Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 05-02-2016, 01:00 PM   #1
2016 26' Flying Cloud
Bastrop , Texas
Towing AS From Alamogordo NM to Cloudcroft NM
Trying to get away from the heat in June in southern New Mexico. Does anyone have any experience driving from Alamogordo NM to Cloudcroft NM - both up and back. Believe its a very steep grade. Also, any issues with an AS at 8,600ft.
Tarcoola is offline   Reply With Quote
Old 05-02-2016, 06:59 PM   #2
GoWhereTowed's Avatar
texas , Texas
It is very steep and winding. Should have no problem with AS at that elevation. Biggest challenge is to have enough TV power to pull the mountain.
If you are reading this, it means I have made it another day!!!
GoWhereTowed is offline   Reply With Quote
Old 05-06-2016, 02:54 PM   #3
J2Becker's Avatar
2015 27' Flying Cloud
Santa Fe , New Mexico
I have done it both ways. Not really difficult. Use engine braking. I am towing w a half ton pickup no turbo and 27FB. Just take it easy.
"It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be 'the way'." ~ Rubin, "Road Trip"
__________________________________________________ ___________________________________________
"The most savage controversies are those about matters as to which there is no good evidence either way." Bertrand Russell
J2Becker is offline   Reply With Quote
Old 05-07-2016, 06:26 AM   #4
Bastrop , Texas
Thanks for the feedback J2Becker and GoWhereTowed. That part of NM looks like a great area to explore.
Old 05-15-2016, 08:41 AM   #5
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
Pretty Steep Drive!
The route from Alamogordo NM to Cloudcroft NM on US 54 to US 82. In 19 miles, your elevation in Alamogordo starts at 4,400 ft, and ends at 8,700 ft in Cloudcroft. Average grade 5%. That is pretty steep, especially for such a sustained distance. You will use a lot more fuel during that climb, and if you have any concerns on engine over heating, you may want to do the drive before the heat of the middle of the day.
On the other hand, it should be a beautiful part of the country. Enjoy the trip!
Name:	nm profile_picture.jpg
RAH is offline   Reply With Quote
Towing 19ft Bambi with 2009 Tacoma v6sr5 w towing package Shany Tow Vehicles 6 07-03-2017 10:44 PM
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
Lincoln National Forest Campgrounds-Cloudcroft Goal15 On The Road... 12 07-09-2014 02:41 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
