Old 08-02-2010, 05:15 PM   #1
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
tire pressure monitoring
Recently I purchased the Pressure Pro monitoring system and like it very much but for one thing. I cannot find a dashboard mount for it. Does anyone have a suggestion? Their visor clip will not work for me and I don't want to make any holes in the dash.
jfowler218 is offline   Reply With Quote
Old 08-02-2010, 05:35 PM   #2
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
We have the same question
Please let us know if you find something for mounting the monitor.
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 08-02-2010, 05:49 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Did yours come with suction cups? Ours did...they fit on the clips...if you didn't get them you can probably order them. Since the rear view mirror isn't really functional while towing, we attach the monitor to the face of the rear view mirror with the two suction cups...then take it down when we reach our destination... We can still see enough in the mirror to know the AS is still there! This works very well for us...
TB & Greg and Abbey Schnauzer
#3954
Old 08-02-2010, 06:02 PM   #4
2010 25' FB Flying Cloud
Powell , Ohio
I velcroed mine in the back window of the truck. I can see it from the rear view mirror. This also allowed the antena to be closer to the trailer.
tbaugh is offline   Reply With Quote
Old 08-02-2010, 06:04 PM   #5
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
If I recall, it's illegal to mount things to your windshield in California.
For convenience, I bought one of these (not same brand) and used the suction cup mount that came with my gps. I drilled a hole thru the pivot of the gps mount and wired the pressure pro monitor to it. I then glued the suction cup moun to the bean bag holder. It works pretty well.
On edit: attached picture
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 08-02-2010, 06:27 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The California law has been changed for many things including GPS: V C Section 26708 Material Obstructing or Reducing Driver x2019 s View
Since I have my Doran 360 monitor located in the wrong place, looks like I'll never go to California again. And Minnesota and NJ may have laws prohibiting windshield mounts, or used to.
The locations permitted in Cal. are pretty hard to get a wire to, or if you have a sloping windshield couldn't work at all. GPS is specifically referred to in the Cal. law, so radar detectors and TPMS monitors wouldn't be permitted.
If you follow the law, and can't mount it on your dashboard (the mount won't stick to my dashboard), then I suppose you have to mount it somewhere you have a hard time seeing it so you'll have to take your eyes off the road. The permitted locations in Cal. are in either the right or law lower corners of the windshield where you'll be looking away from the highway.
Gene
Old 08-02-2010, 06:49 PM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I don't know what your TV is, but ours is a 2009 F150. At the top of the radio stack is an opening/shelf. I cut a piece of wood to fit in there, and added velcro strips to the front of the wood and the back of the Pressure Pro monitor. It works great!
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 08-02-2010, 07:23 PM   #8
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Our Silverado has the same opening in the radio stack and that worked great for us. Recently and in order to free up some room in the storage tray just below, I mounted ours a bit higher on the radio stack using Velcro. Works great there as well.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 08-02-2010, 08:21 PM   #9
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
jfowler218.......I have a 2006 GMC Sierra 2500HD and used an open space on the dash to mount my monitor. Not sure if this would work on your vintage tow vehicle.
Name:	Pressure Pro 2006 GMC.jpg
ID:	108026   Click image for larger version
Name:	Pressure Pro GMC-2.jpg
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 08-02-2010, 08:50 PM   #10
Images: 59
Similar idea. I mounted a removable aluminum bracket in the opening below the radio. First a U shaped aluminum piece riveted inside the opening. Then a bracket that slides in between the aluminum and the plastic, and the Pressure Pro is velcroed to the bracket.
Easy to remove when not trailering.
ID:	108029   Click image for larger version
ID:	108031   Click image for larger version
Old 08-02-2010, 09:08 PM   #11
_
... I cannot find a dashboard mount for it.
there are DOZENS of cell phone, gps, blackberry, i pod sized, generic HOLDERS...
that attach to the 12v PLUG, dash air vent, cupholders or 'tacky' to the dash...
there are also sticky 'pouches' that use the suction cup mounts without attaching to the window glass.
some have goosenecks or flex tubes and other don't.
search 'cell phone/gps mounts' or visit a bestbuy, wal/target discount store or radio shack...
i've seen perhaps 20 that would work fine in this application.
typically 25-40$.
cheers
2air'
Old 08-02-2010, 09:22 PM   #12
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Air vent mounts
I bought two mounts that hang on the louvers of the air vents on the dash and clamp onto the top and bottom edges of whatever is mounted. There is actually a hole for the andtenna on the TPS. I use one mount for the TPS, the other for a big 7" diagonal Magellan GPS. The mounts have hooked fingers that go between the louvers and hook on the rear edges. I haven't found that the mounts appreciably interfere with air flow since they stand off enough. They actually keep the vents from blowing right in my face. The mounts also do not restrict access to the radio or other controls.
I bought my mounts at Cabellas, though I have seen them in Target, as well. About $20.
It is late now, but I can post a photo tomorrow.
John W. Irwin
WBCCI #9632
Old 08-03-2010, 03:26 AM   #13
ZoominC6's Avatar
Colleyville , Texas
It is late now, but I can post a photo tomorrow.[/QUOTE]
I, for one, would love to see your solution John as we have the same tow vehicles. Thanks in advance.
Old 08-03-2010, 06:47 AM   #14
_
GPS & Netbook Accessories Mounts Mobile Grip-IT Vent Mount Kit
Air Vent - Vehicle Mounts for GPS, MP3, Cell Phone, iPod, iPhone, Blackberry - | Bracketron
http://www.proclipusa.com/home/home.aspx
cheers
2air'
Dill Tire Pressure Monitoring System wingfoot321 Tires 3 12-14-2011 07:03 PM
Tire pressure monitoring kittrik Tires 13 09-26-2009 01:42 PM
Tire pressure monitoring. Doohickey Our Community 13 08-17-2009 02:21 PM
Tire Pressure Monitoring system chirocruzr General Motorhome Topics 10 04-17-2009 09:08 AM
PressurePro Tire Pressure Monitoring Systems PatMcFall Commercial Listings 0 12-28-2007 02:04 PM
