03-10-2019, 11:17 AM
#41
2019 16' Sport
TACOMA
, WA
I'm new to RVin' but I HAVE made a few costly mistakes in my life. Doing the same pre-flight no matter where you camp seems paramount.
03-10-2019, 11:21 AM
#42
2011 30' Flying Cloud
Arvada
I generally will lower the stabilizers and the jack. Agree wholeheartedly about a reminder to raise them the next morning - but that is another answer to a question!
03-10-2019, 11:50 AM
#43
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Jack yes. Stabs no. We don’t mind how it feels with stabs up when we know we’re leaving the next morning.
03-10-2019, 11:57 AM
#44
2004 30' Classic Slideout
Fenton
, Missouri
I do, specifically for the fact that I have a slide out which requires stabilizer jacks down to prevent torquing.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
03-10-2019, 03:10 PM
#45
2013 20' Flying Cloud
2014 16' Sport
2019 23' Flying Cloud
Dunedin
Originally Posted by BAB
I simplify everything for a RON (remain overnight). I shut off the truck, set the parking brake, and that’s it. If I’ve got a pretty open view to the SW, I’ll push the button and let the antenna find DirecTV. (It’s always nice to see a familiar news program.) A lot of what we’ll do trailer-wise depends on distance to destination. We like to travel with full water and empty black/gray tanks so we can boondocks if the mood strikes us.
How do you get DirecTV without power?
“I haven’t been everywhere, but it’s on my list”.
Rosalita WBCCI #12814
Florida Unit #027, Southeastern Camping Unit #012, Florida Suncoast #129, Stella's Sisters, Grapes & Grains, Indie Streamers Save
03-10-2019, 03:11 PM
#46
2014 16' Sport
Dunedin
If you have your tow vehicle and trailer set up correctly, why do you have to put down the jack to level it out?? Isn't it already?
03-10-2019, 05:21 PM
#47
1976 31' Sovereign
Durham
, Ontario
I usually do put the stabilizers down and take the weight off the car by brining the jack up. I carry an 18 volt drill with a bit that fits the stabilizers. I can zip them up and down in about 5 seconds. I always look under the trailer on departure to make sure we're all good to go.
03-10-2019, 08:57 PM
#48
Green Cove Springs
Honestly, the only wrong answer is if you try to pull out in the morning without raising the stabs and/or jack that you lowered last night. Otherwise, it's all good.
03-10-2019, 09:57 PM
#49
2002 34' Classic S/O
sault sainte marie
, Michigan
I have a 34 Classic with slideout, and only put down the left front stabilizer to support that corner to extend the slide. Works perfectly.
03-12-2019, 09:42 AM
#50
1994 30' Excella
Franklin
, Ohio
When tired after long tow i get best leve if bed is good bounce not shuch a big deal if more than sleeping I relax hitch equalizer and lowe TT jack
03-12-2019, 08:01 PM
#51
2009 23' FB Flying Cloud
Miami
We just try to level as well as we can, no stabilizers or jack. The reason we are remaining overnight is because of time constraints. If we are groggy in the morning we don't need to remember a thing, just go forward and get safely on the road.
03-12-2019, 08:34 PM
#52
Sag Harbor
, New York
Flying solo ---> stabilizers up.
Co-pilot sleeping --> down.
03-18-2019, 08:50 AM
#53
2018 27' Flying Cloud
Spring
Keep it Simple
Agreed. Just pull over and enjoy having your mobile hotel room behind you with the comforts of home (your own bed). If you aren't staying, no big deal. Have done it many nights and it works fine. Lock out the steering wheel on the TV so nobody takes you for a ride (if staying somewhere where that could happen!)
03-18-2019, 09:01 AM
#54
Spring
Ooops
Agreed, nothing would be worse than starting your tow all groggy and without that first cup of jolt, and hearing the scraping and bending of pretty metal because you forgot something. Another thing that is valuable is similar to what I saw a buddy do with his Prevost conversion......right after he ripped his 50 AMP power cord off when pulling away from a quick RV park stop and thought he was running his gen when he in fact had plugged in right before passing out from driver fatigue......he also flies a plane and has a checklist on his yoke, and now has one right on his steering wheel on a small tablet so he can run through it before departing. It works. We all get tired and absent minded once in a while. Happy travels.
03-19-2019, 03:05 AM
#55
Sag Harbor
, New York
Plenty of steps have gone that route!
Don't ask how I know . . .
03-19-2019, 07:04 AM
#56
Tampa
No.
Your campsite may not be level front to back.
Obviously, you can't lower the tongue hitched up, but you can raise it.
I carry a home made block, 12" x 12" x 5" that I place under the jack foot, then raise the trailer with the truck still attached.
03-19-2019, 07:21 AM
#57
Miami
Check List
Here is my pulling-out checklist:
Close vents: 2 roof top & 1 stove hood
Disconnect shore power, turn on gas valve & switch refrigerator to gas mode for the road
Turn off: Hot water heater & water pump
Secure and latch: Cupboards, loose items, liquids & table
Wind down TV antenna
Check ice in refrigerator & coolers
Secure awning
Raise stabilizers
Stow chocks & blocks
Stow Dump hose, electric cable, TV cable & water hoses
Close storage lockers
Secure forward windshield
Attach sway & torsion bars
Secure breakaway chains
Lock receiver to truck & coupler to hitch
Connect 7-pin electrical plug to truck
Lock doors, Stow steps
Raise tongue jack
Check trailer lights: running, break & turn, (emergency blinkers)
03-19-2019, 08:11 AM
#58
2014 27' Flying Cloud
Wenatchee
We don’t lower the stabilizers or jack when we’re just stopping for a few hours but I do walk around the trailer & truck before leaving and during every stop. There’s too many things to go wrong (caught a trailer tire going flat that way one time, changed it in a Rest Area).
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
03-20-2019, 04:39 PM
#59
2004 25' Safari
Hanford
Secure awning
Raise stabilizers
Raise tongue jack
Then check everything again before you pull out.
03-21-2019, 07:50 AM
#60
Miami
Depends on how white your hair is!
