Originally Posted by Jwestman
I just put new tires on my 2012 25'. Looking at the old ones they are worn on the inside of the tread - the side facing the trailer - noticeably more than the outside. Is that normal?
It was my understanding that the wheels should toe in a bit, which would wear the outside of the tire. Use a straight edge held against the front and rear tire side wall to check the wheel alignment. An 8 ft light tube will do the job if you do not have a long straight edge. Alternatively, you can use a tight line between two jack stands. Good luck with your investigation.
Pat
