Old 08-03-2015, 04:49 PM   #1
KYAirstream's Avatar
Northeastern , Kentucky
Travel with a full load of water?
I've read that traveling with a tank full of water helps with the center of gravity with the trailer. I'm curious if it really makes a difference, since a 50 gallon tank of water weighs more than 400lbs. That seems like a lot of extra weight if the effect isn't substantial.
KYAirstream is offline   Reply With Quote
Old 08-03-2015, 05:23 PM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
The tank I'm my safari is under the floor ahead of the axels so adding weight there adds stability and lowers the centre of gravity, in theory.
In practice I've towed with the tank full and empty and can't tell any difference in how the trailer tows.
Normally I fill the tank of we'll need water and leave it empty if we will have full hookups. So the tank will be full on the way to the NASCAR race but empty on the way for the KOA. I try not to tow with a half empty tank because the water sloshes around but I have and couldn't feel a difference. If we ever need to cross the desert I'll have a full tank in case of emergency.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 08-03-2015, 05:34 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
My 2 worth
If you're on your way to a boondocking site, traveling with a full water tank makes sense. If you're bugging out for a hurricane, it makes sense. Otherwise, it's more of a problem than it's worth.
A low center of gravity only makes a difference if you're going to slalom the trailer on a test track. Sane drivers will never maneuver so sharply that having the CG a foot lower (or whatever) would have a measurable effect on handling. As long as all of your trailer wheels stay on the ground, it doesn't much matter how high or how low the CG is.
Carrying a full water tank cuts into your load capacity. It adds to your tongue weight (unless the whole tank is behind the axles, which is seldom the case). It places more of a load on the tank supports causing them to fail sooner, and contributes to separation of the tank's vent line.
Carrying a partial tank of water is even worse, because then you have a sloshing effect, which causes your CG to move as you're towing, and makes every above problem more of a problem.
So if you're going to a campground with water, haul with your tank empty. If you're going to a campground without water, haul with it full. But always make sure it's either full or empty, never anything in between.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-03-2015, 05:39 PM   #4
Mission , Texas
The GVWR of my 27' Overlander is 6,200 pounds, 400 pounds of water in the fresh water tank would be roughly 7% of the total weight - maybe some effect, but not likely.
nrgtrakr is offline   Reply With Quote
Old 08-03-2015, 05:45 PM   #5
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I always carry enough for bathroom use only. If boon docking full tank!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 08-03-2015, 06:01 PM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I look at the full water tank as it is better to have it and not need it than the not have it and need it scenario. When filled at home, we know what the water tastes like. If a mechanical issue happens and we are beside the road, there is water at hand for the toilet or to drink. Out West where we are based, there are long stretches of highways with literally no services of any kind.
The water issue would be less serious back East with exits so close together on the interstates.
switz is online now   Reply With Quote
Old 08-03-2015, 06:02 PM   #7
Bend , Oregon
I do the same Joe
derf
derf is offline   Reply With Quote
Old 08-03-2015, 07:00 PM   #8
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
Me too, full tank. Better to have and not need than to need and not have
Hiho Silver is offline   Reply With Quote
Old 08-03-2015, 07:18 PM   #9
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I often fill up full at home first. Most campsites I visit don't have a convenient spigot so am faced with hauling 6 or 7 6-gallon jugs of water to the trailer after arrival. This can cut into cocktail hour and gives me a sore arm and I get wet.
kscherzi is offline   Reply With Quote
Old 08-03-2015, 07:22 PM   #10
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Full tank for me when I leave home, even if I know I'm going to a full hookup park. Never know about the future. You can always pump & dump, but if you need water, it could be hard to find.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-03-2015, 07:26 PM   #11
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
Our 16' Bambi definitely tows smoother and with less bounce with a full tank (only about 20 gallons). Also, I know that our home water supply is clean and odor-free. Not so sure about a campground's.
2015 Airstream Bambi Sport 16J
Past Travel Trailers:
*1992 Dutchmen 30' Bunk
*2003 Jayco Designer Series 32' Rear Living
*2015 T@B Sofitel S (exchanged after 3 days for Bambi)
remphoto is offline   Reply With Quote
Old 08-03-2015, 07:34 PM   #12
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Water
I usually carry all 54 gallons......as I am often boondocking for several days. This gives me at the least seven days without worry if I am careful.
The issue is not so much the fresh water but the gray tank which holds only 39 gallons...
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 08-03-2015, 07:45 PM   #13
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Most times I head out I do not know where I might end up. Always nice to have plenty of water on board. I usually leave my tank full, drain and refill it once a month.
MICHAEL
Old 08-03-2015, 07:45 PM   #14
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I've towed with it empty, full, and plenty of places in between and have never noticed any kind of difference. You're talking about, at most, a couple hundred pounds difference compared to thousands of pounds, so the difference is relatively small, and the weight is over the axles so it doesn't affect the hitch.
As to whether I fill it, it depends. Going camping to a place without water hookups? Yes, fill it, obviously. Going camping in a place with a water hookup? Don't worry about filling. But I do keep some in it at all times during the season so that we have water to wash hands, etc. while on the road (probably a third or so). But it's not a decision to make sure I have X gallons in it - it's more of a situation of what's left after we used it for a weekend without hookups, until the next time we are camping without a water hookup.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Parked with full hookups and full water tank question badkat Plumbing - Systems & Fixtures 16 10-18-2013 10:32 PM
fuel gauge showing full when it is not full Normin storm Mechanics Corner - Engines, Transmission & More... 2 08-25-2009 10:31 AM
1/2 ton tires- load C to load E John Tires 75 03-20-2009 10:15 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 08:36 AM
Need spring load clips for water heater door 68 GT. Jim Clark Water Heaters, Filters & Pumps 4 05-09-2002 08:39 AM
