Old 09-04-2014, 07:57 PM   #15
dznf0g's Avatar
Oswego , Illinois
Originally Posted by mefly2 View Post
I am more concerned about the smear on the rear ...especially if/when the thinnest gives out ...
I think that's why, in some cultures, you don't shake hands!
-Rich-
Old 09-04-2014, 09:02 PM   #16
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
after living on a boat and having to deal with this on numerous occasions with "guests". I now use only Scott RV, I found that Walmart has consistently has the best price. We also have an '82 38' Newell so I buy in "bulk" when I find it on sale.
Yes, I have heard that you can use any TP but really....do you want to deal with a problem of this kind when .........................
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 09-04-2014, 09:15 PM   #17
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Take a pickle jar and fill it half full of water. Take two or three sheets of your household toilet paper and place in jar of water. Attach lid and shake for 10 seconds. If you end up with little bits of toilet paper in the jar, your regular paper is RV safe. If not, buy some other brand and try again. We use Cashmere 2 ply and it saves use big bucks over buying "RV" toilet paper.
Old 09-04-2014, 09:22 PM   #18
2014 27' Flying Cloud
Over-the-Horizon , Bliss
Protagonist... why do you say to not use a macerator pump or Sewage Solution? I ask because I take delivery of my Flying Cloud this month and I sure don't want to do anything stupid.
Nimbus is offline   Reply With Quote
Old 09-05-2014, 07:24 AM   #19
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My new to me Safari came with 4 packs of 4 Scotts RV tp. I do not think I will have to by any for some time. As to the Sewer Solution. I acidently tossed a sheet of paper towel in the the head. The SSF shredded it to bits and passed it right thru the hose. Not something to make a habit of doing.
MICHAEL
Old 09-07-2014, 10:20 AM   #20
2011 23' Flying Cloud
Durango , Colorado
Originally Posted by jbauer View Post
Still shopping for my first Airstream but the rule on boats I have sailed has been been put anything you want in the head (OK, that's the toilet) so long as you've eaten it first. Just saying.
No matter where you go, there you are.
You'll find a big difference in this regard between the Airstream and the boat (and I've had to tear down marine heads myself, so the same rule applies on our boat). Hundreds of dumps with our Airstream using a standard flex hose (Rhino brand is tougher) without problem. Sloshing water in the black tank works well, so add a few gallons after dumping before you drive away. I do flush my coffee grounds followed by a pot of soapy water, and have never noticed an odor.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 09-07-2014, 11:10 AM   #21
jbauer's Avatar
Thanks JamuJoe-
I guess the difference might be on the boat we are pumping the waste to the holding tank where as in the AS it's more of a direct deposit, if you'll pardon the turn of phrase. 😉
jbauer is offline   Reply With Quote
Old 09-07-2014, 11:21 AM   #22
Pat Conway's Avatar
On our l988 it's a slider valve with a rubber gasket on the black tank. Paper fragments will stick to it and before long you will have a first class mess when you least want it, because after a period of time you will be unable to get the valve to completely close and the liquid will run out. You want tissue that will dissolve as completely as possible, so yes using RV paper is helpful. Best yet is to only use your toilet for #1 unless it's an absolute emergency. Doing this, you can go one better then, and place your paper in a trash bag. It's only a recommendation, we don't have a macerator and use the traditional slinky.
Paula is right about schooling people on the toilet. Someone on the forums bought a trailer, only to get it home and discover it was completely clogged. PO had been using it as a guest cabin in the back yard. It happened to my Dad's trailer. His aunt had been living in it in the summer time. He had one hell of a clog caused by what he later found to be caused by her being allergic to toilet paper and using strips of old sheets.
Sun City Center, FL
1988 25' Excella
Pat Conway is offline   Reply With Quote
Old 09-07-2014, 11:38 AM   #23
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
My bunkhouse has a macerater toilet - waste goes down through macerater then to black tank
I use Scott's single sheet rolls from costco - no problems yet
As long as the darn fancy macerater toilet never stops working all the sudden I'll be happy - don't hold your breath
We use the sewer solution - and even drain the black tank with the sewer solution with gravity alone without issue
PharmGeek is offline   Reply With Quote
Old 09-07-2014, 04:48 PM   #24
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
I think one problem that a lot of folks have is they just don't have enough water in their black tank. Ever use a porta potty, they are full of water. I don't leave the dump station until I pour at least 10/15 gallons into the tank (using a "johnny chock" and a bucket"), I could make a case for putting even more water than that in the tank. I also use a tank treatment. When dumping, I run a bucket or two through the tank and hose before closing the valve and putting the water and treatment in there. I have never had one problem with smell, clogging etc. over the years. Of course that is just my experience in my trailer, your mileage may vary and I have also now jinxed myself and will be posting on here after the next trip asking about tips on how to clear clogs LOL. As I mentioned earlier I use the Scotts RV/Septic friendly stuff from Costco.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 09-07-2014, 05:01 PM   #25
Remax gal's Avatar
2014 27' FB Eddie Bauer
Lake Placid , Florida
I had an elderly camper tell us that when he leaves a campground, he pours about 3-4 bags of ice down the toilet and lets it slosh around while he drives. He swears it rids all the paper and the "other stuff" and keeps everything nice and clean. Of course he dumps again just before he gets home. We tried it and were very pleased.
Let the good times roll! Laura & Tom
Let the good times roll!! Laura
Remax gal is offline   Reply With Quote
Old 09-07-2014, 06:09 PM   #26
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
“RV Geeks” have a video about cleaning the black tank and they show that even after they flush it many times...the ice trick breaks up even more.....
**Note: do not do ice down through a macerator toilet, I presume it could damage things greatly**
Old 09-07-2014, 07:29 PM   #27
Soyboy's Avatar
1999 28' Excella
Images: 44
Yes I have heard that ice tip too. Sounds like a good idea.
1999 28' Safari
TAC MD-6
AIR 4534
Old 09-07-2014, 07:51 PM   #28
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
So you aren't supposed to use toilet paper, or you're supposed to eat it first? Only on a boat? I'm confused
DryFly is offline   Reply With Quote
Best price on toilet paper sharptalk Plumbing - Systems & Fixtures 16 07-22-2009 05:32 AM
The Great Toilet Paper Debate moosetags Sinks, Showers & Toilets 26 02-19-2008 08:59 AM
Toilet paper and other things campcollector Waste Systems, Tanks & Totes 45 12-08-2006 09:22 PM
Important papers: toilet paper cover Safari64 General Interior Topics 15 03-17-2006 07:04 PM
Toilet Paper: Is scotts ok? TBKP's Overlander Plumbing - Systems & Fixtures 11 11-29-2002 08:03 PM
