Old 09-15-2017, 06:15 PM   #1
2008 28' Safari
Kirkland , Washington
Tips for being stuck in snow???
Just this morning I was concerned about driving too slow on the Interstate. Now, I've stopped all together because it's snowing! Middle of Montana, middle of September.
This is supposed to be my shakedown cruise, but snow was certainly not expected. Ironically, I got an RV because I wanted to get away from the cold completely.
I contacted my Airstream dealership about what I should do, and they only thing they recommended is to empty the holding tanks.
Now that I'm going to stay in the trailer during the night, I'm told that since I'll have the heat on, I don't have to worry about the tanks freezing. Right now the only tank that is full is the fresh water tank.
Thoughts from the experts? It's going to go down to 32 degrees tonights according to the forecast.
bliss is offline   Reply With Quote
Old 09-15-2017, 06:21 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
tips for being stuck in snow???
Nothing to worry about. Just run the gas furnace and nothing will freeze no need to empty tanks in fact its best to have them full.
I love winter camping - just be careful out on the roads - if your are forced to drive on snow / ice surface then consider staying put. Otherwise at a minimum disengage your anti-sway and proceed with caution!
wulfraat is offline   Reply With Quote
Old 09-15-2017, 06:33 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Run the gas heat. Unhook and drain the water hose to the trailer. I have a friend who says "Propane is cheaper than plumbing". Wait tell the snow melts. Sounds like a good first trip to me.
Old 09-15-2017, 07:24 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
You need not worry as it probably won't be at freezing long enough for your plumbing to freeze.
Best to have water in the tanks any way... Thermal mass.
Hunker down and enjoy the experience!
Old 09-15-2017, 07:25 PM   #5
Lily&Me's Avatar
Normal , Illinois
32 degrees is nothing....you can manage that easily with your furnace on.
Once you get into the teens, that is a bit more challenging.
Think of it as an adventure.
Maggie
Old 09-15-2017, 08:06 PM   #6
2008 28' Safari
thanks everyone.
So the furnace is running. I also have a heat pump via the A/C. Is the furnace preferrable to the heat pump, and if so why?
Reason is, I'm noticing that my battery is being run down when the furnace is on, even though I'm plugged into shore power.
Been "living" in the airstream for a week, and this is the first I've seen the battery meter change from green. It's now red.
Thoughts on this one?
Old 09-15-2017, 08:07 PM   #7
2008 28' Safari
Why disengage the anti-sway?
Old 09-15-2017, 08:09 PM   #8
2008 28' Safari
"Propane is cheaper than plumbing" - ha! good way to think about it
It's been a ... very interesting first trip. At least a dozen new challenges every day. When one is solved, another arises!
Old 09-15-2017, 08:10 PM   #9
2008 28' Safari
Good point. Snow and storm is supposed to pass by Sunday.
Old 09-15-2017, 08:10 PM   #10
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Bliss,
You want to run the furnace when it is below freezing because it circulates warm air around your tanks. The heat pump does not warm your tanks.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 09-15-2017, 08:11 PM   #11
2008 28' Safari
Maggie
ha! Yes, it is an adventure for sure
Old 09-15-2017, 08:12 PM   #12
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I'm thinking the AS people probably were trying to reduce your trailer weight when towing in slippery conditions; which is why they suggested empty holding tanks.
I wouldn't worry about plumbing freezing at 32 degrees as it would take many days before the temp in the trailer and tanks matched the outside, especially just the overnight temp.
Relax and enjoy; just remember to allow for more room between you and others when driving in slippery conditions and if possible have one hand on your brake controller to add a bit more braking to the trailer.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Isuzusweet is online now   Reply With Quote
Old 09-15-2017, 08:20 PM   #13
2008 28' Safari
Originally Posted by DaveP View Post
Bliss,
Oh, great. Many thank!
Now, for the battery issue... manual says the furnace is "powered by 12 volt current from the batteries or power converter when plugged into city power."
Since I'm operating at the moment like I've hooked up to city power (all the lights all, television going, etc) I could be running down the battery. How can I tell if I'm hooked in or not? The power surge protector is between the electrical outlet and the cable that's plugged into the trailer. All seems well, except the furnace part.
Old 09-15-2017, 08:32 PM   #14
1979 23' Safari
Wayland , New York
Do other 120volt appliances work. Like the microwave, that'll let you know if you've got 120v going into the trailer. Check all the circuit breakers move them FULLY to the off position then back to the on position. You may have a tripped breaker.
For some reason it seems like the converter isn't getting power or charging the batteries.
I wouldn't be afraid to go politely ask someone for a little help, if your batteries are red you likely won't have heat through the night unless this gets figured out.
Make sure use/store switch is in use position if you have one.
Yet even more tow opinions being solicited: Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 20 09-20-2017 05:43 PM
How much snow is too much snow? KSA63 Winterizing, Storage, Carports & Covers 43 02-19-2017 04:20 PM
Snow and SNOW.. 53flyingcloud Off Topic Forum 9 01-23-2005 02:32 PM
Door locking after being slammed shut TomD32 Doors & Locks 4 06-25-2003 09:56 AM
My Suzuki Samurai dropped into gear while being towed williamhenshall General Motorhome Topics 16 04-07-2003 09:30 AM
