Old 10-17-2016, 11:02 AM   #29
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
AIRHEDS: I had the same problem with the 7-way extension cable. I modified the Propride so the cable doesn't get caught/cracked when making deep turns....... Yes, I learned the hard way too. I see you're attending Alumalina. If you have time, hunt me down. I'll PM you my TEXT number.
glcmranger is online now   Reply With Quote
Old 10-17-2016, 06:04 PM   #30
1976 25' Tradewind
Kimberton , Pennsylvania
About 5 degrees
In my leisure career of driving a big rig I was fortunate to learn a backing up rule from a champion truck-rodeo driver. While teaching us how to back up a tractor and trailer through a serpentine course he pointed out that in any backing maneuver you should only turn the front wheels about five (5) degrees in either direction. How long you hold the turn while moving in reverse is the skill.
BicenTw is offline   Reply With Quote
Old 10-17-2016, 06:40 PM   #31
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Thanks for sharing, it's not easy to admit when this happens for fear of a flood of I-told-you-so's and I'm-way-smarter-than-you's. Could happen to anybody, we'll be double extra careful about this in future.
Originally Posted by FCStreamer View Post
So I was backing up to a campsite today and I heard a"cruuuuuuuunch". I was surprised as I didn't think I was close to hitting anything,
Turns out the steering angle was too steep. The corner of my truck struck the front rock guard. The rock guard is dented. The rear right window of my truck is busted.
Valuable (and expensive) lesson learned. You can hit your trailer with the corner of your tow vehicle when backing up of your steering angle is maxed out. Watch for that. Don't be like me.
The preceding was a public service announcement...
Rocinante is our 2014 International Signature 27FB
Old 10-18-2016, 05:23 AM   #32
2016 FC27FB - F350 2017
2016 27' Flying Cloud
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
That sounds like great advise and will follow it. As a newbie, I can take all the info I can get. My personal challenge here is backing up into an uphill, serpentine, uphill driveway (to my house). I was able to do it with lots of help from my wife behind the rig (Marriage-Saver walkie talkies headsets) and the short wheelbase LR4, only had to pull forwards to correct angle twice. Aware that my LR4's tongue weight carrying (550) is about 50% short of the specs requirement for the TV, I am now in the market for either a RAM or Fort trucks. Tested both from 150 to 350. I like the F 350 the most (shinny toys, I am a guy after all!) Now, the longer wheelbase of anything beyond the 150 in both brands require a larger turning radius. How will this affect my ability of backing uphill my FC27? I expect it will reduce it. Anyone has an insight on this? I have to buy next two days, I am looking at 2017 models.
Vitaver is offline   Reply With Quote
Old 10-18-2016, 05:48 AM   #33
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Longer wheelbase has a big impact on your ability to maneuver in reverse.
Look at the turning diameter of the tow vehicle you are considering. One of the reasons I chose a Ram was the turning diameter...
Have fun shopping!
Bruce
Barely getting by, towing our 16' Bambi with our Ram 2500 CTD "Moby"!
Bruce B is offline   Reply With Quote
Old 10-18-2016, 01:57 PM   #34
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
You should talk with Andrew Thomson at Can Am RV before buying another vehicle. Your hitch receiver can probably be reinforced.
And, yes, a 160" WB pickup needs a helluva lot of room to turn around.
1990 35' Silver Streak
2004 555 Cummins
Old 10-18-2016, 03:37 PM   #35
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
A trick to make sure I am not jack-knifing my trailer into the side of my truck:
Use the rear view camera on the back of the truck to look at the relationship/closeness of the rear bumper, trailer tongue/a-frame, and weight distribution bars.
You can not turn too tight going forward, but you can definitely fold it in half in reverse.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-19-2016, 06:58 AM   #36
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
not sure your total layout but it might be better to pull the trailer up the hill vs backing it up up the hill. if you have room to maneuver and get turned around so you are driving down the driveway on way out. Or get a front mounted trailer hitch on truck or get a nice tractor with hitch on front etc.
that much slow going in reverse can burn your transmission fluid as you are really making the torque convertor spin and fluid can get HOT quick.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 10-19-2016, 07:20 AM   #37
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You are not alone.....
I jackknifed my 25 trying to get out of a fuel stop that I shouldn't have gotten into. $2K to the trailer and $1K to the truck. A guy who had partially blocked me in was guiding me back. I guess he had never heard the term "jackknife". So in addition to "always use a spotter", always use a spotter you can trust. I was watching him through the right rear view mirror but he wasn't watching the left side. I should have been checking both mirrors anyway.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-19-2016, 08:07 AM   #38
FCStreamer's Avatar
2014 30' Flying Cloud
While boating I learned a docking lesson that served me well. Whatever you do, do it slooooooow. So if (or when) you hit, the damage is lessened.
I brought that lesson over to Airstreaming. I was going very slow. The dent to the rock guard is minimal. I won't even worry about it. And the damage to the car was glass only. Although almost $1000, it's covered by insurance minus my deductible.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-20-2016, 06:07 AM   #39
1976 25' Tradewind
The right vehicle.
There are few if not any tools that are good at more than one job. Buy the truck you need and if your home driveway arrangement is so severe for navigating consider borrowing or renting a small wheelbase jeep for the reverse work you have to occasionally do in your driveway.
Old 10-21-2016, 06:34 AM   #40
FCStreamer's Avatar
Got my call from the dealer today. They're replacing the window as I type this. Yay! Glad this lesson is over with...
Is there such a thing as "hybrid" full-timing? mgriffrus Full-Timing 14 03-17-2013 03:09 PM
Didn't know there was such a thing as 14.5" rims 59toaster Wheels, Hubs & Bearings 1 05-04-2009 09:23 PM
How steep is too steep? Tin Diesel Towing, Tow Vehicles & Hitches 14 02-12-2007 01:03 PM
Is there such thing as a trailer jack? Alluminatrix Jacks, Stabilizers, Lifting and Leveling 10 06-05-2006 09:12 PM
Is there such thing as a 1958 Bubble? 58BUBBLE Our Community 10 08-03-2004 04:31 PM
