02-25-2018, 12:36 PM
2013 28' Flying Cloud
Central
, Canada
Trailer Wash Water with JetDry?
Greetings all;
I'm just checking in to see if anyone has any experience with putting "JetDry" into your wash water to eliminate hard water marks?
We try to keep our trailer as clean a we can even when we're on the road. So options to washing are always of interest.
Thanks in advance for any input
cheers
Doug
Trying to use my camera to create memories - not photographs!
02-25-2018, 02:04 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Following
02-25-2018, 02:27 PM
2018 30' Flying Cloud
South Hero
, Vermont
I’m on well water that’s kind of hard. I put a little Jet-dry in the wash water. I don’t know how much it helps since I just rinse without it. But, it can’t hurt.
02-25-2018, 05:30 PM
2009 25' FB Classic
Scottsdale
This might be good to see if anyone has used this procedure. I live in the Phoenix area and have very hard water. The storage lot has de mineralize water at the RV wash. I use that and then dry with rags.
Bob & Julie # 5587, 4CU in AZ
02-25-2018, 06:17 PM
Baltimore
, Maryland
I would try in the rinse water. If you use in the wash water, you will be rinsing it off with the rinse water. I think that you would want the Jet Dry to stay on the outer surface of your AS. Jet Dry is a silcone coating that reduces the surface tension of the water on things in your dishwasher, so that droplets of water slide off your dishes and hopefully reduce spoting.
I use a windshield washer fluid that contains silcone to do the same thing for my windshield. It works well.
Cheers,
John
02-26-2018, 07:19 AM
Central
, Canada
Cheers,
John
Thanks John I should have said rinse water in the original post as that’s what I meant.
Thanks again for your input
02-26-2018, 09:12 AM
2015 25' FB Flying Cloud
Huntley
We live in Phoenux also. Where do you store your unit?
02-26-2018, 09:17 AM
Eustis
Great idea
I am not sure what you mean by put it in the rinse water and I am assuming that you are putting it in a bucket and then using that with a brush to like rewash the trailer. Maybe you mean something else, but I just had a thought of putting it in a hose end sprayer bottle and then adjust it for the correct ratio and hose it down.
Thanks for the idea!
02-26-2018, 10:04 AM
1975 31' Sovereign
West Liberty
, Kentucky
I wonder if anyone has used a garden sprayer with Jet Dry or windshield washer diluted with water and sprayed on the Airstream as a final rinse. This is the process used at a car wash as a spot free rinse.
02-26-2018, 11:04 AM
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
We love GEL-GLOSS wash and wax from Camping World. It's a pink gel that washes and waxes our trailer keeping it looking new and shiny. I put a glob of it into the wash bucket, wet the trailer and wash a section at a time with the RV brush rinsing a section at a time. No water spots!
Happy trials y'all.
In dog years, I'm dead!
02-26-2018, 12:38 PM
Eustis
I tried calling Jet Dry customer support to ask how many Oz per gallon but they said since there were no instructions on the label for use other than using it in a dishwasher she was no help. I did some other thinking and I am open to criticism too. The container indicates that 16 oz does 150 dishwasher loads. The average dishwasher uses between 4 and 6 gallons of water. I assume that 1/2 (2or3) gallons is for rinse and the other 1/2 is wash. This is only a guess. So 16 Oz divide 150 washes divide by 2.5 gallons equals very little I am going to try 1/2t per gallon as a final rinse.
02-26-2018, 01:18 PM
1994 34' Limited
colebrook
, Connecticut
JetDry
I have used JetDry when washing my airstream and cars. I put it in the wash water and found that it greatly reduced water spotting. It does not do as well on clear coated alum.
Mark
02-27-2018, 07:11 AM
Central
, Canada
Thanks everyone for your input. I need to wash the trailer in the next couple days and will give this a try
