02-24-2009, 12:54 PM
I Bought it I Broke it...
1976 31' Sovereign
Migratory
, North America
Towing an Airstream with a VW Bus
I was wondering if anyone has had any experience towing a small Airstream with a VW Bus.
Currently, we live in a 29' Class C RV. It's great and all, but it's on it's way out and I've been itching to get a little '79 VW Bus and fix it all up. I know they have a small engine, 60HP at best, so I'm not sure if I would be able to tow anything, let alone even a small Airstream.
Anyone have any ideas on this? I'm even open to the idea of having a larger, more powerful engine put into the VW if necessary.
02-24-2009, 01:00 PM
Corona
The engine is sort of not a question.
The problem is that you will not be able to install a load equalizing hitch on that van, that you must absolutely have for safe towing, regardless of the size of an Airstream trailer.
02-24-2009, 01:05 PM
Princeton
, New Jersey
In another lift time I towed with a VW 36 hp, see attached picture. Now I have to say the trailer only weighted 900 lbs and I did have to wait on the turnpike on ramp for a UPS truck to come by and use him as a slingshot to get over 50 mph but it did work.
However i think you are asking for a bit more than can be expected for man and his machines.
2004 Excursion 4x4
02-24-2009, 01:34 PM
1978 28' Ambassador
Kenton
, Ohio
I've been driving VW buses for 35 years...lots of them. My daily driver is a 1967 camper. You will overheat the engine fast towing even a bambi. The only trailer I have seen towed are Eriba Pucks or little things that motorcycles tow. Go to thesamba.com and type in eriba in the search window. Also, go to the forums section and ask the question to bus owners. Also, you can only get very small hitches that will work with a rear engine, nothing near what an A/S would need.
Tom
02-24-2009, 01:36 PM
Aluminut
2004 25' Safari
Sorry bud, but even with a flux capacitor, you are pop up bound, if even that.
02-24-2009, 01:39 PM
Certifiable
Wally did.
http://www.airforums.com/forums/f492...ere-47715.html
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
02-24-2009, 01:45 PM
1978 28' Ambassador
Kenton
, Ohio
Originally Posted by mistral blue
Wally did. l
Hmmmm...I'll bet not for long. :-)
02-24-2009, 01:51 PM
Master of Universe
2008 25' Safari FB SE
Grand Junction
If you want to tow with the always underpowered VW busses, move from Pa. to somewhere that is absolutely flat and very close to sea level to get more power out of that engine and not have to go up a hill. Then find the plans for the original trailers that Wally Byam designed in the early '30's, a build one of those, and you're on the road.
In other words, no.
I had a bus, maybe late 70's, that I got in a trade. It had the 2nd generation fuel injection system and it was fun, we camped in it a few times, and it was pretty fast for a VW. It also was cold in the winter and leaked oil even after I fixed that problem. When the oil leaks eventually got to one quart every 100 or 200 miles, it had to go. I'd never consider towing an Airstream made in the past couple of generations. I do remember, though, that back bumper was made of really strong steel because it had been pushed in by something by a previous woner and I never could pull it out even with a tree and a come along.
Gene
02-24-2009, 02:14 PM
Certifiable
none tons
prolly longer than some of these guys!
The 1999 WBCCI International Rally - Dayton, Ohio
02-24-2009, 03:51 PM
1972 Travelux Princess 25
Cobourg
, Ontario
As a long time VW fan and owner of camper vans I advise against it. The 79 has a fuel injection air cooled engine of about 80HP. It is barely strong enough to power the van itself. Any trailer would be too much for it.
You would be far better off getting an American van. Believe it or not a Ford Windstar or Freestar van will tow an Airstream if properly equipped. This is the minimum. The VW is just not powerful enough.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
02-24-2009, 07:21 PM
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville
, Wisconsin
Im surprised this question hadnt been asked along time ago! I have a 71 Bus that has an OEM VW hitch which is mounted to the frame with heavy angle iron...of which i dont happen to know the dimensions...I belive it says the tongue weight max is 400lbs, and max tow weight is 1500...So, as much as Id like to use it to pull my 67 Safari, its a bit under powered and even that hitch is a bit light. Im guessing that no one else made a hitch nearly as heavy duty as this one either. Even though the bus was considered a 1-ton vehicle with its huge frame and breaks, it was a bit underpowered!
