Old 09-07-2014, 07:55 PM   #29
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
Any single ply tissue will work. Sloshing in transit is good, and I have heard that, after dumping the black tank, put an 8 lb bag of ice in the toilet, and let that slide around in transit. Have yet to try this, but sounds very reasonable.
Tom
TVKetchum
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 09-08-2014, 09:51 AM   #30
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
**IT Happens
In days of old
when Knights were bold
and paper wasn't invented
They wiped their ###
on a piece of grass
and walked away contented.
There ARE alternatives. A bidet/toilet. There was a thread years ago about a woman who had one installed "fresh as a daisy" just pat dry with a small towel (never use what looks like a hand towel in THAT kind of bathroom.)
Rig the sprayer to operate with (a) warm water and (b) when you're not stepping on the flush peddle. (again towel dry)
Buy brown shorts - no giveaway "racing stripes"
Use the "mom grew up in the depression" or "extreme cheapskates" method which only requires one sheet:
  • pull one sheet from the roll
  • fold it into quarters
  • with your fingers pull out a center hole with a radius of slightly under 3/8 inch
  • retain the quarter folded center piece
  • unfold the sheet
  • insert your index finger into the hole
  • wipe
  • use the sheet to remove as much as you can from your index finger
  • use the quarter folded center piece to clean under your finger nail
  • shake hands with a politician then wash your hands (conserve on soap as well as toilet paper)
The method listed above may seem extreme, but frankly if you're going to use Scott tissue for anything other than finish sanding a shop project - you're likely to have a breakthrough that your psychiatrist wouldn't be thrilled with anyway. The result will be the same.
Old 09-08-2014, 11:41 AM   #31
timmaah's Avatar
1999 25' Safari
On , the road
We have been full-timing for over 2 years. All different sorts of toilet paper with the sewer solution and never have had a single issue.
Our Adventure.. http://www.watsonswander.com/
timmaah is offline   Reply With Quote
Old 09-08-2014, 06:52 PM   #32
Remax gal's Avatar
2014 27' FB Eddie Bauer
Lake Placid , Florida
Paula...you are TOO much!! I love reading your posts!
Let the good times roll! Laura & Tom
Let the good times roll!! Laura
Remax gal is offline   Reply With Quote
Old 09-09-2014, 05:33 AM   #33
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Actually, there is a Dometic bidet hose attachment for their toilet in a trailer. That is a very upmarket accessory.
One has to improve their aim with the hose to keep from "watering" the entire bathroom walls
The version I remember from grade school:
In days of old
and toilets were not invented
They dropped their load beside the road
Old 09-09-2014, 07:46 AM   #34
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Originally Posted by Foiled Again View Post
In days of old
on a piece of grass
  • unfold the sheet
  • wipe
Scotts: AKA John Wayne TP. Rough, tough, don't take no s**t from nobody. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 09-09-2014, 08:14 AM   #35
AnnArborBob's Avatar
Chelsea , Michigan
Images: 12
We've never found that toilet paper makes up a significant part of our household budget so we just use RV toilet paper.
Bob Martel
WBCCI# 5766
Old 09-09-2014, 08:52 AM   #36
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
After dumping, we refill about half way, dump again, refill about 10% and add a about a .25 cup of dish soap to the black tank. The hope is that it will slash around and clean it up a bit.
Silverflames is offline   Reply With Quote
Old 09-16-2014, 10:15 AM   #37
2012 22' FB Sport
Lake Forest , California
Originally Posted by danjoe91 View Post
I have been trying to find out if 'septic safe' toilet paper is alright to use in Airstreams, ( more specifically, my '85 Excella), or should I only use 'RV' approved tissue?
Friends of ours watched a demonstration on toilet paper dissolving at a rv show and the Kirkland brand form Costco won the contest. Much, much cheaper than the worthless over priced rv stuff.
HrLola is offline   Reply With Quote
Best price on toilet paper sharptalk Plumbing - Systems & Fixtures 16 07-22-2009 05:32 AM
The Great Toilet Paper Debate moosetags Sinks, Showers & Toilets 26 02-19-2008 08:59 AM
Toilet paper and other things campcollector Waste Systems, Tanks & Totes 45 12-08-2006 09:22 PM
Important papers: toilet paper cover Safari64 General Interior Topics 15 03-17-2006 07:04 PM
Toilet Paper: Is scotts ok? TBKP's Overlander Plumbing - Systems & Fixtures 11 11-29-2002 08:03 PM
