Old 06-04-2016, 12:59 PM   #1
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Trailer Weight: Dry vs. Fully Loaded
My '90 25' trailer weighs 5000# dry. I've weighed it fully loaded, including a full tank of fresh water, a couple of times and it came in at around 5800# for an increase of 800#. How much does your trailer weigh dry vs loaded?
Cheers,
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 06-04-2016, 04:50 PM   #2
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I'm interested in only one simple thing: what is your typical trailer payload, i.e. the difference between dry and fully loaded for camping?
John
John & Vicki
WBCCI #4291
Old 06-04-2016, 05:19 PM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I had a 27' '01 Safari and its unloaded weight was 6,000 lbs. With food, camping supplies and clothing it came in at 6,500 lbs. with nothing in the holding tanks. My Classic slide out is probably pushing 8,700 lbs or do with the same load. If I fill the fresh water tank, I'm probably around 9,100 lbs.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-04-2016, 05:55 PM   #4
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Thanks Jack. My sense is that 400-500 pounds with empty tanks is probably pretty common.
John
John & Vicki
WBCCI #4291
Old 06-04-2016, 06:07 PM   #5
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
2013 25FB Flying Cloud twin (no factory options):
Empty weight when new was 5600
Most recent weight after addition of rear and street side awnings, four solar panels, a Magnum inverter/charger and larger batteries, weighed loaded during a four-month trip, with full tank of water: 6900.
So an increase of 1300.
SSquared is offline   Reply With Quote
Old 06-04-2016, 07:03 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The specs for my 25' Safari floor plan C (six sleeper) says it weights 4,770 lbs empty. I've changed and added a few things so, so I'm guessing closer to ~4,800 to 4,900 lbs is the real weight now, without water or fuel.
I can add ~39 gallons to the fresh tank and ~6 in the water heater. (0 lbs to ~375 lbs possible variation for water)
I always keep one of the 30 lb propane tank full and one is partial (30 lbs to ~60 lbs possible variation for propane)
The last three times the gross trailer weights were 5,280 lbs, 5,560 lbs, 5,960lbs. All were done at a CatScale. I've weighed my 25' several times, but never empty.
Assuming actual trailer weight of 4,900 lbs:
The first weighing was at the end of a weekend trip with only a few gallons of water. (~490 lbs payload)
The second weighing was at the start of a weekend trip with a partial tank of water. (~660 lbs payload)
The third weighing was at the beginning of a couple month long winter trip to FL, heavily loaded with gear, clothes, food, drinks, 2 bicycles, 1 full propane and one partial, and ~45 gallons of water in the tanks. (~1,060 lbs payload)
add edit:
Since the scales weigh results are in 20lb increments, there is a ~10 lb + or - possible variation.
Old 06-04-2016, 07:30 PM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our 2015 23D International Serenity left the factory assembly line at the end of September 2014 with the factory installed inverter, street side and rear awning and 1,000 watt inverter. It weighed 4,870 pounds then.
After extensive modifications and fully loaded for camping it scales 6,086 pounds. The street side rear 15" Michelin has the most load at 1,360 pounds. None of the axles are overloaded and the tongue weight with a Hensley Arrow hitch attached is 968 pounds.
We have five 100 watt solar or else on the roof, 300 amp-hour lithium that weighs less than the two stock batteries, 15" Michelin tires on SenDel wheels, Truma instant on water heater, Dometic CU434 stove, Vitrifrigo DP150iL refrigerator, 10" Rocky Mountain mattress, Magnum hybrid MSH-3012 inverter, all 129 Vac outlets upgraded to Hubbell commercial grade outlets, custom Hickory dinette table top and flip up side table beside sink, all Airstream Stainless Steel upgrades and converted brakes to auto-adjust with Timken bearings and seals.
Towing with 2007 Mercedes ML320 CDI diesel.
