Old 07-19-2014, 09:08 AM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The OP might want to book a space for a thorough inspection and leak test so he is aware of any issues as he heads for home.
Old 07-19-2014, 09:59 AM   #16
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Excellent suggestion. Any idea what that would cost? I can give them a call on Monday.
MICHAEL
Old 07-19-2014, 10:10 AM   #17
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I meant my comment the way you took it.
If I had meant it the other way, I would have said "strangers and in-laws"...
Old 07-19-2014, 11:02 AM   #18
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Call them for current prices. We had the Seal-Tec leak test and their 27-Point Inspection done last fall and I believe it's around 6-7 hours labor for the two, in the neighborhood of $700-$800. If your wheel bearings need repack this is good time to do it because I think they pull the wheels to check bearing runout and brakes as part of the inspection.
I did it because the trailer was nearly two years old and warranty about to expire. And they check and adjust little things like propane gas pressure, which was low. They found several small leaks which they fixed that I had already identified with my Sonin Moisture Test Meter. I was well satisfied and maybe slept a little better afterwards.
We maintain our trailer well, but I like the idea of their experience looking it over well and checking for leaks. I'll probably do it every again every couple of years or so when passing near the area in our travels.
Doug and Cheryl
Old 07-19-2014, 11:21 AM   #19
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
Originally Posted by overlander63 View Post
If you are planning on having work performed at the service center, and there are spaces available, you can use the Terraport.
As far as just dropping by for a visit and using the Terraport, I think they look at that in the same way you would probably look at friends or relatives showing up for an overnight stay in your spare bedroom.
I was just there, and was told that if you are not getting work done, they will charge $10.00 per night. Free if they are working on your AS.
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 07-19-2014, 11:28 AM   #20
AWCHIEF's Avatar
Images: 33
Doug, price is steep but worth it if they catch any issues before they get out of control. Thank you
MICHAEL
Old 07-19-2014, 11:32 AM   #21
Mont Vernon , New Hampshire
They have wifi too!
bugsbunny is offline   Reply With Quote
Old 07-19-2014, 12:54 PM   #22
AWCHIEF's Avatar
Images: 33
Excellant, thank you
MICHAEL
Old 07-19-2014, 02:44 PM   #23
AWCHIEF's Avatar
Images: 33
Just got the new tires on the Jeep. Now all I need is one more check to clear and I can hit the road.
MICHAEL
Old 07-20-2014, 02:39 AM   #24
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I just got new tires in April in anticipation of our September trip to the mother ship. I've put 3,000 miles on my new tires.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-20-2014, 04:39 AM   #25
Gainesville , Florida
Good luck, see you at Ga Mt Campground this fall? Jim
Old 07-20-2014, 05:45 AM   #26
AWCHIEF's Avatar
Images: 33
It is not a done deal, yet! I guess I should of kept my reservation. Hopefully I can still get another spot.
MICHAEL
Old 07-20-2014, 06:11 AM   #27
m.hony's Avatar
2013 30' Classic
Yeah, I was thinking you should have kept your reservations until the time got here and you didn't have a trailer.
You will probably own a trailer before rally time. I would have said nothing and surprised everyone by showing up with a new rig unannounced.
TAC #MS-10
Airforums #70955
Old 07-20-2014, 07:12 AM   #28
Well Preserved
1993 21' Sovereign
I've done that before. It was a surprise, especially since they had canceled the rally...
Factory Tour - Camping at the Terraport GolfStream Our Community 22 04-05-2016 05:42 PM
Status of Terraport jackcat On The Road... 9 09-13-2014 03:19 AM
