Old 12-09-2018, 10:58 PM   #1
McCalla , Alabama
Tow vehicle
What is everyone towing a 30’ classic with?
Jtholland is online now   Reply With Quote
Old 12-10-2018, 06:46 AM   #2
2001 30' Classic S/O
Marshall Ford , Texas
My 2016 crewcab Duramax tows my 2001 Classic with slide. With about 16,000 tow miles in the last two years, we average about 13.4 mpg. Combined tow and non-tow mpg is around 15.6. That's at 56,000 miles total.
With the truck weighing around 7,000+ and the trailer around 9,000 lbs, there is no sway.
I know you can tow with a smaller vehicle, but I have peace of mind knowing I can stop with control when some sob cuts me off...
Cruising at 65 to 70,
John
TexAirS is offline   Reply With Quote
Old 12-10-2018, 08:46 AM   #3
2018 30' Classic
Jacksonville , Florida
2017 Chevy Silverado, 2500 HD, Duramax 6.6L diesel., Z-71, crew cab..…… Cruises at 65mph around 1600-1750 rpm. On cruise control with trailer it goes over the Buckman Bridge at 1750 rpm. My old 3/4 ton gas truck couldn't do that without down shifting and increasing rpm. The diesel engine braking "jake brake" was invaluable on the two lane roads in the Smokies last summer. You don't have to have 4x4. But the "limited slip" rear end is a necessity. Comes standard on the GMs. I get 13mpg +/-.5.
I also tow some boats.
PS...…….at 7500 pounds it is in the next weight class in Florida. Everything cost more. Registration instead of $35 +/- on my car the truck is $150+/-.
Overstreet is offline   Reply With Quote
Old 03-14-2019, 11:01 AM   #4
McCalla , Alabama
Thanks all. I ended up with an F350 crewcab long bed 4wd with the 6.7 powerstroke. Longbed will be my garage. JT
Old 03-14-2019, 11:19 AM   #5
pt.reyesfan's Avatar
2016 30' Classic
Naperville , Illinois
Silverado 3500 crew cab long bed.
Ed
2016 Classic (with ProPride)
2016 Silverado 3500HD Diesel drw
1995 & 2004 Gary Fisher Hoo-Koo-e-Koo emergency vehicles
pt.reyesfan is offline   Reply With Quote
Old 03-14-2019, 11:21 AM   #6
McCalla , Alabama
What kind of bed cap are you using,
Old 03-17-2019, 11:06 AM   #7
Retired Fishing Guide
Cap-N-Red's Avatar
2005 28' Classic
Port O'Connor , Republic of Texas
Pull ours with ‘18 G.M.C. 2500HD Duramax/Allison crew cab standard box. Average 13 mpg +or - .5 bpm at 65 on cruise (on fairly level ground).Cruise control gets turned off in the hilly or mountain area. We do have a Leer bed cover that is cab height.
Cap-N-Red
2005 GMC CC D/A
2005 28' Classic
WBCCI # 3133
Cap-N-Red is offline   Reply With Quote
Old 03-18-2019, 01:37 PM   #8
Retired Navy Veteran
1964 26' Overlander
Warner Robins , Georgia
I also am looking for a new TV for my 26ft Overlander (1964) and recently purchased 34ft Excella (1989). Heavy Duty trucks with gas engines should work but I see a lot of folks using Diesels. Many of the comments on this forum recommend diesels for heavy towing, but not for daily drivers. This bit of info comes from looking outside my Overlander today at Land Yacht Harbor in Melbourne, FL. I see Diesel TVs from all over the NorthEastern states and Canada which have their AS’s parked here for months at a time. Guess what these diesels are used for ALL winter = DAILY DRIVERS. Unless you plan to tow a lot of days, stick with gassers and every once in awhile offer to buy a gas line water filter or some DEF for your Diesel friends!
superChop is offline   Reply With Quote
Old 03-18-2019, 01:42 PM   #9
2016 30' Classic
ARE fiberglass
Ed
Tow vehicle weight to tow 19' Airstream pennylynne 2005 and newer - Bambi all models 18 02-20-2017 11:18 PM
Tow Vehicle - Jeep Wrangler to tow sport 16 iamcrazy Tow Vehicles 22 04-10-2016 07:37 PM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
Can you tow a 31' with 12 a bhp tow vehicle? goatfarmer Member Introductions 6 06-30-2010 10:40 PM