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
02-24-2009, 07:42 PM
1972 25' Tradewind
North Vancouver
, British Columbia
I had a 78 with a 2 litre engine and can honestly say no way! Too underpowered for the task you're thinking. It was, however, a Westfalia, so there was no need for a trailer as it was all set for camping. If you want to tow with a VW, wait for the diesel Passat wagon to hit our shores or get a Toureg.
North Vancouver, BC
02-24-2009, 07:47 PM
1960 33' Custom
Athens
, Georgia
I always wanted a split screen VW camper but converted to the flat 6 from a 911. I still don't think it would be ideal TV material but it would half solve the bhp problem.
02-24-2009, 08:17 PM
1967 26' Overlander
Owings Mills
, MD
Running stock, I would say no... but your notion of an engine swap is interesting. There are some VW lovers who have done some interesting exchanges. I think Subaru engines are common. According to Kennedy, you can do a fairly clean swap with an Subaru engine bumping to about 130 hp. I've also seen posts where guys (or gals) bumped to a 3.1l 230 hp engine. Giddyup!
02-24-2009, 08:26 PM
2003 31' Land Yacht 30
Old Hickory
, TN
Another option...
I just entered the world of the Airstream B190 Van. Think VW Bus on steroids.
It can certainly handle an AS TT - within limits.
Just don't expect V-Dub gas milage...
Take a look at:
B190 Enthusiasts
Ralph & Margie Day
Lizzy the Borderline Collie
Old Hickory, TN
Between 'steams...
02-24-2009, 08:31 PM
St. Cloud
Vanagon or microbus -- a small teardrop or der Kleine Prinz is about your only possibility. Except for that Airstream being privately owned and revered as nearly a museum piece. Or you could nurture the exceptional skills of Carlos - http://www.airforums.com/forums/f191...pod-37710.html
Anybody ever install a higher performance (yet fragile) Corvair aircooled plant in a microbus?
You aren't the first to ask the microbus question - VW bus
02-24-2009, 08:49 PM
1968 26' Overlander
Dillon
, Montana
As a previous owner of 2 VW vans, a VW dune buggy and several Beetles, my advice is : don't do it. I think that even with a remote oil sump and an additional oil cooler, the engine will eventually melt. I can't imagine going uphill against a head wind. Then there's the old saying about an accident waiting to happen.........
02-24-2009, 08:58 PM
1978 28' Ambassador
Kenton
, Ohio
The Subie engines are great for an engine replacement with a waterboxer (water cooled). They work great. I don't know of many that have been done to an aircooled bus or van. They have been done but are few and far between.
Tom
1972 25' Tradewind
McHenry County
If 37 years with VW service has taught me anything it’s that Type 2 owners are a bit eccentric. This means that they will take great pleasure in doing something just to prove you wrong.
Here we are taking a new member to task for thinking outside the box.
Who’s to say that clicknathen doesn’t have a Pacer or Bubble hiding in a barn somewhere?
Engine mods are easily accomplished and readily available. I’ve seen a T2 with a diesel stuffed in back. One of my colleagues had a Drag Bug that would tear the splines out of a C/V joint hub after 3 passes. Torque and Horsepower issues can be overcome. Same goes for the suspension and brakes.
Longevity, practicality and safety may only be secondary considerations.
Heck, I’ve even towed a 17’ canoe filled to gunwales with camping gear to up to the UP and down to Florida on the back of an overloaded ’70 Camper Bus.
Seriously, while there is a Forum member that tows a Bus behind an Airstream motorhome, I think that turning the tables could be a recipe for disaster.
Tom.
02-24-2009, 09:02 PM
1978 28' Ambassador
Kenton
, Ohio
VW made vans with a diesel for a year or two in the 80's. Strong engines but very slow.
