Old 03-25-2016, 05:20 AM   #15
2005 19' Safari
2007 23' Safari SE
Onekama , Michigan
Wow. Thanks for the info. I'll definitely look for the BB's.
Gene T is offline   Reply With Quote
Old 03-25-2016, 08:27 AM   #16
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
When you use Blue Beacon do they wash the tow vehicle too for the same price?
Looking at some youTube videos they use the same pressure type washers at the coin operated self service. Do they wash the top and dry the trailer and tow vehicle?
Kelvin
Old 03-25-2016, 08:36 AM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Blue Beacon does use acid.
As mentioned above, not really a problem for clear coated trailers, but it WILL dull polished trailers.
Superat stultitia.
Old 03-25-2016, 08:55 AM   #18
Sioux Falls , South Dakota
Don't know for sure. I've heard both ways, so it may depend on the location and how many trucks are stacked up. I've taken our 40' MH through once, and was happy with the results. The Jeep was already unhooked, so I didn't hook it up to see.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 03-25-2016, 09:27 AM   #19
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Used Rudy's in Fort St John on way down AK highway, easy access do it yourself car and truck wash. Bays long enough for pickup and 25' to fit.
Used Blue Beacon for first time in Twin Falls, ID. $15 for truck and $25 for trailer. Worked out fine.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 03-25-2016, 10:19 AM   #20
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
With all the water splashing and misting inside the BB wash space, both vehicles get wet anyway so might as well get the bugs and road grime off both at the same time.
Our units are stored under roof in Apache Junction, AZ but there is always an accumulation of dust and sand from the wind storms that we get washed at the start of most trips.
Old 03-25-2016, 10:35 AM   #21
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Another vote for Blue Beacon Truck Wash.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-25-2016, 10:46 AM   #22
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
I live in S Cali, LA area. I use those mobile washer guys to come and wash my trailer. When my wife says I am not the one cleaning it, I tell her, I took the effort to call and make arrangements. So technically, I washed the trailer.
cazual6 is offline   Reply With Quote
Old 03-25-2016, 11:27 AM   #23
2004 28' International CCD
Cocoa , Florida
I've used blue beacon as a trucking company and with my AS. They do a reasonable job, but they are nation wide. I have found a local guy that details cars. He charges me $110 for my 28' international. And believe it or not, that's a hand wash AND hand wax with tire dressing... I scored here in Cocoa. FL... You might also in your home town
Bhkh226 is offline   Reply With Quote
Old 03-25-2016, 11:40 AM   #24
TinCan
graysailor's Avatar
2016 30' Classic
Regarding Blue Beacon do you ask that they do or do not use their brushes? Or simply have them spray wash with soap and water?
TinCan
graysailor is offline   Reply With Quote
Old 03-25-2016, 11:50 AM   #25
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
I use BB and love it $42 for truck and trailer, I have not had RainX applied, not sure if it OK. Does anyone here have them apply rainX to trailer? Is it safe on clear coat??
Russ and Lisa
2018 Classic 30
2015 F250 King Ranch 4x4 turbo diesel
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
Firedog1 is offline   Reply With Quote
Old 03-25-2016, 12:01 PM   #26
m.hony's Avatar
2013 30' Classic
There is a less expensive, generic version of Rain-X available at Blue Beacon.
You can specify no acid.
To clean in between, I wipe down after a dew- free wash-
I use Meguiar's instant detailer in between and at campgrounds where trailer washing is prohibited.
TAC #MS-10
Airforums #70955
Old 03-25-2016, 12:33 PM   #27
Lily&Me's Avatar
Normal , Illinois
I haven't seen brushes at BB....it's all done with hand wands.
Maggie
Old 03-25-2016, 01:08 PM   #28
m.hony's Avatar
2013 30' Classic
There are brushes for 18 wheeler smokestacks. The brushes are kinda sorta u-shaped.
You can request no brushes as well.
Even after a Blue Beacon wash a towel dry the truck and trailer before hitting the road.
TAC #MS-10
Airforums #70955
Washing AS while on long trips bearrand On The Road... 16 08-16-2012 05:08 PM
Washing when traveling Tino643 On The Road... 14 12-21-2011 05:15 PM
Washing the AS while on the road. Not Done On The Road... 7 04-18-2011 06:33 AM
Do you use your LP refrig while traveling? John Community Polls 19 07-23-2005 09:28 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
