Old 09-26-2009, 08:39 AM   #29
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Just for the record, it's not "moniters", but is "monitors".
Gene
Old 09-26-2009, 06:22 PM   #30
2000 34' Limited S/O
Jamestown , North Carolina
Thanks. I can spell but can't type that well.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 09-26-2009, 06:29 PM   #31
Master of Universe
Gene's Avatar
Sometimes I can't speel, sometimes I can't tipe.
Gene
Old 09-26-2009, 06:41 PM   #32
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I thought it was misspelled because there was already a thread with it spelled correctly.
Regards,
Ken
Old 09-27-2009, 08:44 AM   #33
2005 28' Safari
, Georgia
Originally Posted by henw View Post
The Pressure Pro website states that updates are at 5 min intervals.
Does that mean you have to wait five minutes to know if a tire is deflating?
Tom W
I understand the alarm will report without a delay.
Pops
Pops is offline   Reply With Quote
Old 10-02-2009, 05:42 PM   #34
After reveiwing all the options, I just purchased the Pressure Pro system. I'm sure I'll be back with questions as I learn how to use it efficiently.
WBCCI #4358
Old 10-02-2009, 07:42 PM   #35
Don McKelvay
Don McKelvay's Avatar
1994 34' Limited
London , Ontario
Congratulations and I am sure you will love them as much as the rest of us who own them. They give great peace of mind as well as being a wonderful safety item. Relax - read the manual and don't get too frustrated doing it for the first time - I found it a little confusing.
Not sure if you bought the locking washers - they may have changed that system to secure the monitors to the 'metal' valve stems (I had a rubber stem break due to the centrifugal force and then replace all the stems with metal ones) which simply makes it much more difficult if someone decides to play games and take them off.
Let us know later what you think of them.
Cheers,
Don
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
Don McKelvay is offline   Reply With Quote
Old 12-01-2009, 09:17 PM   #36
Central , Mississippi
Originally Posted by HiHoAgRV View Post
Don't take my post as the final word on this technology since I've only seen the respective adverts and posts about the products here on the web. I just installed a HD system from Hawkshead.
SEMI TRUCK TPMS, RV, MOTORHOME TPMS, COMMERCIAL VEHICLE TPMS, HEAVY EQUIPMENT, BUS, TIRE PRESSURE MONITORING SYSTEMS
The things that swayed me this direction were price, replaceable sensor batteries, temp monitoring and some favorable indepth research from a friend.
I've only had them out for a single short outing but so far they seem to perform as good or better than advertised. For $408 I got 6 sensors, 6 metal valve stems, the monitor, various mounts AND the optional amp since I have a 34' trailer. At this point I have not installed the amp since they sensors work even with the truck parked 20-30 feet in front of the trailer. I will probably send the amp back for a refund bringing the cost to under $350.
Only time will tell!
TIME!
Having done a couple of outings, including a 1,700 mile loop, I am thrilled with the system. I have not needed the amp, but I did keep it. I figure I'm kinda on the upper length limit and will go ahead an install it.
The rechargable headunit is nice, I can hold it as I air up the tires and don't need a gauge.
The temps pretty much mesh with my laser infared gun that I use to shoot the hubs at each stop.
No complaints, great price, flashing red lights...what else is there to say?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Minuet tire pressure Dan S All Argosy Trailers 12 04-30-2012 08:28 AM
Tire pressure trmiller Tires 46 08-06-2011 04:09 PM
Tire Pressure Sensor??? pappy19 Tires 9 07-14-2011 02:39 PM
Tire pressure GAT Tires 5 02-07-2011 02:36 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