Old 06-05-2016, 12:52 PM   #8
2016 19' International
2012 Interstate Coach
Virginia Beach , Virginia
Impressing)
Misha_9998 is offline   Reply With Quote
Old 06-05-2016, 03:59 PM   #9
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Like the OP... About 800# and I always weigh with a full fresh tank and both waste tanks empty since that's how I travel. That's about 300# of water. The other 500# is gear and food including 60# of propane which I believe is not included in the dry weight published by Airstream. I also have about 200# of additional gear (generators, solar panels, blue boy, tarp, chairs, grill) in the back of the truck which isn't there unless I'm camping.
GammaDog is offline   Reply With Quote
Old 06-05-2016, 06:14 PM   #10
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
Don't forget to include your weight distribution hitch. On the newer trailers there is a maximum gross vehicle weight stamped on the identification label. Best to use that +10-15% imbalance for tire selection and TV loading selection.
gr.austin is offline   Reply With Quote
Old 06-05-2016, 07:00 PM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I weighed my 30' FC a couple of weeks ago, absolutely empty. It had full 30# propane, no water other than water heater, awnings on both sides and aft, and that's all.
It weighed in at 3000 Kg. an even 6600 lbs.
I'll let you know later when I have it it loaded for my first trip.
MelGoddard is offline   Reply With Quote
Old 06-05-2016, 07:13 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not know what our dry weight is. I know the last time we weighed it was 6300 when loaded and ready to go against a GVWR of 6800 lbs. I know we carry 800 lbs on the truck and 5500 lbs on the trailer axles when traveling. Half or more tank of fresh water and almost completely empty waste tanks. We have a full compliment of awnings. No spare tire. 2 batteries. No solar. I have added a vinyl plank floor, part of a cabinet, and a television set. Microwave. A pantry full of heavy stuff and drinks under the sofa.
Okay, I looked up the dry weight on the Airstream site. 5100 lbs with a tongue weight of 700 lbs. So we have added about 1200 lbs to whatever they consider dry. And our tongue weight must be over 800 since I am transferring some load back to the trailer axle.
To me the dry wt seems a bit not relevant. I think and work mentally from the loaded weight since I can get that. If I was buying a new tow I would size it from the gross weight.
Bill M. is online now   Reply With Quote
Old 06-05-2016, 08:17 PM   #13
The interesting thing is: when I weighed my 30' FC (above), iI used my new Sherline tongue wt. Scale at the front screw jack, and recorded 1100lbs
A.S. said the weight should be between 800-900lbs.
And in no case over 1000 lbs.
So what's with that?��
"Look after your equipment, it'll look after you!"
Old 06-06-2016, 01:06 AM   #14
2016 30' Classic
Santa Rosa , California
So what's with that?��.
I dont know why Airstream sets the maximum tongue weight to 1000, but once you start loading the external storage bins located behind the wheels, and interior cabinets/drawers behind the wheels, that should help to take a load off the tongue.
We have the opposite issue - in order to bring the tongue weight up to the recommended 10-15% of our loaded Classic's weight (8900lbs), I have to move some heavier items to the front before we travel, even with two full propane tanks on the front frame.
Happy Trails,
Phil
phann is offline   Reply With Quote
2013 Airstream 16 foot sport travel trailer Fully Loaded! **NEW** eBay Watch Airstreams on eBay 0 09-05-2013 10:40 AM
Airstream 25ft Safari LS Special Edition Fully Loaded eBay Watch Airstreams on eBay 0 07-13-2011 11:00 AM
Airstream Landyacht Fully Loaded And NO RESERVE..!!!! eBay Watch Airstreams on eBay 0 05-23-2010 06:20 PM
Brakes Fully Loaded - Which Ones Ganglin Brakes & Brake Controllers 3 02-26-2008 05:00 PM
Value....of 1994 Airstream Classic limited....."Immaculate , fully loaded"!!! route66 Off Topic Forum 7 09-22-2004 07:02 PM
