05-16-2018, 04:53 PM
2016 26' Flying Cloud
Southlake
State inspection annoys me
In Texas, you have to get an annual inspection on any trailer with a GVWR exceeding 7500#. Our 26u is 7600#. So for 100#, I have to make sure everything is secure inside, the stabilizers are up, power disconnected, install hitch and bars, tow trailer 2 miles to Kwik Lube and pay $7. “Can you get in the truck, turn on the lights, turn signals and hit the brake pedal? Thanks. “. Then and only then can I go to the local county tax office and pay $77 to renew the registration. I wouldn’t mind it if the inspection was actually meaningful.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
05-16-2018, 04:59 PM
2007 22' International CCD
Corona
Our trailer plate renewal for a 22 footer, lighter than yours was north of $250 bucks....here is sunny Southern California.
If all I had to do was take the AS on on short trip and renew my tag for a grand total of $84, not counting my time and gasoline to get there and back, I'd be smiling all the way.
Hm. now that I have some hard data, I think I need to convince DW to move to Texas.....
Smile, it could be much, much worse!!!
By the way, in Chicago, you don't pass the inspection unless there is a $20 bill wrapped around the registration card when you check in...and that vanishes into the inspector's pocket...
05-16-2018, 06:14 PM
2018 27' International
Southeastern MI
, Michigan
Michigan plate is permanent. No inspection, no smog BS for the truck, no nothin’.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
05-16-2018, 06:17 PM
1976 31' Sovereign
Oswego
Illinois does not have inspection of rec. RVs.
05-16-2018, 06:51 PM
2017 30' International
Broomfield
$77 for registration? I’d go through all that for a $77 registration bill. I just paid mine - it was over $1,400 for my 2017 30’
05-16-2018, 07:04 PM
2018 28' International
Fayetteville
, Georgia
Sounds like you are in Georgia...
brick
05-16-2018, 07:20 PM
2007 27' Safari FB SE
NW Oregon in a nice spot
, Oregon
You could sell the trailer and not be aggravated?????
In NY they do that and have to remove one wheel to look at the brakes...so you get to coach the inspection place through that concern with an Airstream.
Or, look at it as a cost of doing business with a travel trailer....
Bigger issues to get in a tizzy over. Read the post running on dump station delays. Easy to make a big stink over that situation!!!
05-16-2018, 08:08 PM
2018 30' Classic
Jacksonville
When I lived in Hawaii you'd take your car to the laundromat to get the inspection filled out then go to the gas station to turn in the signed form, pay the money, and get the sticker.
We don't do any of that in Florida.
05-16-2018, 11:35 PM
Tampa
It's tax revenue.
05-17-2018, 05:23 AM
Lakes Region
, New Hampshire
You should probably take it back, complain, and make them do it over again correctly.
4.20.12 Electric Brake System. (Trailers) (Ammeter)
1. Inspection Procedure. a. Insert a low-range (0 to 25 amperes will be adequate for most two and four brake systems; 0 to 40 amperes may be required for a six brake system) DC ammeter into the brake circuit between the controller and the brakes. With controller in “off” position, ammeter should read zero. Gradually apply controller to “full on” position; observe maximum ammeter reading and current modulation. Gradually return controller to “full off” and observe return to zero ampere and current modulation. Divide maximum ammeter reading by number of brakes.
Check for loose or dirty terminal connection and for broken, frayed, or unsupported wires.
2. Inspect for and reject if:
a. Trailers showing a per-brake maximum amperage value of more than 20% above, or less than 30% below, the brake manufacturer’s maximum current rating.
b. Ammeter showing no reading, or needle indication not steady on application and release of brake controller.
c. Loose or dirty terminal connections; broken, frayed, or unsupported wires.
d. Trailers using single conductor or non- stranded wires or wires of a size below brake manufacturer’s minimum recommendation.
05-17-2018, 07:10 AM
2019 25' Flying Cloud
Hendersonville
, North Carolina
Inspection/Registration Fees
Be glad you do not live in North Carolina. Went to register our new 2017 Int. Serenity 23D Last May and was told it would be a one time "Road Use Tax" fee of $1750,00 and the first year tag at just under $1000.00! Yes, you read that correctly. Each year you pay property tax on your vehicle and RV registration renewals. Also, car/pickup have annual inspection fee of $30.00. The tag for my tow vehicle, 2013 Ford E150 van is around $230.00 for one year. We wound up registering Airstream in Ohio. No annual inspection and the tag is $21.00 per year.
05-17-2018, 09:09 AM
2017 28' International
Virginia Beach
, Virginia
We live in Virginia and we do pay personal property tax. This past year for our 2017 28' Serenity it was $919.00. We also have to pay for an annual inspection which is not terrible expensive. My license plate is permanent. The personal property tax will go down as the trailer ages. But it is a bite. My biggest complaint is not having to pay the fees, it's the process of hitching up and making a special trip to have it inspected. I suppose I could do it when we're heading out on a trip, but I really don't like the idea of taking a fully loaded rig into an inspection place. Such is life.
05-17-2018, 09:13 AM
Rivet Polisher
1973 31' Sovereign
Mt Pleasant
, North Carolina
I have a friend who swears by this -
https://mainetrailerregistrations.com/
and he lives in Florida!
-Jim Pantas
1973 31 ft Sovereign
2009 Chevy Express 3500
05-17-2018, 09:39 AM
HOUSTON
What is required under 7500# in Texas
Does this mean that a trailer with less than 7500# in Texas avoids the annual inspection only?
John1048
05-17-2018, 09:58 AM
2015 30' Classic
Saint Augustine
Florida taxes ?
In Florida we have no property taxes on any type of vehicle ( with or w/o an engine), no inspections either. The inspections in RI were a joke and just a way for the state to get more money out of ya'. Rhode Island they taxed everything. I couldn't wait to get the heck out of there.
05-17-2018, 10:39 AM
2018 30' Classic
New York
, New York
I don’t even know that I would know how to coach them through the process. Who does trailer inspections in NY?
05-17-2018, 11:42 AM
1964 26' Overlander
Milton
, ON
Ontario too, as far as the trailer is concerned. You pay once (I think it's $72 now) and the plate is permanent. No trailer inspections.
05-17-2018, 12:02 PM
Hendersonville
, North Carolina
I lived in Naples, Florida for 13 years before moving to North Carolina in 2014. If I had done a little more homework on the tax/tag/property tax issues, I would have kept my Florida residency. I am only 60 years old and plan on returning to Florida residency at retirement. Miss Naples badly.
05-17-2018, 01:23 PM
2005 25' Classic
Austin
Inspection eliminated
On my 2005 Classic they had put the weight on my title and registration at 8,000 lbs. I took a picture of the Serial Number plate that shows max Gross Weight is 7300 Lbs and went to the tax office. They first said I would need to get it weighed, but I protested after showing the Serial Number plate. After going to a supervisor they gave in and reduced the gross weight on their records and sold me the new license renewal without an inspection.
Dennis
05-17-2018, 01:27 PM
2001 30' Classic S/O
Leander
Since you have a three month window for the annual registration, can't you pull into an inspection during one of your outings?
I was amazed at how many rigs are titled in TX to folks who don't live there.
John
