What's the solution for a freezer door that, develops a "vacuum lock" and won't let you re-open it easily to, say, replace the ice cube tray that you just took out a moment ago to get ice cubes. I would think that there should be a vent somewhere to prevent this - but I can't find it.
in most Dometic units the main box vents via the drain tube for the defrost water, but I am not aware of any similar vent on the freezer. Interesting issue.
... I would think that there should be a vent somewhere to prevent this - but I can't find it.
It certainly seems that when the freezer door is opened and takes on a load of warmer moister air, the sudden temperature change when the door is closed creates a partial vacuum. It can take a substantial tug to get the door open again until the pressure equalizes which may take a minute. I've thought about drilling a 1/8" hole into the plastic door liner to function as a relief vent, but then considered that this "breathing" into the insulation may have some unintended consequences. We have decided it is better to accept it as is and wait a moment when the door will open more easily.
