09-19-2017, 04:24 AM
#41
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by wulfraat
.....snip Otherwise at a minimum disengage your anti-sway and proceed with caution!
I wouldn't recommend the disengagement of a WD style sway control......friction bar ok.
The only other tip I can think of......Austin TX, San Diego CA
Goog Luck
09-19-2017, 06:31 AM
#42
Lin
, Ne
Originally Posted by bliss
Thoughts from the experts? It's going to go down to 32 degrees tonights according to the forecast.
As soon as the roads clear head to warmer climate and learn how to operate your camper.
09-19-2017, 09:04 AM
#43
ObviouslyKnot
KAILUA
, HI
Television - other plug is blocked so Inverter only. I wonder why he did that. o
I have several outlets, TV included, that are marked with the Inverter Label, but they all work without turning on the inverter when plugged into shore power, as designed. Perhaps previous owner (PO) decided to defeat that option, or inadvertently did, when he replaced the stock inverter.
A good question for the next service guy or helpful camper that knows more about trailer wiring.
Inverter: 12v DC to 120v AC.
Converter: 120v AC to 12v DC.
More info here: http://www.rv-dreams.com/rv-electrical.html
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
09-19-2017, 09:49 AM
#44
ObviouslyKnot
KAILUA
, HI
Driving on Slippery Surfaces??
Originally Posted by guskmg
Yes, the friction sway control, as recommended by manufacturers, should be disconnected on slippery surfaces. They make hitch system too rigid, i.e., it won't bend in the middle very well, if at all.
I have camped all winter in Omaha, NE, with no difficulties. Just use a short heated water hose and only empty holding tanks on days when it is above freezing. Have fun, I too like winter camping.
guskmg
So, on slippery surfaces, the trailer coming around to pass the TV is better?
or
1) Don't drive when slippery.
2) Invest in PPP if you want to not worry about changing your lashup on slippery days. :
Possible winter cross-country trip this year, want to learn.
09-19-2017, 12:30 PM
#45
2018 27' International
carbondale
Back to the sway control bars for a second. I have an Equal-i-zer system and I called the manuf. after reading above about driving in slippery conditions and they said they recommend leaving it on. Too much info. sometime on the internet. So, who's right?
09-19-2017, 12:57 PM
#46
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Loosen this style....
09-19-2017, 01:07 PM
#47
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
09-20-2017, 12:40 AM
#48
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento
Originally Posted by james.mileur
Good to know NAVY.. me be AIR FORCE... hee hee... go AF...
09-20-2017, 12:51 AM
#49
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento
Question... some of you say you have inverters in your AS... I know that their is a inverter that works both ways... i.e takes shore power and converts it to 12 volts DC... to power up the RV... and charge the batteries.... then when shore power is gone... it takes the 12 volts DC and turns it back into 120 v ac 60 cyc...
The question is... because it does this..
does the refrig auto controller then switch the refrig back from propane to 120 v ac thinking that it has shore power... yet your running off the 12 volt batteries... (could this be part of our newbies problem and not know it)
While traveling.. is the inverter always on so as to have the trailer powered up with 120 v. ac ?
Seems to me that their should be some control of the inverter as to when it should come on... and/or be off...
The effecency of going from 12 volts to 120.. to run a TelVison these day is not their.. most flat screen TelVisons... can and do run on 12 volts DC... and use a wall wart to convert the 120 volts ac to 12 volts DC... which is a better way to go .. and to run the microwave or convection oven... from the inverter.. really suck... the life out of the batts... one might ponder... some of these thoughts...as to batt life and useage
09-20-2017, 03:01 AM
#50
2015 23' FB Flying Cloud
2016 27' Flying Cloud
Rapid City
, South Dakota
The heat pumpm won't work below 50. Run the furnace.
09-20-2017, 03:59 AM
#51
Dazed and Confused
Hillsburgh
, Ontario
Originally Posted by GM Airstream
So this leads us to the question...
when you need help.. who ya call... the chemist or the engineer...???? (grin)
Neither; I call my friend with little formal education and decades of life experience.
Bliss may have forgotten more than we know in many areas.
Cheers
Tony
09-20-2017, 06:03 AM
#52
2016 27' International
Jasper
, Georgia
Your gfci is likely tripped if no power to any 110v outlets. Check to see if the gfci in the bathroom (thats where mine is) is tripped.
09-21-2017, 12:12 PM
#53
2008 28' Safari
Fanning Spring
Haven't tested the other Inverter outlets, will do so later to see if they work with the Inverter off.
Though from Joe's comment, it looks like the Inverter outlet for the television was an Airstream thing, not previous owner?
In the scheme of things, television is not a priority, just a distraction, something to have on and was easier to flip on than the stereo. I have not really watched television in years, will only use it as a monitor for work when I get all the computer stuff set up.
09-21-2017, 12:25 PM
#54
2008 28' Safari
Fanning Spring
Thanks. But half the outlets worked, half did not. Had a type of GFCI I've never used before, but have now.
09-22-2017, 08:48 AM
#55
2017 27' International
Lake Havasu City
Hmmm😏 my first cold night up north I couldn't get my furance to turn on. Was ready to give the AS dealer heck in the morning. I was hooked to shore power, no heat...spent most of a cold night checking breakers, GIF, when suddenly I remembered i forgot to flip the breaker switch on the RV Parks electrical post after hook up. Very humbled but I will never make that rookie mistake again. Check easy stuff first...beware of operator error, especially when first starting out. Good luck, NO BAD DAYS....[emoji41]
