Old 02-18-2015, 04:48 PM   #29
MontyV's Avatar
1994 34' Limited
Salem , Oregon
I take as much speed as I reasonably can paying more attention to the engine work load and temperature. Towing over the coastal range and along the Oregon coast there were times that 35 was the best I could comfortable do.
MontyV is offline   Reply With Quote
Old 02-18-2015, 07:19 PM   #30
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Uphill MPG and speed
The only hill I haven't been able to take at 65 or 70 is the 8% pull just south of Globe, AZ on hwy 77.
I like to run the speed limit.
MPG is what it is, hills don't make much difference with my rig and driving style, if I drive under 60 I will get about 11, if I go faster I will get as little as 9.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
J. Morgan is online now   Reply With Quote
Old 02-18-2015, 07:54 PM   #31
2014 27' FB International
Clearwater , Florida
A lesson I learned is buy enough tow vehicle. Tow capacity is rated in pounds. Air drag happens and at speed takes horsepower to overcome. Putting this together, divide trailer gvw by TV tow capacity equals a percentage of capacity. In my case 2014 International 27FB est. gvw. 8000#, 2015 2500HD Silverado 6.7L Duramax 14000# tow cap. 8000÷14000= .578. My TV is entirely capable of towing at ant speed anywhere. Towing I get 9-12 mpg. My previous TV 2011 1500 5.3L 9600# capacity 8000÷9600=.833 towing mpg 5.5-8. The biggest difference is overall towing confidence. Up hill, down hill any speed, safe confident secure.
ChuckFeldt is offline   Reply With Quote
Old 02-19-2015, 04:55 AM   #32
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Speed & MPG, not that relevant.....2000rpm,(63mph), is our 'sweet spot' when toeing loaded, barefoot I don't sweat it.
Uphill, downhill matters little.
MPG is a secret, you wouldn't believe me anyway,
Old 02-19-2015, 10:36 AM   #33
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Sodbust View Post
Hard pulling I lock my trans in 4th gear if I can.. Reason,, 4th on my pu is direct and the power flows in and out without any clutch packs turning.. With that along with my 4-1 gearing limits me between 50 and 65 mph.. I monitor my engine load gauge more than anything as I don't like to apply anything over 75% POWER for any given RPMs.. I do ck the trans temp,, and engine temp,, but have never had it out of normal range ever..
On a real hard pull that 4th cant keep up I will drop down to 2nd and float the power at or under that 75% power setting..
No engine has been made to pull at 100% power for any constant amount of time.. Anyway not if you wish to see 350,000 miles life out of it..
Sodbust
This said it best.
Old 02-21-2015, 11:25 AM   #34
mandolindave's Avatar
Thanks all
The RPM info was most helpful. I have electronic RPM readout, but was clueless as far as it being useful info.
mandolindave is offline   Reply With Quote
Old 02-21-2015, 12:38 PM   #35
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
An Ultragauge can give you engine load percentage among other useful readouts.
Old 02-22-2015, 06:45 AM   #36
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
If you want to see what's REALLY going on, hook up an Accutron or any other upper end scan tool to the Assembly Line Data Link under the dash. You can watch all the sensors in real time.
NavyCorpsman is offline   Reply With Quote
Old 02-22-2015, 09:05 AM   #37
If I only had a brain……..
Hey Navy, Data doesn't help me much, as I don't know what the parameters of the sweet spots are. Thus far, I have just been using the sound of the engine to warn me that I was pushing the limit.
Old 02-23-2015, 05:05 AM   #38
Regular Guy
1978 31' Sovereign
True. Seat-of-the-pants is the only way to fly. Lots of data can be used to impress your friends and family......... Really....
Old 02-24-2015, 07:40 AM   #39
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Using the math formula from post 31 above, our number is .79 and we can maintain speed with no issues by watching EGT, water temp, transmission oil temp and rear differential oil temp. We averaged close to 13 mpg coming back from Long Beach to Phoenix last Friday on I-10, which includes a long climb east bound out of Palm Springs.
Our combination seems to be a perfect match for us.
switz is online now   Reply With Quote
is anyone pumping blackwater uphill? elicia Waste Systems, Tanks & Totes 39 07-19-2015 07:56 AM
What is your MPG/Speed? Phil Gobie Tow Vehicles 34 10-16-2010 06:25 AM
Speed and towing Minnie's Mate Towing, Tow Vehicles & Hitches 23 02-02-2006 11:31 AM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
