Old 05-25-2016, 08:32 AM   #29
2015 22' FB Sport
Olatje , Kansas
We do the same all the time as well. Especially if it's just a quick overnight for sleep!
joekr is offline   Reply With Quote
Old 05-25-2016, 09:08 AM   #30
2004 30' Classic
Huntsville , Texas
Preflight streamers and hooks
Originally Posted by rmkrum View Post
I have a set of "remove before flight" streamers and a set of hooks and labels inside our closet to hang them on, plus a checklist.
Hopefully that will limit the possible damage.
I am intrigued by the streamers, hooks and labels you are using with a checklist. Would you provide more information about your system? I am finding the need for checklists for many operations. We have a checklist for takeoff, but need to make sure we always consult it, as we occasionally overlook something.
RLtravel is offline   Reply With Quote
Old 05-25-2016, 09:26 AM   #31
2007 22' International CCD
Use streamers available from Amazon. Look for "Remove before flight" key chains.
Hook for each streamer on back of closet door. Hooks and streamers are labeled with location, like 4 hooks for stabilizer jacks. Streamer also labeled.
Drop jacks, streamer goes on stabilizer. Retract jack, streamer goes back on its designated hook.
Checklist is made up from how I go around the trailer, either getting underway, parking, or storing/un storing. Examples on the site.
I also do two walks arounds before towing to double check all stabilizers, hitch parts and utility connections and steps are accounted for. As others have said, no interruptions allowed.
It's like pilots do with airplanes... Check and recheck from a very specific list of tasks and checks before takeoff and after parking.
KE4GNK/AE
Old 05-25-2016, 10:30 AM   #32
Llando88's Avatar
2016 30' Flying Cloud
Unhook every time?
I spent a lot of time with aircrew the last part of my career.
Pilots with 10,000+ hours would arrive in the trainer, first question they ask is 'where is the checklist'.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 05-25-2016, 10:40 AM   #33
Unhook every time?
Yup exactly. The checklist never forgets....people do.
I've flown as aircrew. You live or die by the checklist. Every close call I've ever been involved in can be traced back to missing something simple on the checklist.
I'm a bit anal about it, but I'm still alive--so I check and recheck the checklist.
You know the old gag about the three most useless things in aviation....
Fuel on the ground
Altitude above you
The backside of the power curve
Sometimes scrupulous attention to detail will keep you alive.
KE4GNK/AE
Old 05-25-2016, 10:53 AM   #34
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Then there was
"Kick the tire and light the fire" and
"Any landing you can walk away from is a good one".
Doug and Cheryl
Old 05-25-2016, 11:01 AM   #35
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I get paper towel write plug in and jack up on it and poke a hole thru the note onto my car keys. Every time I stop I do a wlk around.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 05-25-2016, 11:11 AM   #36
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Originally Posted by dkottum View Post
Then there was
and "If you can re-use the airplane, it is a great one!"
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-25-2016, 11:23 AM   #37
On Topic, this time
For me it's very situation dependent. I will often just put down the tongue jack and disconnect the unbilical. My Ram does not disconnect the 12V to the trailer when engine off like my F-150 did.
I will let side-to-side level go if less than an inch or so, but I try to level front to rear for the fridge. If I have to go too high, i.e. lifting the truck with the tongue jack, I will chock and disconnect the coupler. In the morning all I have to do is plug in and drop the trailer back onto the ball.
Al
S/OS #004
Old 05-25-2016, 11:27 AM   #38
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
I always put a note on the steering wheel to remind me to tell my wife to recheck everything before we take off, then if something happens, its her fault.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 05-25-2016, 12:14 PM   #39
Unhook every time?
Al
Had a friend that flew medevac choppers in Vietnam. He and his crew rescued a pilot out of a river under heavy fire. When they landed, a bit roughly at their base, they discovered there was not one spot on the airframe that did not have a hole in it. No one on the crew or the rescued pilot was even scratched. The chopper was scrapped on the spot, because it was so shredded.
He did get a medal for that one. I saw the pictures. To this day he has no idea how the Huey held together long enough to land safely. Even the rotor case, engine, fuel tanks, and both rotors were full of holes. His only explanation was that God must have taken over the controls at some point.
KE4GNK/AE
First time every-thinger! KennewickMan Member Introductions 1 04-19-2014 10:33 AM
Should I unhook batteries from shore power? flyfishrra Electrical - Systems, Generators, Batteries & Solar 14 08-30-2012 05:16 PM
2 of every picture happier Forum Admin, News and Member Account Info 0 08-18-2004 03:56 PM
What every Airstreamer needs! blucloud Off Topic Forum 3 08-08-2004 07:16 PM
