Old 04-27-2014, 02:31 PM   #15
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Wow. Here are a few facts although they do not totally clear up the controversy here.
Propane tanks will not explode even when punctured or shot with a gun that can penetrate the tank
Propane tanks will not explode even when shot with tracer bullets (bullets on fire)
Propane's most deadly scenario is in enclosed areas when leaks are present- both from a potential reparatory issue and ignition by flame.
There is a video that shows LP tank facts and mythsIt- somewhere online! From what I saw, where RV owners need to be most concerned is when we are in the coaches as basically there are at least four LP ports- furnace, water heater, stove/oven and fridge that could potentially leak into our living airspace. Make sure the LP warning device is replaced when faulty or every six or so years regardless.
One thing you come away with after seeing that video is the way that LP burns- its nature per se. It is pressurized, yes but it is all about dissipation or concentration in the air for it to become dangerous. That is why it takes an explosive device for it to become like a bomb- destroying the tank all at once and releasing most or all of the gas at once. Bullets can't do that. The same is true of natural gas. Gasoline is totally different.
As far as why RVs burn, here is one video I found. Note that the "fire guy" talks specifically about the 4 door fridges. That is because they are basically a doubled up version of what any AS would have with of course double heat in the rear too.
I could not find the official safety vid online but I did find this hilarious spin-off James Bond one:
HowStuffWorks "MythBusters: Exploding Propane Tank"
Ok, like I said, the facts part may not settle the controversy but they did make me more comfortable being around propane and LP tanks AND lighting my stove, etc. I know to switch on the gas and get it lit ASAP so as not to "build up" unburned gas in the vicinity of flame. If there are no leaks and a place for gas build up, the pilot should burn off the gas at its regulated rate. Oh, and as far as statistics go, what we have is a varied list of why RVs catch fire at a rate of around 20K units a year. The fireman gives several reasons. The "heat buildup" alone would contribute to spontaneous combustion. Note the sources he gives as per their reports. Hey that no fuel charcoal in your back storage area is a no go! I like others travel with my refrigerator running on LP. In FL it is too hot. My last trip with my new fridge I did not check the switch inside when I unplugged the electric (it ran 24 hours on electric) and net on gas before pulling out. It was on auto BUT the new "generations" models apparently have to be reset EVEN THOUGH it says auto. So, I automatically must remember to go in and switch it! Well, got to Fort Wilderness and had warm food- in three hours, in the winter! Fifty some degrees in there when I arrived. (have a fridge thermometer too!) Our neighbors lost their CBS (concrete block stucco) home a few years ago by storing their Coleman camp gear in the garage. It got hot and poof- spontaneous combustion.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 04-27-2014, 03:01 PM   #16
r carl's Avatar
Lin , Ne
You guys are fricken nuts!
Old 04-27-2014, 03:02 PM   #17
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I'm a pedant
It's a terrible terrible affliction
PharmGeek is offline   Reply With Quote
Old 04-27-2014, 03:13 PM   #18
2006 25' Safari
Images: 8
Hey I just joined in to help with mediation. I am comfortable around LP now but my previous ignorance made me uncomfortable until I learned more. I like your motto r carl. How true- learn to think. It applies to LP too! Check out the free fun movie (second link).
Old 04-27-2014, 03:38 PM   #19
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Originally Posted by PharmGeek View Post
I'm a pedant
It's a terrible, terrible affliction. So am I.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 04-27-2014, 04:08 PM   #20
1974 Argosy 20
Kooskia , Idaho
I have decided to turn off my batteries while traveling. Just too damn dangerous. Electrical fires from shorts, battery explosions. Amazing havoc can result. Oh, the break away switch needs power... 9 D cells will do that.
We did this topic last week (propane). It is time for a rest.
Old 04-27-2014, 04:53 PM   #21
aftermath's Avatar
Spokane , Washington
I'm a pedant
Mr Geek,
I have enjoyed your posts since the beginning. To be a card carrying pedant I would think you need a very dominant anal retentive gene. If you are indeed a pharmacist I would bet that you are a very good one. Too bad I don't live closer.
I especially appreciated your post in the thread about this same topic we just beat into the ground. It was the one that started out something like, I am not a psychologist but I used to live next door to one, or I read a book about it once.....In it you introduced (to me at least) the concept of how we follow "logical inconsistencies" all the time. YES! That is it. Getting away from any further psychobabble let me say this in the way of an answer to the OP.
Yes, run with the fridge on. The trailer was designed to do just that and it has not proven to be a safety issue. We have a very small percentage of folks who choose not to. They do not feel comfortable with the infinitesimally small probability of disaster so they opt out. Of course they gladly embrace the much greater risk of trouble due to accidents, collisions in intersections, loss of control from tire blowouts, fire from gasoline tanks, grease fires in the kitchen and so on. The concept of Logical inconsistencies makes sense to me now. Thank you Dr. Geek
aftermath is offline   Reply With Quote
Old 04-28-2014, 05:26 AM   #22
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Some people on this website get nasty over the smallest things. We're all adults here and can have different opinions.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 04-28-2014, 05:46 AM   #23
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
I always did love the saying live and let live. I am sure you will have just as much enjoyment with your Airstream if you turn off the propane as you would if your turned them on. You won't be less of an Airstreamer if you choose to turn it off. Feeling comfortable and relaxed is all part of it, so if leaving it on is comfortable for you, go for it, if turning it off makes you comfortable and relaxed by all means go for it. The Newbies Guide to Airstreaming suggests turning it off as well. Why don't we cut some slack? Not everyone has the experience and the confidence that you do!
GAStreamin is offline   Reply With Quote
Old 04-28-2014, 05:49 AM   #24
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
The definition of "Safe" is "in the absence of risk", in our ever changing world there is always risk, the the key is to manage risk, because it is always there. So be "safe out there" knowing there is risk in no matter what we do, simply make a decision then manage it the best you can.
Luigi123 is offline   Reply With Quote
Old 04-28-2014, 05:56 AM   #25
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We leave ours on because it's all behind us anyway.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-28-2014, 06:56 AM   #26
dznf0g's Avatar
Oswego , Illinois
I'm a pedant
Yes, fortunately we like pedants in some places in our world. Doctors, Pharmacists, missile bunkers, etc. I have a bit of the gene...but thank goodness passed the full blown gene to my youngest. He is a nuclear power plant cooling system engineer.
-Rich-
Old 04-28-2014, 10:40 AM   #27
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I keep the propane turned off at home and when I am not using it on the road, Most of the time I run the frig and keep the propane on when traveling. I do not see any down side to turning the valve off and on each day.
Old 04-28-2014, 11:24 AM   #28
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Would smoking a cigarette while pumping gas be more or less dangerous than a pilot flame... 'cause I see that ALL. THE. TIME.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Airstream Sightings while Travelling safari57 On The Road... 23 08-25-2013 06:28 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Shearing Off Interior Rivets While Travelling RICH&JAN 2007 Safari SE 32 05-02-2010 10:17 AM
Fresh water level while travelling Mrs_RedSHED Fresh Water Systems 9 03-17-2008 11:02 AM
What keeps fridge cold while travelling? ole81 Batteries, Univolts, Converters & Inverters 14 07-29-2007 09:13 AM
