Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 10-03-2016, 02:05 PM   #1
Cispook's Avatar
2017 27' Flying Cloud
Greer , South Carolina
Toilet Empty When Towing
Not much of a topic line ... I was wandering how many folks turn off the toilet water valve and empty the basin prior to towing? Avoiding the inevitable splash splash that comes with not doing so.
Pro and con always welcome
Regards
2017 27FB FC
Cispook is offline   Reply With Quote
Old 10-03-2016, 02:08 PM   #2
2012 25' FB Flying Cloud
Parker , Colorado
The toilet seal need liquid on it at all times, otherwise it drys out. The little amount thats left in the bowl never splashes in mine. And it's another step once I stop.
There is already enough work
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
mfrez is offline   Reply With Quote
Old 10-03-2016, 02:18 PM   #3
Naper's Avatar
Loretto , Ontario
I always leave a little water in the bowl, I do however turn the pump off and release the pressure buy turning on a tap.
Naper is offline   Reply With Quote
Old 10-03-2016, 02:27 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My water pump is usualy turned off when not using, definitely powered off on the road. I always try to keep a little water in all the drain traps and some in the commode. Seems to help keep unwanted odors down.
MICHAEL
Old 10-03-2016, 02:32 PM   #5
Mantua , Ohio
Turning the valve off is not something I would do. We stop,often to use the toilet and having to turn the valve on each time would be impractical. We do turn the water pump off. Close the lid on the toilet.
Old 10-03-2016, 03:06 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have never heard of that, never done it with multiple trailers and never had a problem. I am curious what is this based on?
Old 10-03-2016, 03:11 PM   #7
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
After flushing, my toilet bowl is almost empty. Never had anything splash out. At least nothing has splashed out due to trailer movement. Men will be men, after all. I do turn off the pump whenever the trailer is moving.
McDave is offline   Reply With Quote
Old 10-03-2016, 04:16 PM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We always leave about an inch of water in Lucy's toilet bowl with a splash of Pine Sol while underway. This has worked well for us over the years in keeping black tank odor at bay. In over 160,000 miles of towing, we have not had any trouble with water jumping out of the bowl.
We also make sure that water is always in the drain traps. We also keep the rubber plug in the shower drain while underway.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 10-03-2016, 04:28 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
What Naper said.
2019 Ford Expedition Platinum
Old 10-03-2016, 04:39 PM   #10
1979 23' Safari
Wayland , New York
Yep. Had the problem. Pump off before leaving then I would flush the toilet to drain the water in it as well as depressurize the system. Found that water would slosh out of the rim when starting towing, so I now stop after moving a few hundred feet to flush the water again. After that no more sloshing out.
Old 10-03-2016, 05:12 PM   #11
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Our trailer has had two different toilets over the years and we had a Class B van with a toilet and none of these had a splashing/sloshing problem. It's difficult for me to imagine what's going on with your "loo" that you need to take these preventive measures.
After I flush the toilet there are only a few ounces of water remaining. That small amount of water has never caused a problem. Do you have more water than that in the toilet after flushing? If so, maybe that's the problem.
As others have said, we do make it a point to turn off the water pump when we're not in the trailer. We don't relieve the pressure in any way. Similarly, when at a campground, we turn off city water when we leave the trailer for more than just a few minutes. We do this to avoid what might happen if something developed a leak while we're not in the trailer. This really doesn't have anything to do with how much water remains in the toilet after flushing.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 10-03-2016, 06:40 PM   #12
Rich and Kat
AIRHEDS's Avatar
Alexandria Alexandria , Virginia
Dangit... I learn something new here every day. Need to pour some water into my bowl now while in storage ...
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 10-03-2016, 07:45 PM   #13
2019 27' Globetrotter
Missouri Valley , Iowa
Lumatic, my '89 Excella would not hold water in the toilet bowl. A couple years ago when this first occurred, I read (maybe on this forum) that cooking oil in the bowl would soften the seal. When in storage that winter, I poured some cooking oil into the bowl. Later, that was gone so I added more oil. In the spring with warmer temps I added more oil. Ever since then - the bowl holds water like it should!!!! I have a friend that used silicone grease on the seal at the end of the season. This, too, will keep the seal soft and waterproof.
Dan
Farmer Dan is offline   Reply With Quote
Old 10-04-2016, 05:40 AM   #14
Cispook's Avatar
Brian
My wife is going to start with the pine sol this coming week on our trip. Thanks for the feedback everyone.
2017 27FB FC
Old 10-04-2016, 11:43 AM   #15
Parker , Colorado
Airstream Guide to Maintenance that I bought discusses this. As another poster suggested, you can grease the seal when you aren't using the trailer, or as I do leave water in the bowl during the summer and RV antifreeze in it over the winter.
Old 10-04-2016, 01:33 PM   #16
1967 26' Overlander
Spartanburg , South Carolina
Dan
Well said. Never use any grease other than silicone on a toilet bowl seal as regular grease and vaseline will damage the seal. As to water splashing, some toilets leave more water in the bowl after flushing than others. We have had several different ones over the years and have found it necessary with some to flush the extra out after turning the pump off. Vegetable oil in the bowl for winter storage is good practice.
Jacob D is offline   Reply With Quote
Old 10-04-2016, 03:04 PM   #17
"Silver Shrek"
drairstream's Avatar
2000 27' Safari
Crestwood , Kentucky
oil might break down the seal over time. Silicone sounds better
drairstream is offline   Reply With Quote
Old 10-04-2016, 03:51 PM   #18
2015 30' FB FC Bunk
Ayer , Massachusetts
Depends on the toilet. Ours has a 'dry flush' feature specifically for flushing the bowl empty prior to towing. It's made to do that. It's a macerator toilet.
Our old camper had a ball valve, had to leave fluid in it.
Ted S. is offline   Reply With Quote
Old 10-04-2016, 04:14 PM   #19
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
We leave approx. an inch of water at the bottom of the bowl, never had a problem. We always turn off the pump when towing, except four days ago forgot to do so after stopping in Ft. Bragg, CA. By the time we got to HWY 101 at Leggett we found the sink faucet had turned on and off due to the incredibly rough and switchback road for 22 miles plus the sink stopper had set itself allowing the sink to fill with water. According to the fresh water tank level the sink dumped about five gallons of water onto the floor. Now where did I put that check list.....
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 10-04-2016, 09:39 PM   #20
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I think mine dried out because it does not maintain the water fill. How do I fix?
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
HELP - Need to empty LP tank for export ViewRVs LP Gas, Piping, Tanks & Regulators 7 03-16-2010 07:23 PM
Towing an empty 31' shell bugz42 Towing, Tow Vehicles & Hitches 16 04-07-2009 01:42 PM
? Empty Weight -- '84 Excella 34' ? TOM CRUMP Our Community 3 05-04-2006 08:30 PM
Black Water Tank Shows Full When Empty yochanan Waste Systems, Tanks & Totes 12 01-21-2006 10:41 PM
What's wrong with an empty house? yukionna Off Topic Forum 2 09-12-2005 02:38 PM
