Old 05-30-2015, 01:17 AM   #15
2000 30' Excella
2014 30' Classic
Princeton , Iowa
You will do fine. The big thing is not to drive too fast and watch it a little on steep inclines. The weakest thing is still the automatic transmission going up real long hills with your "foot on the floor".
larryglarson is offline   Reply With Quote
Old 05-30-2015, 04:34 AM   #16
1977 25' Tradewind
Florence , South Carolina
I pull my 1977 25ft Tradewind with a 2004 Yukon XL. It pulls it perfectly without any issues whatsoever. Mind you I have only towed it on flat grounds so far, no mountains at all.
With that said the weight of your proposed trailer is MUCH greater than mine (mine is around 5-5500 pounds), so that is not an apples to apples comparison. But I think I would feel comfortable with your proposed scenario myself if I took a few things into consideration:
1. Keep it slow. Don't be in a hurry to get anywhere. Plan an extra day (or two or three) for traveling.
2. Watch your temps, especially your transmission temperature. If you're vehicle is a 1500 series which I am assuming it is, you do not have a transmission temperature gauge but you DO have a transmission temperature sensor. You just need to get some way to read the data from that sensor. I use a ScanGauge II. Keep your transmission temps to below 190, and preferably below that (170-180 would be good.)
3. Along with the recommendation above, get a transmission cooler installed. As has been said in this thread previously the transmission is the weak link in these vehicles. They're not bad - but if you are towing more weight than what you are supposed to (you will be) then it is going to put even more stress on the transmission (and engine and suspension and...)
4. Know that you will be, technically, over your capacity. Just something for you to think about in regards to insurance, liability in case of an accident, and your own personal "comfort" with the whole situation.
-And Lastly-
5. Keep your brakes in top shape. I can not stress this one enough. I have no doubt whatsoever that this engine is more than capable of towing your rig. I have slightly less confidence in the transmission but I believe you'll be ok there too. But the brakes...you will need to get them inspected and repaired/replaced/tuned up often. This is not to scare you - you actually will probably (hopefully) never need the full capacity of your brakes as the Airstreams brakes will actually help you to stop. But what happens if the trailer brakes go out? You will need to be able to stop the whole rig with your vehicle brakes only. Using the advice above about going slow (and I didn't mention it but also make sure to leave lots of space in front of you) will help in this area a lot. But it's best to be prepared for a worst case scenario. I towed my trailer home about 80 miles the day that we got her without any trailer brakes and with brakes on my tow vehicle that were 110,000 miles old. I didn't have any problems though I am very glad that I didn't have any emergency stops that I had to make. It can be done - but it helps if you make sure your vehicle has brakes that are in tip top shape.
I was at Myrtle Beach State Park last October and was set up beside a nice couple from Canada who was towing their triple axle 34 foot Airstream with a new For Flex. It had been reinforced, worked on, etc... and I'm sure it could handle getting the trailer up to speed. My concern with that scenario would be the ability to stop the rig if the trailer brakes ever went out.
-And for my second lastly-
To top it all off - I hate to say this but you really won't know for sure until you actually get out there and tow with it. My gut feeling is that for occasional towing you will be fine. But know that you will be over the limits (possible legal ramifications?), you'll need to keep it slow, and you might end up having to do more work to your tow vehicle than you would otherwise.
With all of that in mind it is obviously up to you. I think I would do it myself but I would try to stay away from the mountains. And if it turns out that you are towing more than you had planned on you will be best to get a mid 2000's 2500 Suburban or Yukon XL (I like the 2000-2006 model years myself).
Good luck and have fun! Let us know what you end up doing.
ajcannon is offline   Reply With Quote
Old 05-30-2015, 08:02 AM   #17
Sioux Falls , South Dakota
Nearly any vehicle can pull something for a short distance. The bigger issue is stopping. A 3/4 ton pickup will have larger brakes than a 1/2 ton, as well as a heavier suspension and greater weight capacity. Remember that the weight of all passengers, tools, generator, lawn chairs, etc. that ride in the truck count against the truck's cargo capacity.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 05-31-2015, 03:20 AM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The one ton won't stop any faster for an equivalent payload. If braking is the worry it should be, then the trailer brake performance is what needs addressing.
Old 05-31-2015, 05:35 AM   #19
andreasduess's Avatar
1984 34' International
Toronto , Ontario
The 34' models from the 80's are light, track exceptionally well and have a comparatively low tongue weight.
We happily, safely, and efficiently tow our 1984 international with a 2008 Honda Odyssey. Full details can be found in the link in my signature, if you're interested.
To address the stopping argument, to say that larger trucks will bring a rig to a faster stop is categorically incorrect. If anything, the opposite tends to be true, as larger trucks, built for carrying loads, tend to come with a more primitive suspension setup and a high centre of gravity. Their stopping distance is almost always longer than that of a car, van or SUV. Adding a trailer does not magically increase their abilities.
If this is something you're interested in, there are a number of posts on this board that explain in detail how mass, momentum and speed affect brake performance.
andreasduess is offline   Reply With Quote
Old 05-31-2015, 07:29 AM   #20
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"Adding a trailer does not magically increase their abilities."
No, but adding a trailer certainly does "magically decrease" the stopping distance and all around performance of the lighter car or suv. If the trailer brakes do not work, then the stopping distance is a lot longer for a trailer with a lighter TV than a heavy TV.
Old 05-31-2015, 09:14 AM   #21
1994 34' Excella
Warren , Manitoba
If the older Suburban is in good shape and your purchase it, take it to a reputable transmission shop and let them check it, replace with synthetic fluid, add a transmission cooler and install a temperature gauge. If it needs a rebuild, that is the time to do it as well. Some of the older vehicles still pull very well and are cost effective. I pull with a 2002 3/4 Duramax and have no plans to replace it. I get better mileage than the newer models, and best of all, NO PAYMENTS!!!
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 05-31-2015, 09:31 AM   #22
ghaag's Avatar
2014 30' FB FC Bunk
2007 25' Safari FB SE
2014 Interstate Ext. Coach
Jonesboro , Arkansas
There are going to be members here much more knowledgeable, my only comments are from personal experience. I had the 2500 Suburban pulling a 30' and the transmission was just not up to the job.
ghaag is offline   Reply With Quote
Is the body seal sufficient to keep mice out? DHart Airstream Lifestyle 46 05-29-2015 10:14 PM
Sufficient Sway Bar Tension? Frank&Mike Hitches, Couplers & Balls 7 10-29-2012 04:37 AM
Is my GMC sufficient? macstrange Tow Vehicles 8 12-06-2011 02:59 AM
New 2008 airstream *dwr* ccd * fully self sufficient * eBay Watch Airstreams on eBay 0 06-15-2009 01:30 PM
New 2008 airstream *dwr* ccd * fully self sufficient * eBay Watch Airstreams on eBay 0 05-21-2009 12:00 PM
