Reply With Quote
Old 05-23-2014, 06:15 AM   #4
Tacoma , Washington
Paula, Rich
Thank You for your replies any idea the draw that the CO Detector takes ? Initial check of the battery was close to 100% now after 3 weeks with no shore power down to about 80% does this sound about right ?
Thank You
Old 05-23-2014, 06:39 AM   #5
richw46's Avatar
OK, I'm on board now
Down 80% in 3 weeks sounds like something is drawing off power. My CO and smoke detectors use 9 volt batteries, not sure about the propane detector.
I would think anytime you aren't actively using the trailer the switch should be in 'store', that's where we keep ours. That should cut off all power in the trailer. There could be other direct connections on the batteries, like the trailer tongue electric jack. You can also lose power if your battery terminal connections are dirty. Check those to make sure they're clean and have a light coating of grease.
Like Paula says, if you take the batteries out, you want to make sure they're always charged. You want a charger that turns off after the charge is reached, not trickle, or you can monitor the charge and disconnect when they are full, checking every couple of weeks.
How old are the batteries?
What type? Do you know if they are AGM or standard deep cycle? Are there caps on the top to allow you to check the acid level or are they sealed?
-Rich
Rich & Yvonne
2004 4Runner SE
Old 05-23-2014, 07:37 AM   #6
Tacoma , Washington
Morning Rich !
Batteries are less than a year old and clean,
"You want a charger that turns off after the charge is reached, not trickle, or you can monitor the charge and disconnect when they are full, checking every couple of weeks"
I have a Battery Tender that I use for charging
The Batteries are interstate Deep cycle They are not AGM, I do have access to check the fluid levels The trailer itself is a 2012 Flying Cloud
I will check the switch and make sure it is set to 'Store' as well
Thank You
Old 05-23-2014, 08:40 AM   #7
2016 30' Classic
Erie , Colorado
The current LPG detector is direct to the battery. The Use/Store switch has no effect.
Your LPG detector is wired directly to your trailer
battery and incorporates a 1 amp, in-line fuse. It has no
internal battery backup. In normal stand-by mode, the
LED indicator will be green.
So there is a battery draw, less than 1 amp. I tried to find a manual for the unit on the Atwood site but didn't find anything with more detail on the draw. 3 weeks would draw it down. 80% level not sure.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 05-23-2014, 08:56 AM   #8
Tacoma , Washington
Thank You Gary
Old 05-23-2014, 09:57 AM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
Paula, Rich
Thank You
The propane detector will typically draw 0.1 to 0.2 amps.
Old 05-23-2014, 11:07 AM   #10
Tacoma , Washington
Thanks Jammer,
Sorry for All of the rookie questions but where is the propane detector and exactly what does it detect level of the propane, the refer when switched to propane ???
Old 05-23-2014, 11:37 AM   #11
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
You should find the propane detector low on the wall. Ours in on the bulkhead wall adjacent to the refrigerator. Directly opposite the stove in our configuration. It's about 3"x4" or so and has a flashing light. It will beep if propane is detected. If I recall there is a re-set on it. One time we came home to find it beeping so something set it off. But only 1x.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-23-2014, 12:03 PM   #12
Tacoma , Washington
Ah got it so it detects a leak of propane
Thank You
Store/use switch and charging B25guy Electrical - Systems, Generators, Batteries & Solar 21 07-05-2010 02:52 PM
Newbie electrical questions -- "Use" and "Store"? jjboone101 Batteries, Univolts, Converters & Inverters 8 08-27-2009 09:44 PM
Store/Use breaker tripping Roadmeister Electrical - Systems, Generators, Batteries & Solar 3 06-26-2007 08:18 AM
"Store-Use" SWitch Rleirer 2003 Safari 10 04-17-2003 02:07 PM
